Question about Sharp AL-1642CS Copier
My Sharp AL-1642CS is a workhorse. Today it stopped copying but prints fine. The scanner head seems to be stuck in the home position and there is a whirring / grinding / clicking noise.
  • Anonymous Mar 25, 2008
    asdf
  • 29 Answers
Try to check the safety lock under the scanner unit.if the lock is in the lock position unlock it.
Posted on Mar 25, 2008
SOURCE:
Need driver for Sharp al 1642 cs with windows 64-bit
Please communicate with me through my email then i will send driver to you. thanks
Nov 05, 2012 | Sharp Al-1642cs Print/scan/copy
My copie send uno l and 1 a not funtion
You are having a problem wth the scanner unit home position or the scanner can not move correctly
Apr 14, 2011 | Sharp AL-1642CS Copier
I have a sharp al-1642cs that will not work it just keep flashing L1 can you help
www.cyberscholar.com/sharp/resources/cop_man_soho_AL1642CS.pdf
http://www.service-docs.com/store/catalogue.php?cat=281&exp=0&resultpage=10 L1 00 Feeding is not completed L1 00 Feeding is not completed
within the specified time
after starting feeding.
(The scan head locking
switch is locked)
1.unlock Scanner unit
2. chang connecter
Scanner unit
May 09, 2010 | Sharp AL-1642CS Copier
I have a Sharp AL 1642 CS. It prints black copies. It came out of no where so I know it isnt dust on the lens. Even after adjusting brightness settings it prints pitch black pages. The bulb on the scanner...
Problem on three things.
1.OPC drum cleaning blade is very old,so lost her activities.
2. Laser unite very dirty,so you need clean.
3. setup or configure exposure control.
# Press Auto key three second
when exposure light indicate now position,select way lighter side.
Jan 20, 2010 | Sharp AL-1642CS Copier
Prints blank sheets of paper, code is L 1, can't find manuel
Blank pages means the Drum becomes bad, Change the Drum.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Jun 17, 2009 | Sharp AL-1642CS Copier
Will not copy
Sounds like a scanner issue, when you make a copy, lift the lid slightly, does the scanner pass by smoothly? if not, it may be obstructed, or it could have a motor problem.
If it an obstruction, you should see it as the scanner moves, turn the machine off then on, this usually causes a scanner pass and reset to home. Look through the glass as it does so to see if it is catching on anything. if it is a foreign object, remove the glass and clean out the optic cavity.
If only one side moves or the scanner is crooked, it has slipped on its cables.
If it just moves in jerky fashion, it could be the motor.
Hope this is of some help.
Ed
May 23, 2009 | Sharp AL-1642CS Copier
Sharp AL-1642CS Copier, the scanner is jammed
Not familiar with that model but what I would try is to turn off the copier remove the glass and try moving it by hand, then turn it on and see what happens it may have a bad motor
Oct 29, 2008 | Sharp AL-1642CS Copier
Prints and scans fine, but copies are all black
Hold down the auto expsoure key the the lights will began to blink light copies then push it again to hold lighter expsoure.
Jul 18, 2008 | Sharp AL-1642CS Copier
Sharp al-1642cs
if scanner is not going all the way back you need to ck the home posinson senser it may be dirty.
Feb 05, 2008 | Sharp AL-1642CS Copier
"Scanning in progress" reported even when I'm not scanning anything
You need to install the print driver and Sharpdesk before you connect the USB cable.
Dec 10, 2007 | Sharp AL-1642CS Copier
267 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
