Question about Epson RX620 All-In-One InkJet Photo Printer
RX620 "Ink Cartridges cannot be recognized"
The first time the cartridges needed replacing I used some unofficial cartridges - the printer came up with the error message above and there's nothing I can do to reset it. Tried getting new set of Epson cartridges and putting those in but error message won't budge.  Tried the reset trick (start/stop/b&w/colour) but that does not work - any ideas?
  • Anonymous Oct 01, 2008
    nk Cartridges cannot be recognized" problem, and notify you when a new solution is offered.
Found the solution at
http://www.fixyourownprinter.com/forums/printer/54833
Try pressing down on the cartridges after inserting them and closing the top of the cartridge carriage. Worked like a champ on my R320 printer!
Cleaning the contacts on the cartridge with a soft tissue may help too.
Posted on Feb 11, 2009
Try- on -stop -color sametime
Posted on Feb 12, 2009
RX680:
After many tries...... I but just under top cover piece od rubber on cartridge which failed ( to make it bit more pressure on cartridge) and closed cover ! Amazing! No problem at all.
Posted on Jul 15, 2009
SOURCE:
Error B200
press the helpful button and follow me on fixya for more tips
an electronic issue with one of the cartridges
How to Fix Canon Pixma Support Code B200 Error Message
http://www.mytechtime.com/2011/09/canon-error-b200-how-to-fix-it.html
Feb 01, 2016 | Office Equipment & Supplies
I cant print it says I'm out of black link and I just replaced it and it's flashing E 1 6
From http://www.refreshcartridges.co.uk/igloo/clearing-canon-pixma-error-message-e13-e16/
Locate the STOP/RESET/RESUME button on your printer which is represented by a triangle within a circle on the body of your printer and is usually in red, white or black as pictured below. With the reset button located hold it down for at least five seconds and then release it.
Aug 02, 2015 | Canon PIXMA Office Equipment & Supplies
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
My HP Photosmart D-7160 keeps advising me that the yellow cartridge is empty even though I just replaced it. Any ideas?
Note that illustrated instruction some of the following can be found at:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00692953&cc=ca&lc=en&dlc=en&product=1156652&tmp_track_link=ot_search
Step one: Reset the printer
CAUTION: Do NOT perform any other type of reset on the printer before the ink initialization process has been completed.
1. Without turning the power off, remove the power cord from the back of the printer and from the wall socket.
2. Wait 30 seconds and reconnect the power cord to the printer and to the wall socket. Turn the unit on if it is not already turned on.
3. Check the printer for the error message. If the error message still displays, go to the next step.
Step two: Clean the cartridge contacts
Lift the top cover.
Locate the ink cartridge indicated in the error message. Squeeze the gray tab below the cartridge slot to release the latch and then lift the latch.
Remove the cartridge indicated in the error message.
Gather the following cleaning materials:
Distilled, filtered, or bottled water. Do not use tap water, alcohol, or platen cleaners.
Lint-free cloth or swab. Eyeglass wipes and coffee filters work well.
Lightly moisten the swab or cloth and squeeze out the excess moisture.
Holding the cartridge by its handle, wipe the copper contacts.
Replace the cartridge and then close the latch and the printer top cover.
Check the printer for the error message. If the error message continues, go to the next step.
NOTE: The printer might take up to 15 seconds to clear the error and recognize the cartridge after closing the cover.
Step three: Replace the cartridge
If the error message continuess, replace the indicated cartridge with a new cartridge.
You might also want to perform the built-in internal tests to verify that the printer internal firmware is functioning properly.
NOTE: The tests do not verify that the computer and printer connections are working properly.
It is always preferable to perform all these tests when the communication cable has been disconnected from the printer, and after having turned off and on the printer.
1. Make sure plain paper is loaded in the In Tray.
2. Press and hold the Power button.
3. Press the Resume button four times.
4. Release the Power button.
Trust the above helps resolve your problem. Please vote. :)
Dec 20, 2010 | HP Office Equipment & Supplies
Cannot print, scan or copy. Continue to receive
Solution
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts. Click here to see how.
  3. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
  4. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty.5. Replace Cartridge.Please rate my response!!!Thanks,SF
Jan 28, 2010 | HP PSC 2410 All-In-One InkJet Printer
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    "remove and check cartridge" error message
    http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=buu02180&cc=in&lc=en&dlc=en
    I resolved the "remove and check cartridge" issue after reading the instructions at the above address. Most importantly, I replaced both cartridges and the problem was resolved.
    The color cartridge appeared to be the issue. It had been in for months and used infrequently.
    May 30, 2008 | HP OfficeJet 6110 All-In-One InkJet...
    Refilled Cartridge
    How can I Reset Memory For Lexmark X4550
    Feb 14, 2008 | Lexmark X5150 All-In-One InkJet Printer
    Error code: U150 The following ink tank cannon be recognized (Cyan)
    U150 ink error fixed!
    I too was getting the error for unrecognized ink cartridge. Then the little green circ board fell out of the end of the ink cartridge and it hit me that maybe if I put in the little green circ board from the old ink cartridge of the same color, then maybe the ink cartridge would be recognized. It worked! So don't throw out an ink cartridge that still has ink just because of that error and hold onto your empty cartridges in case you need the little green/gold circ boards.
    This works!
    Dec 26, 2007 | Canon PIXMA MP600 all-In-One InkJet...
    Error message Alignment
    There is no doubt in my mind it Will be the cartridges you are using, alignment will continue to be requested if print out is missing bits do yourself a favour and use HP gen., not trying to plug HP just telling you the facts
    Dec 06, 2007 | HP PSC 750 All-In-One InkJet Printer
    Epson RX620 All-In-One InkJet Photo Printer Logo
    1,892 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    Inky Fingers
    Inky Fingers
    Clive
    Clive
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
