Question about Motorola Mobility E398 Cellular Phone
It doesn't gharge even with a new charger
It doesn't charge even with a new charger
    Filmmaker:
    Uploaded 5 video answers.
  • 150 Answers
Sometimes the pins inside mob
were broken
or battery were old these are the two cases
for not charging
try to charge with another battery
Posted on Apr 23, 2008
  • shivam raj
    shivam raj Apr 24, 2008
    if u done this then we go further to solve your s problem
  • shivam raj
    shivam raj Jun 16, 2008
    thank you
How do I gharge the battery
Hi Anonymous:
There are actually several ways:
1) Start the engine and let the alternator charge it.
2) Attach the leads from a battery charger and turn on the battery charger.
3) Attach "jumpers" from another vehicle's battery, start that vehicle, and leave it running long enough to charge the battery.
- ALWAYS CONNECT POSITIVE TO POSITIVE, AND NEGATIVE TO NEGATIVE.
- CONNECT NEGATIVE LAST.
- MAKE SURE BATTERY HAS CORRECT FLUID LEVEL
- WORK SAFE! BATTERY FLUID IS ACID AND CAN CAUSE SEVERE BURNS.
Sep 20, 2015 | Cars & Trucks
Where to get gharging cable for veco12cbd
Here is a generic replacement charger at a good price. I measured the open circuit voltage of my charger and it is 18-19 volts.
HQRP AC Adapter Charger for Black Decker VEC012C TYPE 1 VEC012CBD TYPE 1...
Mar 27, 2014 | JUMP START SYSTEM
Coby Kryos Android Tablet is not charging. It is connected to a charger but its not charging.
Leave the tablet connected to the charger for 5-10 minutes even if doesn\'t work. Then take out the battery and try with master charger and (switch on the tablet) after that, check whether the previous charger is working again or not again. If it doesn\'t show charging sign, then you have to take it to service center to change the charger connector.
May 21, 2013 | Tablets & eReaders
Phone will not charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jul 27, 2012 | Samsung Galaxy S 4G Cell Phone
Haven't ridden the bike all winter. Battery flat. WHat kind of charger do I need to buy ?
If the battery is to recover, you must not charge the battery at a greater current than 10% of the rated A/H. So if the battery is 20Ahour get a charger that gharges at around 1.5 to 2.0 Amps.
There are a few float chargers that are good as they regulate the output current to a low level.
Good luck and ride safe.
Feb 03, 2011 | 2001 Suzuki GZ 125 Marauder
Gharge kit not gharging battery
if its not a problem with the charge station then it must be the battery. i had the same problem. i had a microsoft(xbox 360) charge station and bought a "gigaware" battery and charger for my controller. the cord charged the gigaware just fine but the dual charge station would not. good luck with it bud sorry if this doesnt help. key point is that the battery has to be the same brand as the charge station.
Nov 11, 2010 | Video Game Consoles & Games
WHEN TRYING TO CHARGE IT WILL DISPLAY CHARGER NO AUTHORIZED AND IT WILL REMAIN AT 3/4 GHARGE.......??????
change your charger because sometimes the charger gets faulty and cannot provide the required amount of current to the battery. Second reason is not using the original charger so in both the cases you have to get a new charger to solve the problem. If the problem stil remains, then contact the customer care centre
Sep 18, 2010 | Motorola Mobility VU204 Cell Phone
Phone was working fine then battery went out of charge,when I got home I PLUGED IN MY CHARGER AS NORMAL BUT NOTHING I HAVE TRIED SEVERAL TIMES TO GET TO GHARGE BUT NOTHING.
Try these and tell me the result.
1. Try to charge from a different charger.
2. Use another battery and try to on the phone.
3. After plug on the charger press power on/off button for a while. If nothing happened on your mobile after use these 3 tips then visit Nokia service center for installing the operating system on your phone. If the OS is corrupt then the mobile going under dark. No movement, no signaling of charging nothing. Even you can't update it from internet right now. Because the phone memory is fully dead. Its happened with all mobiles if the OS corrupt. Its was happened also in my Nokia N73.
Thanks &waiting for your reply.
Feb 04, 2010 | Nokia N95 Cellular Phone
My nokia 6280 is not keeping gharge and is refusing to charge
1-Try another trusted genuine battery.
2- Try another trusted genuine charger.
3- If RETU IC is not under-filled try yo reflow it, if not works then replace it.
4- No way but to try replacing TAHVO IC even if it's under-filled (if you really want to solve the problem) ;) .
maybe ur bsi line short to ground!!
try to remove the resistor in bsi line....
Mar 21, 2009 | Nokia 6280 Cellular Phone
Motorola Mobility E398 Cellular Phone Logo
61 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
