Question about HP 610 Color Copier
My HP 610 says to replace black pentagon.
What does this mean?
  • Paul82504 Aug 13, 2008
    I have the same "bad pentagon" on my HP 610. I replaced the Black cartridge first, that didn't work. Then ordered and replaced the Black printhead and that didn't work either. Any other help would be appreciated.
    Paul
The cartridge is fine. The printhead needs replacing.
Posted on Mar 27, 2008
    President:
  • 2,072 Answers
Your black cartridge needs to be replaced.
Posted on Mar 21, 2008
Hp 610
expired cartidges are not the problem. the problem comes form the ink. get a peice of tissue, place ink on tissue then remove. If black you should see a black line on tissue. same for color, there should be 3 lines on paper, Y,Cy(blue), MGT (Red)
Sep 05, 2012 | HP 610 Color Copier
How to find a user guide for a Binatone big button 610
Visit the site below (copy and past into web browser)........do not forget to say thanks if it works
http://www.binatonetelecom.com/products/corded-phones/caprice-610
Aug 05, 2011 | Lands Phones
How to load the ink cartridge
Replacing the print cartridges
  1. Make sure the HP all-in-one is on. WARNING: If the HP all-in-one is off when the print-carriage access door is lifted to access the print cartridges, the HP all-in-one will not release the cartridges for changing. Damage may occur to the HP all-in-one if the print cartridges are not docked safely on the right side when you try to remove them.
  2. Open the print-carriage access door by lifting from the front center of the device, until the door locks into place. The print carriage is on the far right side of the HP all-in-one. c00228292.jpg 1 - Print carriage access door 2 - Print carriage
  3. When the print carriage is idle and silent, press down on the end of each cartridge to snap it out of the carriage. If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. If replacing the black or photo cartridge, remove the print cartridge from the slot on the right. c00228293.jpg 1 - Print cartridge slot for the tri-color print cartridge 2 - Print cartridge slot for the black and photo print
  4. Gently pull the print cartridge toward you, out of its slot.
  5. If removing the black print cartridge to install the photo or gray photo print cartridge, store the black print cartridge in the print cartridge protector.
  6. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections. c00228294.jpg 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape c00228295.jpg
  7. Slide the new print cartridge forward into the empty slot. Push the print cartridge forward until it clicks into place. If the print cartridge you are installing has a white triangle on its label, slide the print cartridge into the slot on the left. The label for the slot is green with a solid white triangle on it. If the print cartridge you are installing has a white square or a white pentagon on its label, slide the print cartridge into the slot on the right. The label for the slot is black with a solid white square and a solid white pentagon on it. c00228296.jpg
Jan 14, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Says has bad black printhead..need to replace pentagon? what does this mean...
Second print head from the left
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpa02107&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=64986
Follow these instructions carefully. There may be more than one faulty print head.
Nov 28, 2009 | HP OfficeJet D135 All-In-One InkJet...
Officejet d135 says bad black printhead- Replace the pentagon --
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
Aug 26, 2009 | HP OfficeJet D135 All-In-One InkJet...
Hp 7110 Printer erro
I'm not sure you specified the correct printer. The 7110 printhead is not pentagonal. Is your printer the 7110 all-in-one?
Jun 19, 2009 | HP OfficeJet 7110 All-In-One Thermal...
HP Office Jet 7110 All-in-One
Here is a copy of the manual
See page 58 on how to calbrate and test the print heads. If that doesn't work replace the black print head.
Sep 03, 2008 | HP OfficeJet 7110 All-In-One Thermal...
HP 610 Color Copier Logo
345 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
