Question about Canon NP 6050 Copier
Canon NP6050 Waste Toner Cartridge
We have a message to replace "waste toner cartridge" but we can't locate it. Do we have to call a service person, or is this something we can do on our own?
  • 1 more comment
  • Dejaem Mar 25, 2008
    Unfortunately it must be a different model or maybe year of manufacture... but the waste toner was in the back of the copier. We had to remove the entire back panel and then a smaller side panel to slide out the waste toner cartridge, which looked like a large bottle. Now the system error is still there but the cartridge is empty. Any ideas on how to reset the error message?
  • Anonymous Apr 24, 2008
    we are also facing the same problem.
  • simonin Jun 09, 2008
    comment changer la cartouche sur canon NP6050 ?
    Merci de votre réponse
  • Canon Expert
  • 270 Answers
I'm doing this from memory since I don't have a copier in front of me. You will have to reset the counter for waste toner by going into service mode. You do this by opening the front door and inserting a straightened paper clip into the small hole just below the control panel. If you do this correctly there will be a $ sign at the upper left of the LCD screen. Press the * key, then the 6 key and then the * key again. Another screen appears. Use the arrows displayed to move through the screens until you see WSTTNR. Insert the paper clip again and while still pushing in on the paper clip press the "C" key on the keypad. The counter should go to all "0's". Also check the counter for the web. If its close to 250,000 copies you will be getting a replace web soon message. You reset the counter just like the waste toner counter. Just for good measure you may want to do an overall copier reset in the *4* service mode. Select OK and the copier will shut down automatically and come back on on its own. That should clear any other errors the copier may have. I hope this gets your problem solved.
Posted on Mar 30, 2008
You can do it on your own. There's actually instructions on the LED display but it went something like:
1) open front (access door for toner area)
2) Slide blue handle up to open position.
3) Remove was toner receptacle.
Now since I didn't have a new waste toner, I just dumped out all the toner and re-inserted it. I imagine there may be some repurcussions or the toner is hazardous, I'm not sure. I'll actually get the waste toner cartridge for next time though.
Posted on Mar 21, 2008
SOURCE:
Waste toner container message won't go away after replacing cartridge
http://www.imagerunneradvance.com/imagerunneradvance_c5035.html
Here is a link to the brochure for your machine. You may find your answer in here.
I also would have thought that if the power was turned off and on again after the toner was changed, that it would reset itself. I suspect you have already thought of that, though. Sorry I cannot be of more help but the brochure might be the answer for this query and perhaps more in the future.
Dec 21, 2012 | Canon imageRUNNER ADVANCE C5035
Changing waste container
The is no waste container on Phaser 6500. There is a "waste collection box" in every toner cartridge and the waste toner is discarded along with the empty cartridge. The is also a waste toner reservoir on the transfer belt and this one will be replaced along with the transfer belt.
If there is an error message saying, for example, "Waste Full Cyan Cartridge", it means the waste toner counter reached the replacement value for that color and you have to replace the corresponding cartridge. But the waste collection box is not really full.
Sep 30, 2012 | Xerox 6500/N Phaser Laser Printer
Message
the waste toner cartridge/bottle is located on the right rear panel. remove two screws and empty the bottle.
Jul 15, 2010 | Canon imageRUNNER 5020 Copier
Toshiba E-Studio 202L cartridge does not match manufacture
Did you replace the waste (used) toner cartridge or the empty toner cartridge? These copiers have 2 "cartridges" .... one is waste (used) toner, the other is "new" toner for copying / printing etc. Some newer copiers have All in One units....Drum, New Toner, Waste (used) Toner. If you replaced the Waste Toner container (or dumped it) that should reset the code or error message.
Jun 23, 2009 | Toshiba e-Studio 202L Copier
Toner waste container location
The waste toner is in the front, open front cover and the white bottle in the middle is the waste toner cartridge. Remove the black screw, and empty or replace the cartridge.
Mar 30, 2009 | Canon iRC3100 Printer
Emptying waste tone cartridge
You need to replace the waste toner bottle (packaged with a new toner cartridge) you can't just empty it. There is a photo sensor that "reads" through a window of the waste bottle. The sensor could be dirty. Clean the slits with a q-tip.
Oct 01, 2008 | Kyocera Ai3010 Copier
How to reset waster toner bottle full Xerox 3535
Here's what I did.
Emptied the waste toner cartridge. Left it out of the machine. Held the microswitch (located to the right of the optical sensors) in the "cartridge in" position with a paperclip. Printed one document. Inserted the waste toner cartridge. Error now gone!
GCC.
Aug 27, 2008 | Xerox DocuColor 3535 Copier
Waste Toner for GP200 series
The waste toner is collected inside the drum cartridge. It can be emptied by removing the drum cartridge assy and opening the opaque window and emptying into a large bag. The lines on your copies are probably a symptom of the drum being worn out, so replacement is probably a better option. The drum is good for 60,000 copies.
Jul 17, 2008 | Canon IMAGERUNNER 6570 Copier
Canon NP 6050 Copier Logo
680 people viewed this question
Clive
Clive
old marine
old marine
Ekse
