My neighbor is using the signal from my modem. is there a solution to this?
    President:
  • 2,351 Answers
The only way a neighbor can tap into your internet service & catch a free ride is if your using a wireless internal /external router. You stated your using a modem. Your neighbor would have to access to your telephone service. Therefor call your telephone Co. & turn them in. They'll send out a service tech & check the wiring. If you find you are using a wireless router you can block free riders from tapping your into your wireless by setting up a password. To do this open internet explorer. In the address window type in this; 192.168.1.1 than press the enter key on your keyboard.
This is your default configuration. You should be able to set up a password here. Find your manual or call the Co for the wireless router & they will help you setup security.
Good Luck & have a Great Weekend!
Mike
Posted on Mar 21, 2008
    Brigadier General:
  • 6,966 Answers
Two (2) ways:
1. Use WEP or WPA security key (but that has been known to cause a slowdown);
2. Use MAC filtering which will restrict devices whose MAC numbers are entered into a table of allowed PCs.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Often losing connectivity
Wireless router modems can be difficult. It helps to put tinfoil over your splice connectors as they leak signals that totally confuse your modem. Never leave any bare wires, I tinfoil the entire modem to prevent the neighbors from hacking me, and from interrupting signal noise. I don't use wireless, only CAT5 ethernet cable.
Feb 15, 2013 | Arris At&t Dsl Modem 2210-02-1002
When i connect the dsl cable to it the dsl light starts flashing green then red
Put tinfoil over your splice connectors and filters as they leak signals that totally confuse your modem. Never leave any bare wires, I tinfoil the entire modem to prevent the neighbors from hacking me. I don't use wireless, only CAT5 ethernet cable.
Jan 02, 2013 | Gateway 2wire 2701hg Wireless Dsl Modem
My dlink dsl 1500g++ modem not getting link as I connected working telphone cable
Wireless capable modems are touchy. Put tinfoil over your splice connectors and filters as they leak signals that totally confuse your modem. Never leave any bare wires, I tinfoil the entire modem to prevent the neighbors from hacking me. I don't use wireless, only CAT5 ethernet cable.
Mar 09, 2012 | Computers & Internet
I'm facing this low net speed problem from the time this red light started to blink in my reliance net connect+ modem. How can i rectify this problem?
If you are using the wireless modem you may have interference in your area. Try moving away from Television or other wireless devises in the home. Could be interference from a neighbors wireless telephone, as some wireless home phones use a 2.4 GhZ signal that will interfere with a wireless modem.
Sep 25, 2011 | Computers & Internet
I use an AT&T 2Wire 2701HG-B Gateway Modem and whenever I use the laptop wireless option, the modem tends to repeatedly reset itself, affecting internet use both on the laptop and a home computer which...
http://www.fixya.com/support/t4987959-att_2wire_wireless_router_keeps
Here is a solution I posted today for a similar issue. Might fix your problem.
Jan 13, 2011 | Computers & Internet
Hi, I have a 2Wire 270 DSl Modem I had bought through Qwest since they are my ISP. My home is a 1500 Sft Ranch, if the modem is in the bedroom and the Mac Book is in the family room down the hall the...
If the walls in your house are made of lathe and plaster or concrete block, then the performance of WiFi through all the walls in your house will be very bad. The signal that you are receiving from your neighbor's modem is probably only going through two walls (the outside wall of their house and the outside wall of your house), while the signal from your modem is probably going through at least 4 or 5 walls.
I suggest that you do not buy a new modem, but buy a wireless access point, a spool of CAT6 cable and two Leviton RJ45 wall jacks. Run the CAT6 cable from the modem to your bedroom, install the Leviton RJ45 jacks on both ends of the cable, and then connect the wireless access point to the the jack in the bedroom and the modem to the jack near to it.
This will expand the wireless coverage in your house and allow you to buy much better wireless device than QWest would ever sell to you.
Here is a suggestion for Wireless Access Point.
You can buy the CAT6 cable and Leviton RJ45 jacks at Home Depot or Lowes.
Dec 30, 2010 | Computers & Internet
My DSL Modem is unable to connect to the internet. The DSL ready light is not coming on but all other lights work. I tried using a different modem but same problem.
Wireless capable modems are touchy, Put tinfoil over your splice connectors as they leak signals that totally confuse your modem. Never leave any bare wires, I tinfoil the entire modem to prevent the neighbors from hacking me. I don't use wireless, only CAT5 ethernet cable.
Jun 30, 2009 | Actiontec AOL DSL MODEM BY (HOMEDSL)
Connection
ok this sounds easy
heres your problem you
DsL is a glorified phone connection its not smooth and is always in a state of flaux along with your neighbors there neighbors so on and so forth
technecoly i would run cable connection that does not flaux with neighbors always have a strong signal and wont interfere with your videos
DsL is slow as 58 bit data fax modem i found it a waist of money and time waiting for system to play catch up
now if you want to play videos with out interupt turn off cable dsl modem this will bring function back to normal in video mode
your comps fine its just your service provider
Feb 17, 2008 | Westell Wirespeed LiteLine 6100...
Can not connect
rerun your network setup wizard again this should bring back your modem and access
Jan 15, 2008 | Westell Wirespeed LiteLine 6100...
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
