Dishwasher was running fine. I smelled a burning smell. Stopped washer. Visually checked things out-didn't see any smoke-turned it back on. Smelled smell again-smelled like wood burning! Turned off machine, unplugged and tried to pull it out. See no signs of fire and now machine will not turn on at all-no lights, no noise (yes it is plugged back in)
-   Bosch Classixx, running ok .Smells of melting plastic/burning, when cycle nearing end . No visible sign of damage..?????? -   PCahalin
Feb 23, 2009
-   Having the same problem where the wire nut connectors are melted. How did you fix your problem, did they fix via recall or did you find fix?? Thank you. -   dittim
Feb 23, 2009
-   having the same problem with the wire nuts are melting in the electrical connection box. Did you get a replacement? how did you fix problem? Thank you!-   Guest
I've had the same problem TWICE. It seems the natural vibration of the machine loosens wire nuts and leads to the problem. Soldering the connection and then placing a yellow wire nut over the soldered connection works fine to stop the problem. This machine has a electric water heater to sterilize the dishes and draws a lot of power, near the limit of the connection, more than a standard dishwasher. I called Bosch twice about this problem, only the second time when I stated that my lawyer might call them back did they admit that there is an issue with the vibration of the machine leading to the wire nut becoming loose and suggested I solder the connection. Great dishwasher, lousy customer service. They have know about this problem for years.
Had similar problem on my Siemens which is the same as Bosh. I started to take it apart to see what had gone wrong. Eventually I had to disconnect the cable going into the washer - its in a small box at the front at the bottom. The wire nut connectors had melted and shorted out. Unfortunately now it won't fill with water. The smell was not like wood so maybe a different problem.
Maytag dishwasher MDBTT70AWB anything I should know about the machine. Any trouble shooting...
(More)
Maytag dishwasher MDBTT70AWB anything I should know about the machine. Any trouble shooting problems.
BF1620 dishwasher - filter blocked - cleared, operation starts then stops with water in. filter...
(More)
BF1620 dishwasher - filter blocked - cleared, operation starts then stops with water in. filter blocked lights again.
Woke up to all four red lights on right flashing, and bleeping sound after a load put in last night....
(More)
Woke up to all four red lights on right flashing, and bleeping sound after a load put in last night. BDF60SS. Thanks
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
