RCA D52W19 Flyback Transformer Replacment guide
RCA D52W19 flyback transformer repair guide.
i am confident about changing this myself however i am a little unsure about the H.V. connections or if the FBT holds a charge (if so how to safely remove it)
The picture tube can hold a charge.with a jumper connect one end to the ground wire around the picture tub. attach the other end to a screw driver and push it under the red cap on the picture tub. that will discharge it.. Remove the transformer from the board by disordering all connections. Insert the new fly and solder. from the old transformer follow the two leads on the side to the screen board at the picture tube. one at a time connect the new transformer leads to the socket and board. part number for the FBT 259296 $50.39 from www.the parts store
Posted on Mar 28, 2008
I REPLACED RCA D52W19 CAPACITORS ONE TIME 5 YEARS AGO,AND THE TV CAME ON AND WORKED,IT LASTED 5 YEARS,BUT RECENTLY IT JUST WONT POWER ON,I REPLACED THEM AGAIN BUT IT WONT COME ON AND FLASHES THE POWER...
You have a bad flyback transformer. This is a common problem that eventually goes bad in the ITC 222 chassis. You have to get the model number with the code at the end of it after the /. And sometimes you must have the numbers from off the flyback itself. Try to contact MCM electronics for the flyback at 1-800-543-4330. First see if they can match it with the model number with the code after the /.
Jul 15, 2011 | RCA D52W19 52" Rear Projection Television
Need to buy a flyback transformer where can i find one?
Try website like Tvrepairworld.com have many DLP models tvs flyback transformers.
Jun 23, 2010 | RCA D52W19 52" Rear Projection Television
Is it hard to change the flyback transformer RCA D52W19BYX1
no you can easially do it yourself. You can get the 259296 flyback kit from www.tvrepairworld.com which also has the step by step instructions on CD
May 09, 2010 | RCA D52W19 52" Rear Projection Television
I have hdtv rca d52w19 green power lights shows
Hello Chris this problem is coming from your high voltage circuit which consist of the flyback transformer and the horizontal output circuit, the most common problem when it is acting this way would be bad soldering on the flyback transformer or defective transformer but keep in mind it can also be caused by the horizontal circuit or a faulty lamp as well can cause this problem, what i would recommend is to have a tech come out to service your tv set this should not be an expensive repair since most of the time it is just bad soldering on the flyback thank you hope this helps.
Aug 27, 2009 | RCA D52W19 52" Rear Projection Television
Need to know how to install a flyback in 2004 52 in RCA tv.
First and foremost, disconnect the power cord from the mains.
Next, after having removed the back cover from the set, discharge the tubes' residual high-voltage to ground using a suitable tool.
Access to the transformer is pretty much staightforward here.
A few hardware removals and you can then get to the board and transformer..
Mark, then remove all leads that go to the unit.
INstallation is the reverse of removal.
Be sure to replace the driver device, just to be certain...accordianman
Dec 12, 2008 | RCA D52W19 52" Rear Projection Television
D52W19 Screen Flicker
Go back to FBT check and make sure your high voltage wirer is in good.
Sep 18, 2008 | RCA D52W19 52" Rear Projection Television
This transformer does not come with the hv lead,if the arch is coming from the side of the transformer,cut the side of the plug were it goes into the transformer and the lead will come out,there is no voltage stored on the hv lead after the set is unpluged for a few min.,the transformer you can get at any rca repair center.
Mar 21, 2008 | RCA D52W19 52" Rear Projection Television
RCA P52937 Flyback Transformer question
The lead going from the flyback to that other device is a voltage divider or splitter as they're incorrectly referred to... To remove the leads press down firmly, twist and then pull up...
Bill
Nov 21, 2007 | RCA P52937 52" Rear Projection Television
FLYBACK TRANSFORMER
part # if there is silver face part # 269296 if not part # 270125
Oct 29, 2007 | RCA D52W19 52" Rear Projection Television
Televison & Video Logo
958 people viewed this question
Top Televison & Video Experts
Electro Med Services...
