Question about Vacuums
Panasonic MC-E4013 has lots of **** but won't pick up. Drive belts and brush roller go round OK, Any ideas?
  • 328 Answers
There are a few things to check.
The Twin Bin model could have clogged filters, So you'll have to depress the button on the top and check that the first top filter isn't clogged, then check the removable black filter and check that it isn't clogged with dust. Once these have been removed ensure that the mesh filters are completely clear. Although Panasonic dont suggest it, you can wash the top grid white filter and the black filter but you must ensure that both are dry before installing them. Low temp tumble dry in a pillow case will get the sponges dry in around 10 to 20 minutes but dont use a high temp as the plastic grid will melt! The mesh filters can be cleaned using the on board upholstery brush. Failing that use a paint brush to dislodge any clogged dirt - the worst for cutting suction is the powdery greyish white powder which always clogs the mesh filters.
Then before putting everything back, take the bottom hose out of the front by unhooking it before putting the bin back on. Remove the sole plate and the whole tube should be able to come off although you may need to unscrew the holder at the soleplate area which holds the bottom hose to the bottom of the cleaner. Once that is done the entire hose should come off free and by sticking a blunt stick down this hose slowly, there may well be a clog.
This model and the rest of the Twin Bin series aren't particularly well designed. Ive had two models from Panasonic over the years, both of them being the Twin Bin design uprights (MCE 4003 and MCE 4103) which still have the same inherent problems of pick up when the filters or hose gets blocked. The beauty of the Panasonic however is that the hose handle can be removed by pushing in the lugs and getting around the machine for maintenance is easy but time consuming.
Remember that you do have two drive belts on this machine so make sure the motor pulley belt to the drive belt is secure.
Hope that helps!
Posted on Mar 28, 2008
SOURCE:
How do I open a Panasonic Power Nozzle to replace the belt? The Vacuum Model # is MC-V9635
The top part of the nozzle pops off just put small screw driver on side and lift up under the top lid is 2 screws then pop off by putting screw driver on sides to lift the housing off base plate
here is roller
Sears Kenmore Brush Roller 8192670 8175102 And 742454
and roller
Sears Kenmore And Power Mate Canister Power Nozzle Belt Part 20 5285
Jul 05, 2014 | Panasonic Vacuums
Panasonic ecomax carpet bar won't drive
The first thing to check is make sure the belt is not broken or stretched. It is possible that a vacuum cleaner may need a new belt even if you just bought it. It may have been a year or more since it was assembled and had the belt installed. It may have spent some time in a warehouse and on the store shelf before making it to your home so the first thing to check is always the belt. If it has a stretch belt they must be stretched to almost twice their original length when installed on your vacuum and they lose elasticity. The rule of thumb in the vacuum industry is belts should be changed every three months for proper agitation. If the belt is not broken or stretched check to see if there may be something stuck in there preventing the brush roll from spinning freely.
Oct 24, 2013 | Panasonic Vacuums
The brush bar isn't going round ?
your problem seems to be the belt has snapped. Underneath the the hover there is a rubber belt that connects around the brush bar and around the motor, this belt will be broken. They can purchased from any hoover shop for a couple of pounds.
Jan 06, 2013 | Dyson DC24 Ball All-Floors Upright Vacuum...
Hi, i have a panasonic eco max, the brush has stopped going round, the belt is as new and brushes clean.suction good from hose. Any ideas please? thank you
The brush on this model is controlled by the on/carpet/floor switch and will only work in the carpet position. If the suction motor is running then it could be the roller brush motor, but it's more likely to be the microswitch which stops the brush motor when the handle is returned to the upright position.
Dec 03, 2012 | Panasonic Mc-Ul594 Eco Max - Bagless...
Brush won't turn on my Panasonic MC-CB467
There should be a safety reset button. So like if you suck up a rug it will shut the power to the brush roll off, then reset it.
Nov 14, 2012 | Panasonic MC-CG467 Bagged Canister Vacuum
Belt is melting or burning not sure why
It doesn't matter what or why. Use your owners manual and it will show you how to change the belt. When you open it up whatever is hanging the brush roller up will either show itself or when you remove the brush roller it will fall out. Change the belt. That smell is the motor shaft slipping past the belt and burning it with friction. Either way the belt will need changing if it's had that much wear on it.
Mar 07, 2010 | Panasonic MC-V5481 Upright Vacuum
Impossible to change belt--cannot get belt to go over pulley.
first put belt on big round roller then use a flat screw driver to pull it onto the motor shaft
Dec 10, 2009 | Panasonic MC-V7515 Bagged Upright Vacuum
Ny Panasonic MC-E4013 has lots of ****, but the brushes don't pick up from the carpet. The drive belts are not broken and the brush roller goes round OK.
Usually, shen you have this problem, there is an obstruction of dirt etc. somewhere in the suction path.
You need to take the vacuum apart and clean thoroughly first.
Then get back to me.
Mar 21, 2008 | Vacuums
Panasonic MC-V7395 Belt overheating/snapping
I have the same problem. I keep thinking I have fixed it, but then another belt breaks. I only have the issue when the roller is disengaged. (on bare floor setting). I did find that the unit was slipping back into engaged slowly, because the disengage mechanizim was not kathing prperly,. Tightened up a screw, and now appears to hold, but somehow the belt still get broken - I beleave it is an issue that the belt is not staying away from the drive when it is disengaged.
Jan 05, 2008 | Panasonic MC-V7395 Vacuum
Change belt
To get to the brush roll, you have to take the bottom part. There is no belt, the brush roll motor is part of the brush roll.
Dec 29, 2007 | Panasonic MC-E583 Bagged Upright Vacuum
Vacuums Logo
70 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
