Question about Pioneer PD-R609 CD Recorder
Pioneer pd-609 cd recorder
It says set-up to record but then returns to say 'check disc' even with new or different brand cd-rw audio discs. it also has trouble finalizing if i finally get one to record!! i have used disc cleaners etc..any help please?
  • monoblue May 09, 2008
    I have the very same problem as posted by simeoni. My idea about what the mistake could be, is, that the recorder can't read the TOC properly, because sometimes it says "new disc", although I know, there are tracks on the CD-RW AUDIO. I've tried to clean the discs and sometimes it seems to help, but I'm not sure, it could also happen by accident. The problem does not occur with CD-R AUDIO. Is it possible, that the energy of the laser has subsided? My Pioneer is 5 years old and I've recorded a lot of CDs.
6ya staff
SOURCE:
Anonymous
  • 56 Answers
SOURCE: I can not get my CD recorder to record
You should use consumer cd's that are rather expensive. You probably tried to record a recordable cd-rom (a cheap computer disc). It's not possible to burn a pro-disc (computer disc) by using your Pioneer, and that's why you got that message on the screen. Refer to the user manual of your cd recorder and learn what sort of blank cd you should use.
Posted on Aug 07, 2007
Anonymous
SOURCE: pioneer pd-m406 cd changer magazine style
The Pioneer component 6 CD magazine changers only play normal store bought CDs, not CDs you make yourself.
sorry.
Posted on Feb 20, 2008
Anonymous
  • 85 Answers
SOURCE: Pioneer PD-F805 can`t read discs.
Few things either cd,s are not compatible
laser has died or laser ribbon cable is broken
Posted on Jan 08, 2009
Anonymous
SOURCE: hi can i record on my pioneer pdr 609 cd without
Hi John
You should be able to record without the remote control; make sure you have a blank disc in place, then press the 'RECORD' button on the front; it should go into recording standby mode. When you want to start recording, press the button below the REC BALANCE buttons (the play/pause button, marked with a triangle and a II symbol) and this should get you going.
Try it and get back to me if not.
Hope it works!
Kev
Posted on Jul 25, 2009
afecu
  • 5 Answers
SOURCE: I'm looking for a Service Manual for Pioneer PDR555RW CD Recorder
Here's a site that has the service manual and service guide (you need both). They have 2 copies of the service manual (the second and third links); you only need one of them.
http://elektrotanya.com/?q=showresult&megnev=&megnev2=555rw&kategoria=&kat2=all
Posted on Jan 15, 2010
I have a Pioneer PDR 609 CD recorder. I put a disc in and it says Pro disc din unlock.
This is nearly always due to cable problems. I think the cheaper optical cables can get 'kinked' quite easily, which would stop the signal coming through properly. So, first check your settings to make sure the correct cable type has been selected. If that's OK, try replacing the cable with a good quality one.
Jan 02, 2014 | Pioneer Computers & Internet
My Pioneer PDR 555-RW keeps reading Mon1 or Moni when I try to record my CD from my mixing board. I need to send this wedding music, and it is trapped in my board. HELP!
That's just a MONITOR indication. It means you can SEE the audio from the selected input on the record level meters for adjustment or other reasons. It won't prevent you from recording. Set your levels then hit RECORD, let it set itself up and calibrate to the disc, start your source and hit Play or Pause to start recording to the disc.
May 14, 2011 | Pioneer PD-R555RW CD Recorder
My problem is when i record it show pro dish
Do you mean "pro disc?". Home CD Recorders are limited to recording on CD-Audio or CD-Music blank media. CD-R's are considered 'pro'. Get the right media.
Jan 04, 2010 | Pioneer PD-R609 CD Recorder
Perfect in recording CD's recording of CDRW's (TDK CDRW AUDIO nor MAXELL CDRW XL II music) not possible. how to fix?
If the CD recorder records data discs, and is not a CDRW recorder it will not record on them, also there would be no reason to record a audio CD if the unit records data discs
Dec 11, 2009 | Pioneer PD-RW839 4-Disc CD Recorder
Hi can i record on my pioneer pdr 609 cd without using the remote control,as ive purchased a unit with out one and cant get it to record, thanks
Hi John
Hope it works!
Kev
Jul 25, 2009 | Pioneer PD-R609 CD Recorder
Won't record record to CD-RW
First make sure your cdrw disc is blank. If it is blank try another good known cdrw brand disc and burn it in 12x speed for a good burn.
If it still fail check the software side of your cd rewriter first and lastly the cd rewriter unit.
Mar 28, 2009 | Crosley 4-in-1 Entertainer CD Shelf System
Can't get it to record
I experienced this problem a long time ago, i believe that it was because i tried to use a normal data cd-rw but the unit only reads audio discs. It has to be a cd-rw for audio only (will say cd-rw audio on the disc, whereas if it is a data disc it will simply say cd-rw.) Hope this helps..
Mar 13, 2009 | Pioneer PD-R509 CD Recorder
Wont record on blank pc disks!
I had the same problem and found that I was using the wrong type of CDs. If you look on the CD you have to use the CD that says Compact disc digital audio Recordable or Compact disc digital audio Rewrittable. After I used the Digital ones I could record on it. I then tried the CD on the PC and it worked. You can look on the top of the unit and see the information if you still have it. Hope this helps you.
Feb 23, 2009 | Pioneer PD-RW839 4-Disc CD Recorder
Aug 05, 2007 | Pioneer PD-R555RW CD Recorder
Loading DVD-RW discs
My recorder has stopped accepting NEW DVD-RW discs and ejects them.
There is no problem loading DVD-R (new or recorded)or loading previous recorded DVD-RW, initializing and re-recording
I have tried several different DVD-RW makes. Puzzling??
Nov 03, 2006 | Pioneer DVR-5100H DVD Recorder
Pioneer PD-R609 CD Recorder Logo
102 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
