Question about Refrigerators
Kenmore refrigerator model 46-66812 ice build up on the bottom shelf of freezer
  • Kenmore refrigerator model 46-66812:
  • Everything work  OK except that recently, In the bottom shelf of freezer compartment, ice start to build up. I remove all food in that area and ice as well; overnight, ice restart to build up. This morning, I had about a 1/8 of an inch of clear ice
Had the same problem. I noticed that the fan in the freezer never shut off so I suspected the thermostat. I ordered and installed a new thermostat (about $30 and 15 minutes to install), the fan now cycles correctly and the ice build up is gone.
Posted on Dec 14, 2009
Your drain is blocked and it causes blockage and then ice forms..turn of for 24 hoyrs and it should be alright
Posted on May 25, 2008
Kenmore elite fridge. Bottom freezer ice builds
You have a bad defrost system on this unit, that's why you're freezing up. Call us with the model number and we'll get the correct part out to you right away. We hope to hear back from you soon.
Oct 09, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Hi, I can help you. The drain is plugged in the freezer section. Could I get the model #?
Some models need an after market drain heat strip added.
Please let me know and I can get you through tis.
Thanks
Vic
May 30, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Ice build up on freezer floor.
Hi, If ice is building in the freezer, you have a defrost drain hole plugged. Unplug the Fridge and then remove the rear panel off the freezer. There you will find ice built up in rain. Remove the ice (hair dryer works best). Once the ice is gone, you need to make sure the drain hole is open all the way. A baisting serringe with hot water works really well.
I hope this helps. Please let me know if I can assist you further. Please rate my answer so I know how I am doing.
Thanks
Vic
May 22, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerator doesn't defrost
theres a defrost control on the unit that is probebly bad. its in the upper right of the refrigerator aand depending on the unit is either solid state or mechanical
Mar 26, 2009 | Kenmore 53342 / 53344 Side by Side...
Water accumulating in top shelf of refrigerator
Get yourself a thermeter and see what the tempeature is in the freezer. It should be "0" degrees or colder. If it is hanging around 30 degrees +/- you may have a compressor or control problem. You may have a drain tube clogged that takes the water out of the freezer. I am not familar with your model but many freezers are similar.
Mar 15, 2009 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Kenmore Elite 596755 - Freezer warm, Ice Melted, then...
did you move it or tip it on its side when these devices are moved sometimes it will create anair pocket in the cooling system after moveing let stand for a few hours before plugging back in.
Jan 15, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Water gushed out freezer door, possible solenoid problem?
The drain is clogged. The drain is usually located inside the freezer on the bottom shelf to the rear. Use a meat baster and a solution of 1 tsp. baking soda and 2 cups of hot water-not boiling to unclog the drain. You probably also have about 1/2 inch of ice build-up on the bottom shelf. This will have to be removed first.
Nov 13, 2008 | Kenmore 50522 / 50524 Side by Side...
Whirlpool refrigerator with top freezer either model GR2 or 9FHTXT will not keep get cold
Sounds like the defrost drain has become iced over or clogged. This is why the ice builds up.
Jan 14, 2008 | Refrigerators
Ice build up on the bottom floor of the freezer
Sounds llik a defrost heater is open if you
have a VOM you can test it for continuity
Its probably behind a panel in the rear bottom
of the refrilgerator Should have a pan under
there to
Nov 21, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
1,909 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
