Digital to analog converter box to tv/vcr combo
How to hook up a digital to analog converter box to a tv/vcr combo so can still record.
  • 2 more comments
  • zurnmom1 Apr 13, 2008
    I have a 40 foot tower anntenna-how can I still use it when analog stops?
  • ferocious Sep 08, 2008
    how do you hook-up c converter box to a TV/VCR combo TV
  • Bonnie Lind Dec 01, 2008
    I cannot record on my VCR since installing the converter box. I followed the illustration for the hookup that came with the converter and I have tried various combinations of the switching Ch 3 and 4. The VCR is not using the converter box when recording. Help!
  • Anonymous Dec 30, 2008
    I have the same problem. I have hooked up the converter as described and still have the same issue. If the signal is digital signal getting to the TV/VCR combo and I am recording ch3 input, I do not understand why it can't record
You will need a splitter and an rf modulator to do timed recording of programs. The instructions are on the dtv answers website, option # 2, record and watch a different channel. The recording is for the analog stations 1-24. You cannot record the higher stations. The items I purchased were a 3 way splitter $7 at local hardware store, an rf modulator $25 at Radio Shack. The other option was to get a cable box for the tv and record off of that at $6.95 a month or a DVR for $8.99 per month, all from comcast. The price that I paid for the items I needed would be repaid in 3 months if I were to go the comcast route. The conversion is nothing more than a money making scheme for them.
Posted on Jul 24, 2009
You can record if you set it up the way yalmer said. You just can't do preset recordings anymore. You have to be at the tv and hit record when the show you want starts.
Posted on May 27, 2008
  • 552 Answers
You need to put the antenna to the input on the digital box and put the output from the digital box to your tv/vcr combo(rf out).
If you have sound and picture component inputs(monitor inputs) on your tv, then you go from them on the digital box to the tv(red,white,yellow).
Posted on Mar 21, 2008
How do I record a tv program with a Sharp A400 VCR? Videos will play on the tv, but I was not able to get it to record. Thanks.
Your VCR is no longer capable of recording "off air" tv signals. All tv stations are now broadcasting in digital format, your VCR is analog only. You can however get a digital converter box that will receive "off air" digital signals and convert them for recording on your VCR. CLICKING HERE will give you all the information you need to hook up the converter box... Good Luck!
Nov 10, 2009 | Sharp VC-A410U VCR
I have a new digital tv but can't get my vcr/dvd player recorder to work. Can I use the converter box on a digital tv? will it work to record and play.
The output connection from the VCR/DVD needs to be different for the new digital TV. Instead of using the RF output from the VCR, use the video and audio outputs and connect them to the video and audio inputs on the digital TV. When you want to watch the VCR, select "video in" on the TV. The digital converter box should be hooked to the input of the VCR so you can record programs off-air.
Jun 14, 2009 | Insignia Digital-to-Analog Converter for...
How to record mutliple programs with a converter box
You will not be able to record like you used to: http://www.ezdigitaltv.com/VCRs_and_Converter_Boxes.html There are some boxes that have a timer, but not many.
Vcr hooked to tv and converter box. Will not record digital chann
The vcr has to be set to channel 3 or 4. The converter box has to set to the channel you want to record the show from and left on during the time that the vcr is recording or you will get no recordings.
Apr 19, 2009 | Philips Magnavox DVD/VCR Dual Player
Hook up analog vcr to hd tv
You must have a converter box for the tv and for the vcr. Set the vcr to receive chanel 3 and set the converter box to the digital chanel you want to record. Put a splitter on the antenae out and route one to the tv converter box and one to the vcr converter box. GOOD TO GO.
Apr 11, 2009 | Sanyo Televison & Video
Getting my VCR to record from the TV with a converter box hookup
Hook up antenna to converter box then from that out to the vcr's input (red,white, yellow connections are better than coaxial).
Jan 20, 2009 | Insignia Digital-to-Analog Converter for...
Need to hook up dvd/vcr combo with converter box
Connect your rabbit ears to the Insignia. Connect the Insignia to the antenna input on the "cvd/vcr combo". Now turn on the television to show the "cvd/vcr combo".
The Insignia simply goes between your antenna and your television. In your case you also have a vcr so if you want the VCR to be able to play and record digital stations you will need the Insignia between the vcr and the antenna.
Dec 28, 2008 | Insignia Digital-to-Analog Converter for...
Wish to record on analog VCR and not affect digital TV reception
I don't think it will affect the digital TV reception, but if you try to use the VCR built-in tuner it is still analog and you won't be able to record digital channels that way. If your digital TV converter has video-out and audio-out connectors, then you can connect those to the corresponding connectors on your VCR to record.
Converter box
1) Connect the coax cable from the antenna to the converter box input.
2) Connect the coax cable output of converter box to the input of the VCR.
This is the only way it will work but you will have many limitations such as using the programming features of your VCR.
The boxes are fine if you want to play prerecorded DVDs or tapes. If you want to record tapes you have to leave the box on and have it set to the station you want to record.
May 27, 2008 | Insignia Digital-to-Analog Converter for...
Televison & Video Logo
612 people viewed this question
Top Televison & Video Experts
