Question about Samsung SyncMaster 531TFT Monitor
Vga cable problem, is there anybody who can help?
I really have problem get a vga cable for syncmaster 531 TFT also called LXB531TL. There is really interesting connector its 26pins.i just found on internet that its called 26-pin MDR (Monitor end) to 15-pin D-sub (PC end)
i really couldn`t find this type of cable, i have three TFT monitors like this one is.if you can help me i will be really happy.thanks
  • enzo2k Mar 21, 2008
    this is that video connector on my tft screen which i couldn`t
    find i cable for. please help
SOURCE: 13pins "from the inside monitor" "to the VGA 15 pins connector
hai dear,
i checked your problem and found that you open the cover of monitor and you find the two jack of data cable in main pcb and neck card( 2 connector of data cable).plz you cut the connector of data cable and you will find 8 wires in connector.related red(invild extra ground),green(invild extra ground),blue(invild extra ground),black gnd,white,orange,gold(extra gnd) and now you cut the red wire, you will find two wires.so you refix the main red wire pin no-1 of connector and red gnd pin no-6,green main wire pin no-2 and green gnd pin no-7,main blue wire pin no-3 and blue gnd pin no-8.check for the horizental sync and vertical sync wire you should go in main pcb which invild the other connector. there is present in print, h- sync(two wire of h- sync main wire in pin no-13 and other pin no-5) and ver.-sync wire in pin no-14.first you will check the whose h-sync and vert-sync in color and now finally other wires will fix any pin of connector.
Posted on Apr 24, 2008
SOURCE: samsung syncmaster 910mp TV connection
I believe you are describing this connector adapter.
http://www.thesource.ca/estore/ catalog number 2780265
Posted on Mar 06, 2009
  • 16 Answers
SOURCE: i have a samsung lcd-tft monitor (syncmaster
call on 01122222222 and take the number or address form yellow pages
Posted on Dec 22, 2009
  • 109 Answers
SOURCE: VGA connector wiring detail
Pink - red input - pin 1 green - green input - pin 2 blue - blue input - pin 3 ground shield wire - pin 6,7,8 and 10 black - ddc 5v - pin 9 violet - screen raster - pin 11 white - data or sda - pin 12 orange - clock or scl - pin 15 yellow - vertical signal - pin 14 clear - horizontal signal - pin 13
Posted on May 17, 2010
  • 324 Answers
SOURCE: When I open the Monitor
It sounds like you are connecting with the power on. NEVER do this!
Shut off your computer AND your monitor. When both are off, THEN connect your cable.
Then you can turn the PC and monitor on (the proven old school way is to turn on monitor first, then PC)
If nothing was damaged from connecting them "live", you should be OK.
Posted on Feb 10, 2011
Everything is locked
Try hold down menu button 10 seconds...
Jan 10, 2014 | Samsung SyncMaster 275T+ 27" Wide Format...
Samsung syncmaster 2033sw monitor, till now i was using a vga cable for the display, but recently i bought a dvi cable and connected it. but its not detecting the display of dvi cable. if i remove the vga...
LCD Monitors having multiple inputs have option and option to select and switch between the displays from analog (VGA) or Digital (DVI) inputs. Go to the LCD menu and select input source (DVI)
Hope this helps!
CreativeTECH
Nov 15, 2010 | Samsung Syncmaster 2033SW Monitor
I have a samsung lcd-tft monitor (syncmaster
Nov 03, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Which are the rca plugs on a new tv. (I want to connect a bird nesting box camera)It was easy connecting to my old tv. I have a samsung le32r8 tv now. thanks paul
The RCA plugs are the three (yellow = video, red and white = audio) ports on the TV. Look for "In" to hook up the corresponding cables. I hope this helps.
Oct 26, 2009 | Samsung SyncMaster 275T+ 27" Wide Format...
Screen tearing
You have a high quality monitor with a 5ms response time, so it is not the fault of the monitor which leaves two things.
1) Cable If you are using a VGA (blue) connector I would reccomend upgrading to a DVI or HDMI cable. Digital cables like HDMI and DVI not only look way better than VGA (analog cables) but they deliver quicker response times, and reduce graphical errors. You Should always run a digital output if possible.
2) Software In games in the graphics settings, you might want to enable "verticle sync" this will limit the refreshrate of the game to usually 60 fps, which will reduce and possibly eliminate tearing.
May 24, 2009 | Samsung SyncMaster T260 - flat panel...
Cable color codes for samsung syncmaster 753s
I want to fix new vga connnector on my smsung syncmaster 753s monitor and i am confused with colour coding please help me
Mar 05, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
SyncMaster 510N 15
It might be the connection loose of power cord problem or check your TFT power connector inside the TFT if you can open the TFT screen!!! It may be dry solder….
Other wise go to repairer and do the same….!!!
Dec 06, 2007 | Samsung SyncMaster 510N (Silver) 15 inch...
Samsung SyncMaster 531TFT Monitor Logo
77 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
