Question about Kenmore 17024 Built-in Dishwasher
Kenmore Model 665
Normal Wash light is flashing, unit will not cancel
  • 2 more comments
  • Anonymous Jun 11, 2008
    the lock on control flashes and the washer won't work. i TRIED TO PUSH AND HOLD THE NOT HEAT DRY CONTROL FOR FOUR SECONDS AND DIDIN'T HELP.
  • jillynr Oct 11, 2008
    The lock on light flashes. I pushed the dry no heat button, but will not stop or let me cancel. Machine is un-useable this way.
  • rascals75 Nov 21, 2008
    The quick rinse light stays on, the "no heat dry" button flashes three times and then the "lock-on" light comes on for a second then off. The "no heat dry" button continues on its three flashes cycle again and so on and so on. The "cancel drain" button seems to be the only button that works - you can hear the dishwasher try and drain for a few minutes even though there is no water in it.
  • Anonymous Jan 01, 2009
    Same problem. When pushing ther buttons, more lights flash. I turned off and turned back on the power. This did not help.
How do you clean out the bottom, when something gets stuck in it.
Posted on Jan 30, 2009
  • 413 Answers
The blinking button lights indicate the buttons are bad. The console will have to be replaced.
Posted on Jun 02, 2008
What can I do my dishwasher Kenmore model 665-13834K601 the Cancel and Normal wash lights are blinking and won't work
Try this, unplug it from wall outlet for one minuet to reset its processor. Then plug it back in to see if that worked.
Dec 03, 2014 | Kenmore Dishwashers
Kenmore 665 Dishwasher
Sound like you have a bad control console, which will need to be replaced.
Apr 08, 2012 | Kenmore 13742 / 13744 / 13749 Built-in...
Kenmore Ultrawash dishwasher Model 665 15810000. Originally "water heating" light was flashing and no water in dishwasher. Replaced water inlet valve. Turned power back on, normal wash light goes on...
lock light is locking the panel push this child lock button for 3 sec and see if it un locks . then try it again .. may have a pannel out. mm
Dec 06, 2009 | Washing Machines
My kenmore dishwasher 665-15817 has a blinking ''Lock On'' button
- To clear the flashing light you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Jun 06, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore dishwasher 665 15752 wont cycle right
Sound like door/latch is not providing a secure door close anymore. Push on the door when the lights flash and see if this stops the blinking and continues with wash cycle. If it does, there is either somehing interfering withe the door closing fully, or the door latch on the door or dishwasher side is worn/defective.
Feb 22, 2009 | Kenmore Dishwashers
Kenmore 665 15899
To reset and run diagnosis on the model 15899100 Kenmore Dishwasher you need to press the following buttons on your front panel. Hi Temp, Air Dry, Hi temp, Air Dry. The sears service technician just left my house and used these codes to reset and run diag on my washer.
Hope this helps
Jan 05, 2009 | Kenmore 15899 Built-in Dishwasher
I need to reset the mother board on my Kenmore dishwasher. Do you know the code for the Kenmore model 665-17032402. I was told by sears that they used to give this out but, because of a fire hazard they...
The clean light sometimes flashes and just needs to be reset. To do so hit the keys in the following order. <Heated Dry> <Normal Wash> <Heated Dry> <Normal Wash> <Cancel>.
The dishwasher will go through a cancel cycle (drain the tub) and will then let you start it up again.
Apr 19, 2008 | Kenmore 17024 Built-in Dishwasher
Kenmore 30" stainless steel tub Model#665-110729120 Serial#FM2101476
Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button. This will clear any existing faults and should return the dishwasher to normal operation.
Apr 10, 2008 | Kenmore 15073 Stainless Steel Built-in...
Clean Light is flashing
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Nov 27, 2006 | Kenmore 24 in. 16023 Built-in Dishwasher
Kenmore 17024 Built-in Dishwasher Logo
317 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
