Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Agitator My agitator is not moving during the wash cycle and therefore, not moving the clothes down/through out the wash cycle. I thought it should be moving...am I right? If so, can this be a fix it yourself problem? JAM
  • 1 more comment
  • strongrthnu Mar 24, 2008
    Same. It will not agitate the cloths.
  • leogirl76 Apr 03, 2008
    Originally the agitator worked fine for the first 4-5 minutes of the wash cycle, then it would start clicking and stop agitating, but would resume as usual after that part of the cycle was done. Now it has stopped completely and won't move at all during the wash cycle, but picks up with the drain and rinse like usual.
  • carolfly83 Apr 16, 2008
    I have a Whirlpool Ultimate care II Mod. # LSQ8243HQO We just bought it from another Owner and the upper agitator isnt spinning to push the clothes down. Also when I take out the Fabric softner dispencer the only thing under it is an agitator cap seal. Am I missing a part in between? The agitator is Wobbley and I can spin it by Hand, but when clothes are in it, it is stationary. Is there an easy fix? and a how to guide for a Girl!! LOL.
    Thanks
    Carolyn
My agitator was broken to and it was dog clips inside, remove the dispenser and undo the nut inside and there are four dog clips, check to see if those are broken and replace and it should work, if not its another problem.
Posted on Apr 12, 2008
    Sergeant:
  • 351 Answers
Check the drive coupling between the motor and gearbox,does it make a clicking sound does it spin or just pump the water out only.
Posted on Mar 26, 2008
How do i replace the agitator in my old heavy duty whirlpool washing machone?
Hello.
The Whirlpool Ultimate Care II washing machine is atop-loading clothes washer. The washer has several cycles to choose from,including cycles for washing normal clothes, permanent press items, delicateand items marked "Hand Wash." To do its job, thewashing machine relies on an agitator, located in the center of the wash tub.The agitator rotates during the wash cycle, moving the clothes around the washtub so that they are cleaned equally. If the agitator is broken, it will notsufficiently agitate the clothes and must be replaced. ·1 Unplug the washing machine from the wall outlet or turn off the power supplyin your service panel. · 2 Open thewashing machine lid and remove any clothes remaining inside. · 3 Remove thefabric softener cup by squeezing the bottom lip of the cup and lifting itstraight off. · 4 Pry theagitator cap off of the top of the agitator with a flat-head screwdriver. · 5 Remove thebolt at the bottom of the agitator, using the socket wrench with extension, andthen remove the agitator from the washing machine. Tip the agitator to removethe bolt and washer. · 6 Install thenew agitator onto the drive shaft. · 7 Secure thenew agitator with the bolt that you originally removed. · 8 Press theagitator cap and fabric softener cup back into position on top of the newagitator. · 9 Restore powerto the washing machine to complete the repair.
Thanks.
Sep 07, 2011 | Whirlpool Washing Machines
It leaves soap on the clothes after it goes thru the cycle and I noticed that the top part of the agitator doesn't move hardly. The washers model # is LSR8233JQO and the serial # is CK4729250, Type 111.
The agitator dogs (part # 80040) that grip and turn the top agitator to push the clothes into the bottom agitator during the wash cycle are worn and must be replaced. It costs about $5 and replacing it is an easy task to do.
Disconnect the power to the washer. Open the lid and remove the agitator cap by prying it with a flat-bladed screwdriver off the agitator top. Remove the 7/16 inch stud and seal holding the agitator to the shaft using a socket wrench with extension.
Lift the agitator off the shaft and pull the top agitator off the bottom agitator. Remove the cam that holds the agitator dogs from the top agitator.
Lay the cam upside down and install the agitator dogs on the slots. Hold the cam with the newly installed agitator dogs on one hand and the top agitator upside down on the other. Slide the cam up into the top agitator and turn the assembly in the upright position.
Align the cam and bottom agitator tabs and cut-outs and place the top agitator with the cam over the bottom agitator. Place the agitator assembly on the shaft and rotate it until the grooves match. Push the agitator down and reinstall the stud and seal. Do not over tighten the stud or the agitator will not spin properly.
Feb 10, 2010 | Dryers
The agitator moves very slowly so clothes aren't washed
INSIDE THE AGITATOR IS A PLASTIC GEAR AND SOME DOG EARS WHICH GRAB THE AGITATOR,,,USUALLY ITS THAT,,CALL YOUR LOCAL APPLIANCE PARTS STORE,TELL THEM THE BRAND AND THEY WILL KNOW JUST WHAT YOUR TALKING ABOUT AND YOU NEED,,ITS A SIMPLE FIX,,NO NEED FOR TECHNICIAN,,
Sep 08, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Agitator seems to bind up when in wash and rinse cycle
you need a new coupling between the motor and the transmission.
Mar 07, 2009 | Washing Machines
A piece of clothing is stuck underneath the agitator! It won't turn during the wash cycle. The spin cycle still works. How do I disconnect the agitator, so I can remove the piece of clothing?
remove the agitator by first taking off the softner dispenser at the top of the agitator and then look down inside. inside you will see a half inch head bold. remove bolt and lift agitator out.
Jan 27, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Load squeal when it in the agitation cycle.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
for detailed help with diagrams and step by step instructions click the link http://www.applianceaid.com/washerspinnoise.html
Dec 29, 2008 | Admiral AW22 Top Load Washer
My whirlpool top loader won't agitate.
Peace Friend,
ngfam1 At your service!
You did nothing to cause this! Things wear out! So is life!
Sounds like the coupling between the transmission and the agitator is broken!
How old is the washer?Sounds old!
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
Only a trained laundry tech can make the electronic diagnoses.
Below I referred you to a great service nation wide!
If none of these tasks remedy the problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
I
Aug 31, 2008 | Washing Machines
Sounds like what you have is a dual agitator, bottom moves back and forth in wash, top acts like a screw pulling clothes down to the bottom of the tub. If so, the agitator dogs are bad, to get to them, pop off the cap on top of the agitator, then reach down inside and pull up a cap in there, then use a socket (I forget the size) and a long extension to unbolt the agitator and pull it out, the dogs are located between the top and bottom sections. They are slightly curved rubbery plastic pieces, 4 total. About an 1 1/2" or so long, one end fits into a hole on the inner part of the agitator and the other end is ribbed to catch the outer part of the agitator during the wash stroke.
Nov 08, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Just spins during the wash cycle
Sounds like the agitator got dislogged during moving. In some machines the design allows for the agitator to move up and down alittle too much. Try this and this is only a guess. With the machine empty push down firmly on the agitator and move it back and forth as you do. You might hear a little "pop". If it does, try running the machine again. If it works problem solved, if not tell what happened.
Jul 17, 2007 | Whirlpool GSC9455 Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
99 people viewed this question
Dan Webster
Dan Webster
Sal De
