Question about RCA Lyra TH1012 MP3 Player
Rca mp3 TH1012
Unit comes on but won't play any tunes.It will play songs on the computer but not through earphones.Problem seems to have started when I put a new battery in.
Have you tried another battery perhaps the battery is at fault
Posted on Nov 07, 2008
I have WMA files on my iPOD 4gb black but I can't play them on iPOD earphone but can on computer.?.
The WMA files will not play on your Ipod because I pods only play the AAC format for songs.
The songs you have has to be converted to AAC files to play on your Ipod...
You will also need to have I Tunes on your computer to download the songs to your I pod once you have converted your songs to the AAC format.
I believe I Tunes will convert the songs to AAC format for you, but just in case it does not:
You can get a free song/video converter from the following website:
http://www.formatoz.com/
Good Luck,
I hope this helps
Nov 23, 2009 | Apple iPod nano
My Coby MP200 will not play the songs that are on it.
While it may be something you're well aware of, did you navigate to the folder on the Coby where the songs reside? Is it possible you loaded the mp3s in a directory that is not the default and so the player doesn't see any music. Another possibility is the copyright protection won't allow the player to play the songs. The license may reside on your computer but is not on the mp3 player. Last two thoughts (as stupid as they sound) are is volume up? Is earphones securely plugged in? Have you tried the earphones on another unit to make sure they work? Coby Tech Support at 800-727-3592 6AM-11PM EST
Jul 30, 2009 | Coby MP-C883 MP3 Player
Mp3 won''t work
I've never heard of audio CD being block before from playback. Try this:
Reset your Ipod back to factory settings.
Drag and drop your songs from Itunes into your player. Do not use playlists.
Playback the songs from Itunes using the Ipod player as the file location. If playback is working, undock you Ipod from the computer and play again using the MP3 player.
Dec 02, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Rca mp3 player TH1101A
Either the DB is corrupt of the license on the songs expired - make sure the music service is completely up to date. If it is, then go to RCA's website and get the latest firmware update.
Jul 01, 2008 | RCA TH1101 MP3 Player
RCA mp3 H125PA
I know my does that too.
Jan 09, 2008 | RCA Lyra TH1012 MP3 Player
My RCA Lyra RD1072A just doesnt play songs
The most probable cause that I see happening to people with the same item is the fact that somewhere between uses, the setup files in the device itself gets corrupted. When this happens, you're pretty much screwed. You can't access them because it won't let you, you can't format it because it won't let you, you're left with a dead mp3 player. Sorry, but you need to get a new one. The other one is trash.
Nov 09, 2007 | RCA Lyra TH1012 MP3 Player
Rca th1012
I have the same problem and just used mixmaster's solution to a different problem to solve this one. Here's what he said:
e4087a1.jpg By master_s.gif mixmaster
Rank: Master
Rating: 78.68%, 258 votes
Try removing the battery and connecting it to the computer.
If it shows up on the Computer, format it.
To format in My Computer>Device Name (Lyra)>Right Click and select format.
This will erase everything on the device and allow you to start over.
Best of Luck.
Sep 29, 2007 | RCA Lyra TH1012 MP3 Player
Mp3 says "No Files"
Sounds like you may have tried to put "too many" songs on the device pushing it over its limit. If it connects to the computer and shown up under My Computer, you can right click on it and select "format" this will remove all of the music on it. Thereafter, you can drag files directly onto it under My Computer. There is no real need for any software. Best of Luck.
Sep 16, 2007 | RCA Lyra TH1012 MP3 Player
My mp3 doesnt play music properly
This is caused by the ground connection from the earphone socket not making contact with the main PCB.
This can be repaired by anyone competent with a soldering iron.
The four contacts on the earphone socket need to be re-soldered.
Aug 28, 2007 | Philips SA1100 MP3 Player
RCA Lyra TH1012 MP3 Player Logo
115 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
