I HAVE A PT-61HX40 THAT CUTS OFF EVERY FEW MINIUTES 8 YEARS OLD .WHAT IS CAUSEING THIS?
  • 796 Answers
If it's a CRT projection unit, it could be the screen controls need adjustment, the convergence amps need replaced, you have a loose connector or loose power supply connections or loose deflection circuit connections.....
It really needs a good TV tech to isolate where the failure is....
Posted on Mar 21, 2008
My 2004 pt cruiser shut off and will not even try to start. Shut the car up and came back next day and the alarm will not stop sounding. What can be the cause and how can i fix these problems?
2001 PT Cruiser Cuts Out, Engine dies for no reason ...
? 2:04
www.youtube.com/watch?v=cG9qCHfBhGw
Jan 10, 2014 - Uploaded by michelle salazar
2001 PT Cruiser Cuts Out, Engine dies for no reason ... picked it up on October 18, 2013 only to have it die on me while on the interstate. After it ...
Turn off alarm on 2009 PT Cruiser - PT Cruiser Forum - PT Cruiser ...
www.ptcruiserlinks.com > ... > Sound and Security Forum
Aug 18, 2013 - 10 posts - ‎8 authors It's not an add-on alarm, it's just the factory alarm. ... then I go in to panic mode (because it's horribly embarrassing when it goes off and won't shut off) and try everything else - like pressing the lock button, ... 2004 Pt Cruiser GT Car alarm installation, operation, problems and solutions ...
May 17, 2013
KEYLESS ENTRY stop working
Nov 1, 2009
How to reset Security.....
Apr 26, 2009
Programming the keyless Remote
Mar 13, 2005
More results from www.ptcruiserlinks.com
Oct 02, 2015 | Cars & Trucks
Need to know how to install lamp
Your set does NOT use a lamp--it has picture tubes, and if no pix--may have lost one or more convergence chips.
Mar 29, 2014 | Panasonic PT-61HX40 61" Rear Projection...
Powers up then shuts down within 5 seconds? Power supply board? How much to repair?
MAYBE...A POWER SUPPLY BOARD REPAIR CAN COST YOU MAYBE $300-$500. OR MAYBE A FEW CAPACITORS..SMALL REPAIR. AFTER 13 YEARS, IF IT IS THE POWER BOARD, YOU MAY WANT TO INVEST TO A NEW MODEL.
Jan 31, 2014 | Panasonic PT-61HX40 61" Rear Projection...
Panasonic pt-50lc13 won't show picture. Blinks green when turned on can hear lamp clicking then goes off to red blinking for a few miniutes then shuts down to just red . Can u help me out please?
sound like your lamp is bad ...Panasonic TY-LA1000 Lamp Replacement...Ballast Repair Kit for Panasonic PT-50LC13 some time the ballast go bad as well to hear bouth part number one lamp and 2 ballast I hope this help you..
Nov 19, 2013 | Televison & Video
My panasonic rear projection TV turns off
this just happened to us, we tried the reset button, didn't work. we unplugged from surge protector and plugged the tv in the regular wall socket and after a few minutes the green light quit and we were able to turn tv on
Apr 08, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Laptop keep on cutting out
if it's not loosing power, random dropouts are usually due to an overheat. check to make sure that the fans are running and replace if necessary.
Aug 14, 2009 | Computers & Internet
Blue convergence will not move left or right
look at the convergance board it will be the one on the left there re two stk semi-conductors tward the back of the board. most likly one of them are bad but sometimes the soldering can be faulty. look for signs of cold solder if so just resolder and should be good if not also look for burnt resistors. it will be obvious finding the stk 's can be done by using google and just type in the stk # finding the resistors you might try calling panasonic to find the part #by telling them the location of the burnt resistor. good luck. mind you that the soldering of the stk (semi-conductors) you will want to use a heat sink on each terminal you solder otherwise you take a chance of burning the conductor befor you ever get to use it, if you have no exp. soldering i wouldnt sugest trying it !!!!
Oct 17, 2007 | Panasonic PT-61HX40 61" Rear Projection...
Skt IC and Capicitor??
You need to replace both STKs. They are pretty obvious to find in the unit. They are normally mounted to the same heat sink and will typically be about 3 inches long each, maybe 2 or so high...Front should read something like STK350-120
Feb 07, 2007 | Panasonic PT-61HX40 61" Rear Projection...
Clean inside of the screen? Spider webs?
You should get the service manual so you dont take apart something you shouldnt
Aug 24, 2006 | Panasonic PT-61HX40 61" Rear Projection...
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
