Question about Canon imageRunner C3100 Copier
Error 000013 Says to reset the machine. Guess we are calling a tech on this one. Will post a follow up.
E 013 is waste toner full. drop open the front door, you should see the bottle. now look for a single screw in the cover at the top of the bottle. remove the screw and bottle. dump the bottle in a thash bag. there is a light that shines thru the neck of the bottle, that path has to be clean. pull off the clear tape andplastic cones and blow out as much toner as you can and reassemble. don't wear white :) rp
Posted on Mar 22, 2008
SOURCE:
How to fix error code c2214 on develop ineo 951
Either you do not have sufficient toner remaining or your toner sensor is falsely saying such. Follow your procedure for installing toner. If memory serves me, some toner cartridges have to be shaken but don't rely on my memory, follow the instructions.
If toner replacement does not fix the error, try resetting the machine. If that does not clear the problem, you may have to call tech support for a service call.
Aug 06, 2017 | Office Equipment & Supplies
What is the problem of error code 000013-0000
Thanks a lot , i can clear error code e000 of ir2010 by your solution ,I press *function and # and arrow to #7 press ok and #4 printer reset press ok
Dec 17, 2013 | Canon imageRUNNER 2010F Copier
Error code E-000013-0000 on a Canon Image Runner 5000
e-000013, it is all about waste toner.
possibility :
- waste toner case was detecred full.
- The PLL lock is released because waste toner motor is locked up, etc.
- The micro switch employed to detect clogging of waste toner is activated.
the position behind-below of copier.
open the beck cover and you ll see it.
the waste toner case
Jun 09, 2011 | Canon imageRUNNER 5000 Copier
Apears the code fdU and dont let go the water and make a funny noise
"FdU" is a Door Latch Unlock error code. This is usually an indication of a failed door latch, a Central Control Unit (CCU) problem, or the interconnecting wiring between the two. The first step in troublehsooting any error code on these model washers is to press PAUSE/CANCEL to clear. If the error remains, UNPLUG the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit. In many cases, resetting the CCU will correct many momentary glitches in the program operation. If the error returns following a CCU reset, then you have a legitimate problem. The following link explains the door latch error and what you can do to troubleshoot:
http://www.fixya.com/support/r4490349-fdl_error_code
I know the link is for the "Fdl" error, but the symptoms, troubleshooting and remedies are identical. I have included web links for part resources (if required).
NOTE: EACH ONE OF THESE APPLIANCES COME WITH A TECHNICAL DATA SHEET INSIDE. THIS IS THE SAME SHEET AN APPLIANCE REPAIRMAN WILL REFERENCE ON A SERVICE CALL. REFER TO THE TECH SHEET FOR MORE DETAILED TROUBLESHOOTING INFORMATION.
The tech sheet contains troubleshooting data, wiring diagrams, diagnostics procedures, component illustrations and all error code definitions.
To access, you will need to remove the lower toe panel directly below the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access to the screws (a 2x4 works well for this). With the screws removed, the panel should drop down, and come off. If the tech sheet isn't directly behind the toe panel, it will be affixed to one of the interior cabinet walls.
It is recommended that the tech sheet be placed back inside the appliance when repairs are completed in order avoid losing and to keep this pertinent info for future use.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
May 10, 2011 | Kenmore HE3T Washer
My kenmore elite front load washer model # 110.46742702 displays code F 27. what does this mean?
"F27" is an Overflow Detect error code. The following link explains the code in detail and lists the steps to take to try to resolve:
http://www.fixya.com/support/r3608602-f27_error_code
A simple thing to try before assuming you have a component failure is to UNPLUG the washer for at least 30 minutes in an attempt to reset the Central Control Unit (CCU). In some situations these error codes can be erroneous and a simple CCU reset will correct the problem. If the error reappears following a CCU reset, then you have a legitimate problem that you will need to troubleshoot to resolve.
NOTE: Each one of these washers come with a technical data sheet enclosed inside the equipment cabinet. The tech sheet lists all error code definitions, diagnostic procedures, troubleshooting data and wiring diagrams. You may have to refer to the tech sheet to assist in troubleshooting this problem.
The tech sheet is located behind the lower toe panel directly below the washer door. To access, locate and remove the screws under the bottom front edge of the panel. For better access to the screws, you can prop the two front feet of the washer up with a 2x4. With the screws removed, the panel should drop down, then come off. The tech sheet will either be located directly behind the toe panel or affixed to one of the interior cabinet walls.
If you have any questions, please post back and let me know. I hope you find this information helpful.
Mar 08, 2011 | Kenmore HE2 Plus Front Load Washer
How can I manually open the door of WT741 washing machine? Machine keeps showing error 'F - 05', and won't allow me to open the door?
If this is a Whirlpool Duet, Kenmore Elite, or Maytag Epic series front loading washer, "F05" is an NTC Heat Sensor error. This is an indication that the heat sensor is either defective, or the interconnecting wiring has come loose. The following link explains:
http://www.fixya.com/support/r3608669-f05_error_code
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you need assistance in locating the sensor, please post back with a complete MODEL NUMBER. The NTC is usually listed under the "Tub and Basket Parts" listing.
NOTE: For an explanation of all the error codes, each one of these appliances come with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front fett of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot this error code.
Sometimes when the washer halts with an error code, the door can remain locked. If the door is locked and will not open, there is a manual release you can use to open the door. The following link explains:
http://www.fixya.com/support/r3576511-door_jam_on_kenmore_elite_and_whirlpool_
In many cases, this is all that is necessary to free up a jammed door latch and return it to normal operation. Another method you can try is to reset the Central Control Unit (CCU) by unplugging the washer for AT LEAST 30 minutes. If the latch still fails to operate correctly following a CCU reset, then you may have to replace it.
If the latch requires replacement, the following link explains how:
http://www.fixya.com/support/r3575840-replacing_a_door_latch
If you need further assistance, please post back and let me know. I hope you find this advice helpful.
Dec 22, 2010 | Whirlpool WFW8500SR
Washaer starts the fill cycle and F1 error code appears. It will reset with the cancel button. Is this a control board problem?
Hi
Thanks for using FixYa. Yes you are right, Error F1 means primary control failure and to resolve this you’ll have to replace the machine control assembly. This error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 14, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
System Error
Sometimes, this class of copier will "hiccup" and throw an "Exxx" error code; most of the time nothing is really wrong, it just needs to be reset. You can try the following procedure to reset the copier: First, you press the Additional Functions key, then you press the # key, next you press > until you get to #7 Printer Function, then you press Set, next, you press > until you get to #4 Printer Reset, once again, you press Set, then press <. After this is done, unplug the copier, then plug it back in and turn it on. The machine should reset and go back to normal functions. If the code appears again, there is a deeper problem and a Canon tech will need to be called. Good Luck!
Oct 21, 2009 | Canon Image Runner 1630 Copier Copier
Riso HC5500 System Error - Restart!
I need help with the error code. s04-307 in my riso hc 5000
Oct 22, 2008 | Office Equipment & Supplies
87 people viewed this question
Clive
Clive
old marine
old marine
Ekse
