Question about Plantronics Explorer 320 Headset
Headset for NEC phone
Hello!
I have a NEC DSX22B phone system & I purchase a Plantronics T100 headphones and there is no sound.
PLUG THE DAMN THING IN
Posted on Jul 28, 2008
  • Panda Broad Oct 15, 2014
    I did... it seems to be charged but can't hear anything :)
SOURCE:
How do I connect phone to plantronics
hi June,
I assume you are using a Plantronics wireless headphone? ensure your phone is on and Bluetooth is switched on in your phone settings.
hold the button on the headphone until the light starts flashing, if this does not happen ensure the headphone is charged. in Bluetooth options on your phone ensure your phone is set to "can be seen by other devices" and then use "scan devices" to find your headphone, if you see Plantronics in the list select it and press "pairing" this will then connect the headset to the phone. once paired, everytime your headset is on and Bluetooth is on, you need to just press the button on the headset and it will automatically connect to your phone.(as long as the headset name is not deleted from the Bluetooth list)
If your phone does not show in the headset in the Bluetooth list, keep the phone scanning and press the button on the headset to start the light flashing this is now causing the headset to search for the phone. once the headset shows in the phone list do as above.
I hope this was useful.
Nov 03, 2014 | Plantronics Audio Players & Recorders
SOUND IN ONE EAR PEIXE
Of course, you know that your phone has to support A2DP in order to get stereo sound. If that aspect is okay, perform a system reset: While plugging in the AC charger, hold the power/pair button. The headphones will show a solid red or blue light when they have been successfully reset. If it's still giving you problems, contact Plantronics at 800-544-4660 x5 x5538 for warranty service.
Good luck from Headsets Direct!
Jul 24, 2011 | Plantronics Backbeat 903 Bluetooth...
Hi, i got my Plantronics BB903+ today, i test everthing out; sound system good, mic good but the range is less than 10 ft. In the hand book it say 33 ft. Anyone know how to fix this problem?
The length is 33 feet or 10 meters. Try putting your phone in your pocket when using the headset. There are some things that can cause interference in reception.
Apr 14, 2011 | Plantronics Backbeat 903 Bluetooth...
I just purchased Plantronics BackBeat 906 and am receiving sound only from one earpiece. Is there a setting that I am not aware of that could be causing this problem?
I would try the reset option listed in Plantronics user guide. Here are the steps for the reset and I will include the link to the user guide also.
Instructions to Perform a system reset:
Plantronics Backbeat User's Guide
Jan 28, 2011 | Plantronics Backbeat 903 Bluetooth...
Technical spec for plantronics C60 headset
Plantronics CS60
Type: Headphone
Acoustic Seal: Sealed/Closed/Sound Canceling
Headphone Frequency Response: Hz
Headphone Sensitivty: 14 dB/1mW dB/1mW
Wireless Technology: Infrared
Battery Time: 9 hours hours
Battery Type: Alkaline
Radio Frequency Range: 1.8GHz
Transmission Range: 100 m.
Compliant Standards: TCO '07
Jan 16, 2009 | Plantronics CS60 Professional Headset
Plantronics Practica T100
It's probably faulty. I had the same problem and had to have it replaced because the headphones come with the phone so they couldnt just replace one or the other.
Dec 17, 2008 | Plantronics Practica T100 Corded Phone
Headset for NEC Dterm80
Do a search for a plantronics headset. All of theirs work well with NEC
Nov 11, 2008 | NEC Dterm DTP 16D-1 Corded Phone
NEC DTerm80 phone
I have the 8 button phone and if you hook up your headset the right way you just have to press the line/feature access key all the way to the right instead of picking up the receiver. Keep the headset on all the time and just press that button to answer or hang up the calls. It works great! ( I have the Dterm80 telephone)
Jun 30, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Connect/Program Headset
Sure you can do it. as long as the headset has a plug for the handset your fine. Plug it in and you will have to pick up and hang up the handset as needed. The headset key eliminates you having to pick up and hang up the handset to answer with the headset.
Feb 21, 2008 | NEC DTU 8-1 Corded Phone
Pairing my bluetooth
pair my wireless s9 headphones to my blackberry
Jan 20, 2008 | Plantronics 510SL Headset Voyager...
Plantronics Explorer 320 Headset Logo
211 people viewed this question
Top Plantronics Radio Communications Experts
Anthony Ward
Anthony Ward
gggg
edward80
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
