Question about Acer Aspire 5100 Notebook
Keyboard, usb mouse unusable.
Can not access Bios. F2 key does not work. Only way to access computer is through pcmci adaptor, by connecting usb keyboard and mouse.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 160 Answers
Take him to company service point i think thier it will clear
Posted on Mar 27, 2008
Durabook T7M no access to BIOS
Keep trying until the keyboard is ID'ed. Unplug, remove battery, plug in, reboot. Is there a reset button?
Jan 25, 2013 | Computers & Internet
What function key gives entry to cmos
BIOS is fixed program that starts up the computer. BIOS is initialized during start up of HP Compaq-6715B which sets the computer settings to be uploaded. BIOS enables the creation of a bootable diskette, CD, or USB key that can be used to locally restore or upgrade the System BIOS in the supported notebook models with a 68YTT Family ROM. Only insert the USB drive that will be used to format and create bootable BIOS upgraded USB media. However, you should remove all unused USB drives and flash drives from the notebook before. In order to ROM family and ROM date, press F10 on the target notebook during startup to run the setup utility.
The tips to get into the BIOS of HP Compaq-6715b are:
  • Press F2 for setup
  • Shows logo
  • Independent of OS
Press F2 for setup
BIOS often has a blue background, and uses the arrow keys, PageUp, PageDown and enter keys to change the settings. After you have got into or accessed the BIOS, you can change the boot order settings so that the floppy disk is checked first to see if it contains a bootable program. Usually a message will appear telling you how to enter the BIOS setup program as the computer starts up, such as Press F2 for Setup.
Shows logo
Your HP Compaq-6715b might be configured to show your computer's logo instead of important BIOS messages. In this case, you can press Esc or Tab while the logo screen is visible. If you are facing problems pressing the pause button in time, turn on your computer with your keyboard unplugged. In this situation you will receive a keyboard error, which helps you in pausing the startup process long enough for you to see the keys necessary to enter BIOS.
Independent of OS
The PCs with both PS/2 and USB connections are configured to only allow USB input after the POST. If you are using a USB keyboard, it could be impossible to access BIOS. You would need to connect an older PS/2 keyboard to your PC to access BIOS. The BIOS accessing is independent of any Operating System on your computer because the BIOS is part of your motherboard hardware.
http://www.bostonrecycling.net/
Jun 25, 2012 | HP Compaq 6715b Notebook PC
How can i load the bios setup if F2 or F12 keys are not working in my "Acer Ferrari 1000" notebook.?
You can do this by buying an external usb keyboard and connecting it to your computer usb port. When you restart your computer you should be able to enter your bios setup by means of pressing F2 or F12... Have a nice day friend. Hope this would solve your problem.
Aug 17, 2011 | Acer Ferrari 1000-5123 Laptop
My keyboard on my laptop wont work at all!!
  1. Turn off the computer, disconnect all external mouse devices, keyboards, USB devices, and the port replicator or docking station, and then restart the computer.
  2. Ensure there is not any debris between the keys or liquid spilled on the keys.
  3. Verify that the NUM LOCK is turned off.
  4. Remove all the accessibility options for the keyboard in Control Panel.
  5. Remove and reinstall the keyboard driver.
  6. Using the System Restore utility, restore the computer to a time when the keyboard was working correctly.
  7. Reset the BIOS defaults.
If the keyboard does not work in the BIOS Setup utility, the issue is likely a failed keyboard and service may be required.
Oct 21, 2009 | Toshiba Satellite Pro L300D-EZ1006V...
Mouse and keyboard freeze.
its a very common hardware fault with these laptops, can you open setup or bios? that is opened right when the power is turned on the and screen says press F2 to enter bios or setup, if you can't enter bios then you have a faulty motherboard, usb ports don't work either? (usb keyboard and mouse don't work?)
May 13, 2009 | Acer Aspire 3100-1405 Notebook
About the Aspire 5100 notebook , Keyboard , USB port and Mouse pad not working , the problem apear when you power on , for exemple you want to go to BIOS , first power on then press an F something key on...
  1. Unplug all the device except keybord and monitor
  2. Press F2 and go to bios and you have restore the bios
  3. restart the computer, then it will be back normal.
Still have problem, just reply me
Thanks, PREM
Mar 21, 2009 | Acer Aspire 5100 Notebook
USB system is not working
nope..you can try to boot from an installtion cd..but without HI options(Human Interface) you may find it's locked..sounds a lot like the Motherboard went south.
You could try to reseat the memory, but that's a low probability approach to this sort of problem
Mar 30, 2008 | Acer Aspire 5100 Notebook
Keyboard & mouse are dead
I just fixed this problem by doing the following:
Hard power-off (hold the power button until the laptop turns off)
Unplug the AC adaptor
Remove the battery
Plug in the AC adaptor
Hold ctrl and turn the power on. You should arrive at a black screen.
Hard power-off again, then turn the power on.
Nov 11, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Notebook Logo
74 people viewed this question
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
