Question about Sewing Machines
Elna 6000 sewing machine
Machine is stuck in reverse after sewing a few feet of straight stitching. Machine has been carefully packed in original box for past 5 years.
What's up with this?
SOURCE:
SOURCE: Sewing machine straight stitch is not straight
Hey. It's full out possible that you have it on the right setting...but concider this - the switcher inside the sewing machine could be broken (ie. It's moving to different stitches - but not the one you have the outside set for)
It happened to me (pc o crap singer model)
Posted on Jan 24, 2008
  • 57 Answers
SOURCE: How do I change the stiches?
You can do all of these stitches by using different combinations of your stitch selector, stitch width and stitch feed knobs, for instance, on the panel I can see on your machine:
http://www.jo-ann.com/joann/product/images/52659.jsp?CATID=cat3122&PRODID=prd11333
Stitches 1, 2 & 3 are straight stitches, centered, left and right. Really basic stuff, not different stitches at all. 4,5,6,7 & 8 are zig-zag stitches of different widths. 9 is the widest zig-zag (no. 8) on a finer stitch length, etc...
I think you should try and get an instruction manual for your machine. After a lengthy search of my usual manual sources, I've determined that that this may not be so easy. I think you should contact White on their 800 number and let them try and help you... 1-800-331-3164.
If you found this helpful, please vote generously as I receive nothing other than acknowledgement for my time.
Posted on Mar 08, 2008
SewTechWayne
  • 186 Answers
SOURCE: The Reverse stitch button
The feed mechanism needs to be oiled. Take off the bottom cover and look for any place where two parts move against each other. Some binds can be very difficult to remove. Try spraying everything with a light weight oil (I like Tri-Flow) and let them soak over night. Then manually try to move the feed dogs with your hand. Hopefully it will break loose.
Posted on Jan 30, 2009
  • 136 Answers
SOURCE: Elna machanical sewing machine
50 year old elnas made stitches by cams. look to see if the machine has a cam in it. you can see this by opening lid on top of machine. cams are black with red or white showing the pattern of the cam. could also have broken cam stack gear. That would require technician with elna experience
Posted on Jul 12, 2009
SOURCE: in need of owner manual for the 704 elna seger
try their website
Posted on Sep 18, 2009
My Janome JL250 is stuck in reverse
Probably the reverse mechanism has stuck. Only suggestion may be working the lever manually to see if it frees up. Other than that, it would need service or replacement.
Jul 15, 2016 | Sewing Machines
Why is my Janome Mystyle 20 stuck on reverse?
It may be in the buttonhole mode, change the stitch selector to straight stitch.
Jul 16, 2014 | Janome Sewing Machines
My euro-pro 7130 seems to be stuck in reverse. I cannot make it sew forward
This can be caused by a few things. Check the stitch setting near zero can cause this. Next check to make sure it is on straight stitch. If that doesn't work the reverse mechanism may need oiled. If this is a computerized machine you may need a repair shop to do it. You do not want oil on the electronic boards.
Oct 24, 2013 | Euro-Pro Sewing Machines
My brother ce8080prw machine will not stitch in reverse and is stuck in abasting stitch. how do I reset?
My machine was also not sewing in reverse and stuck in a basting stitch. It was a simple fix. Unscrew the plate and remove any pins stuck in there. All fixed
Nov 04, 2012 | Brother SE-270D Computerized Sewing...
Where can i get a presser foot for a Janome 1017
Sep 18, 2012 | Janome Harmony 1017 Sewing Machine
Model 4423 singer stuck in reverse
Solution: Turn off machine. Turn stitch dial until you hear click on each stitch shown on dial. Set to straight stitch then and set stitch width to 6. try machine again being careful to put light force on the foot pedal so your not going full throttle. This is how I "de-confused" my Singer Heavy Duty 4423 when it got stuck on reverse. Hope this helps!
Jimmy
Mar 20, 2012 | Singer Sewing Machines
Viking 2000 6430? sewing machine, only sews in reverse.
Your stitch length dial is stuck. Your machine is in need of oil. If you open the back of your machine and see the bit that moves when you turn you stitch length dial. oil that bit and warm it with your hair dryer. It should become loose. It take a bit of warming and working the oil into the machine. You have to repeat this process a few times.
I do have the service manual at [email protected]
Jan 25, 2010 | Husqvarna Sewing Machines
Reverse stitching on a singer 514, HELP!
In the center of the stitch length knob (at the right side of the machine) is a button. You would push that button in to get the machine to reverse.
May 08, 2009 | Singer 7442 Mechanical Sewing Machine
Why is my screen showing the 'bobbin threading' icon??
Perhaps the bobbin winding mechanism is stuck. Probably needs service.
Also, check the bobbin and bobbin case. Perhaps there is some thread stuck or it is not securely threaded through the tensioner.
Mar 31, 2017 | Euro-Pro 9125 Computerized Sewing Machine
Sewing Machines Logo
245 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
