Question about Epson Stylus Photo R320 InkJet Printer
Prints gobbledgook! Hi. Every so often my rs320 will start printing rubbish symbols and will continue until i press stop. Also I have developed very poor communication with computer. Have to turn off both printer and computer before printer is found. This has gone on for sometime. Epson tec are usleless. Leads appear fine but have not changed them? Cheers Michael
    Scholar:
  • 67 Answers
You diagnosed a bad connection with the computer. Try changing the connection cord, borrow one if you can, just to test it. What does "leads appear fine mean?" Best Wishes.
Posted on Apr 08, 2008
SOURCE:
Printer prints rubbish but test page is correct
Power off printer. and unplug USB cable, Go to control panel and uninstall all related software.reboot PC.
Go to printer Manufacture website and download latest version of software.
install software. do not plug in the printer until told to do so.
Hope this helps
Mar 01, 2013 | Epson Stylus Multifunction Inkjet Printer/...
Dear FixYa Sometimes when I'm printing a word document contains only one page the printer prints rubbish characters or unknown symbols also beside this the printer prints these rubbish characters on a...
This is usually caused by a spooling error or more likely an error within microsoft word. I would try to make a pdf of the word document and print from that.
Mar 14, 2011 | Office Equipment & Supplies
How do I align the top of form position & for adjusting printing position on my pre-printed form?
Make sure continuous forms are in the printer.
Press Alt and then press Setup to enter Setup Mode.The
printer prints out the Main Menu.
To select a function, press the buttons listed on the printout.
To save the setting and leave Setup Mode, press Start/Stop
until out of the menu.
Jul 13, 2010 | Lexmark 2380 Plus Matrix Printer
Prints one or to pages then stops. Have to reset computer to get it to work. No test doesn't work. It is like it runs out of memory.
Try to run a test for continuous print test page in diagnostics mode. To enter the Diagnostics mode:
1. Turn off the printer.
2. Open the front access door.
3. Turn on the printer while pressing and holding Cancel .
4. Close the front access door once the Error light displays. Print the menu page by pressing and holding Continue until all of the lights flash. Follow the instructions on
the menu page to access the menu items.
Continuously print pages containing cross lines, printer information, and margin settings. Press and hold until the Continue button lights flash to begin. Press Cancel to stop.
Make sure he selects the "Cont Prt Simplex Tray 1" option
If problem persists, contact Lexmark at 1-800-LEXMARK()1-800-539-6275.
Apr 21, 2010 | Lexmark E260dn Laser Printer
Prints 2/3 of the way, stops, continues, bottom is faded
It sounds like you need to replace Toner Cartriage
May 19, 2009 | Samsung ML 2010 Laser Printer
Printer crashes
Hi Ann,
Check the ribbon cable that comes out of the back of the print carriage for damage / disconnection. They don't normally wear loose, but it is possible.Failing that, the print engine could have failed, which would deliver duff data to the heads, thus printing rubbish onto the page.
Mar 05, 2009 | HP DeskJet 670c InkJet Printer
I have a xerox dc12 with error message please turn machine off and on again 9-363 have tried several times but no good! what else can I do?
That's a process problem with that machine.
May require a service call .ON and OFF is pretty much all a customer can do and wait for it to setup.
NOTE: The problem occurs because of the trickle development system in the machine, making extended lengths of black and white copies / prints does not allow the black developer housing to purge itself of excess waste Toner (Dry Ink) and Developer. There are two solutions for the problem:
  • Make 1,000 copies / prints of a black and white job, then make 150 copies / prints of full color. Continue making 1,000 copies / prints of the black and white job, then 150 full color, and so on, until the entire black and white job is complete.
  • Make extended jobs in groups of 100 by making 100 copies / prints of the black and white job, then allowing the machine to cycle down (return to 'Ready') and making the next 100 copies / prints. Continue in this pattern until the entire black and white job is complete.
Apr 28, 2008 | Xerox DocuColor 12 Printer
Error 9-363
NOTE: The above solutions are based on jobs using 8.5 x 11 inch paper, single sided, with no more than 28% coverage.
Feb 18, 2008 | Xerox DocuColor 12 Printer
or
  1. Power OFF the machine.
  2. Wait 30 seconds.
  3. Power ON the machine.
Dec 04, 2007 | Xerox DocuColor 12 Printer
Epson Stylus Photo R320 InkJet Printer Logo
53 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
