Question about Tecnik 24 in. TKD795/3 Built-in Dishwasher
Tecnik dishwasher tkd795/3
We think there is a blockage where it empties,the washer will not fill and it sounds like trying to pump water out but can"t.Took the pipe out where waste water comes out,tried blowing into it but it felt solid,tried sucking but to no avail.Can"t see how to clear blockage,feels like there is water trapped underneath,thanks,debbie
  • 105 Answers
Your machine has flooded and has trippedthe flood switch in the base of machine which turns on the pump to drain and that is the noise you hear
you will need to find cause of problem which is possible leak in machine
Posted on Apr 02, 2008
1 1/2 year old lg WM2496H showed oe error code while washing a heavy unbalanced load. I removed the wet blanket (sitting in water) and tried drain/spin command with empty washer but washer will not go into...
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!!!!!!!!!!!!
Jun 09, 2010 | LG WM2496H Front Load
The dishwasher fills up it starts to spray the water but after 5 seconds it emptys. It then does the other the rest of the wash normally. This happens in all modes.
Check to see if water at the base of the washer has caused the "anti flood system" to trigger. The anti flood device is a polystireene float and micro switch that does trigger (and puts the washer in pump out mode) once water via leak or spill is detected. You can tilt the washer to 45 degrees and check if a small amount of water comes out of the bottom. As you indicate that the washer emptys after 5 sec I do think that the anti flood system is causing this.
Apr 21, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
My dishwasher doesn't clean my dishes anymore and sometimes it doesnt dry them. it is a quiet partner 1 and it is about 2 years old.
It sounds like the water pump on the dish washer has gone out. A dish washer works (much like a clothes washer) by filling up the washer with a set amount of water, then through circulation, pumps the water up through the various spray nozzels. If the water pump is worn and not making enough pressure, the spray won't get the job done. Depending upon make/model, it may be cheaper to replace the water pump.
Run an empty dishwasher load with a bowl of white vinegar on the bottom shelf. As the dishwasher runs the cycle, the vinegar is slowly disbursed and cleans the dishwasher.
Mar 02, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
What is causing the drain pump to continue running
C1 - Partially Blocked Drain - This error will occur when dishwasher was unable to pump out water in less than 95 seconds. Check drain line for debris and blockage. If clear, check for a restricted drain valve in the pump. Check the pressure sensor for correct operation as it sounds like it may be defective and thinks that the machine is still full of water after it has emptied.
Oct 30, 2009 | Dishwashers
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
Water in salt reservoir
I've had the same dishwasher for 2 years now and always had water in the salt compartment. Don't know if this is normal but disn't seem to be a problem til now. Just fill with salt as if it was empty.
Jan 03, 2008 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Empties and fills but boils the water
Can you hear/see any washing sound/spray, it sounds to me like the wash pump could be faulty.
Nov 20, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Tecnik built in dishwasher
These arms spin based on water pressure generated from the washer itself.
Run the washer. As soon as the washer is full of water and the wash cycle starts, open the door and verify that you have at least a couple inches of water in the machine. If there is not enough water in the machine, the pump will not be able to provide pressure. If this is the case, the filling sensor is malfunctioning and will need to be checked.
There's a pump that provides water pressure. It's at the bottom of the machine beneath the lower rotating arm, probably beneath additional plastics. Remove these two items and verify that there is no debris blocking water from reaching the pump as if this is the case, water pressure cannot be generated.
Good luck... let me know what happens, and please rate accordingly.
Nov 11, 2007 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Dishwasher doesn't seem to pump water through
add more water to see if it is not filling enough. if it is there may be a problem with the wash pump either a blockage or it seizing.
Jul 24, 2006 | Indesit 24 in. D63 Free-standing...
Tecnik 24 in. TKD795/3 Built-in Dishwasher Logo
424 people viewed this question
Top Tecnik Dishwashers Experts
Mike Cairns
Mike Cairns
sonic boom...
sonic boom...
Are you a Tecnik Dishwasher Expert? Answer questions, earn points and help others
