If it s a new scanner, have you unlock the transport latch at the bottom? It's a protection latch that keeps the mechanical in place when the unit is being transported or new from the box.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Comments:
Mar 24, 2008
- Hi again,
Any development(s) with your scanner?
Apr 03, 2008
- Hi again,
My apologies for the late reply and postback.
Most scanners of this design uses a proprietary glass-less transparency
scanning - the transparency tray is a completely independent scan bed.
Transparent originals are scanned using the tray that slides in and out
of the scanner. The glass-plate in the transparency tray would at times require cleaning. In some cases, the tray does not slide in properly, you need to double check that it latches back in so that internal sensors would know that it is in (and properly). You may need to do this a couple of times to ensure.
Other than this, it would also be possible that the sensors are not detecting that the try is back in properly. It may be the sensors themselves.
Pls post back for any developments (or even the lack of it)
Again, good luck and kind regards.
Popular Solutions for Agfa DuoScan Flatbed Scanner
Agfa Duoscan powers up then runs through the initiation sequence over and over and never stops....
(More)
Agfa Duoscan powers up then runs through the initiation sequence over and over and never stops. Don't know what the problem could be.
Hi Laura Im thinking of buying an agfa duoscan T1200 for my Intel MacBook but know that I might come...
(More)
Hi Laura Im thinking of buying an agfa duoscan T1200 for my Intel MacBook but know that I might come up against some problems. Did you manage to sort out your scanner eventually? If so can I ask how please? My email is info@edgold.co.uk Many thanks Ed www.edgold.co.uk
hy! i change the lamp but the hours from the last lamp are still there and the projector tells me i...
(More)
hy! i change the lamp but the hours from the last lamp are still there and the projector tells me i must to replace tha lamp! with my new lamp the buyld is perfect but the projector turn it off just so! how i can reset the hours from my old lamp? thank you!
