Question about Logitech Z-5500 Computer Speakers
Lip Sync issues with Logitech Z-5500 and PS3
Hi, we have our new Logitech Z-5500 speakers connected to the PS3 via digital optical cable and it works a treat for approx 20 mins before there is a steady increase in the amount that the lip sync is out. Both the Speakers and the PS3 are well ventilated. Can anyone offer advice?
  • azitaman Jan 13, 2009
    my problem is slightly ifferent none of my streaming audio out of mmy pc throught the ps3 works at all; lip sync all the way
    i have tried direct connect to tv and also through my denoon reciever
    Prodigy:
    An expert who has answered 500 questions.
  • 620 Answers
Hello there
First things First:
1) change the digital opt, cable, for another with cooper conduction. **
2) check connection again on low volume.
good luck
Posted on Mar 28, 2008
SOURCE:
How to connect speakers logitech z 5500 to the TV Samsung UN32F5500 32-Inch 1080p 60Hz Slim Smart LED
Hello there!
I have seen manuals of both the systems. You have two options to connect Logitech z5500 speakers to Samsung UN32F5500 TV.
1. With Optical Audio Cable.
2. Stereo Ear Phone Connection.
Simply plug in Green earphone cable of Logitech Speakers to Green Audio out Jack described on Page 7 of the TV manual. If you are using stereo EP you may not experience 5.1sound separation. And it is also mentioned that you should not use other two audio cables of the tri-EP-cable provided with Logitech speakers.
Have a nice day!
Mar 12, 2014 | Audio Players & Recorders
How do i connect my technics sh-dv290 to my tv and what leads do i need
i am trying to do same thing - i suggest connect ps3 via optical cable to hi fi red/ white cables via a optical/ rca adaptor, the ps3 is connected to tv via hdmi so play dvd via ps3 sound will play through hi fi - but remember dont need the yellow dvd cable from hifi dvd player to tv any more as you will be using the ps3 as a dvd player instead
Jan 02, 2013 | Technics SC-DV290 System
Only the center speaker work well now.
I have the same problem but its all the speakers, move the control pannal around and it should work. If yours is broken like mine call Logitech and they will help you.
Feb 08, 2010 | Logitech Z-5500 Computer Speakers
The right speakers logitech Z 5500 do not work
try buying a new optical cable or change some settings on your tv.
Feb 04, 2010 | Logitech Z-5500 Computer Speakers
Im trying to connect my Logitech X-530 to my PS3.
You need a digital decoder that is compatible with the ps3 and the speakers.
You would then run a digital optical link from the ps3 to the decoder and the normal speaker cables from the decoder to the speakers.
Decoders can be quite expensive and it can sometimes be easier to buy a set of 5.1s with the decoder either built in or included with the package.
Apr 10, 2009 | Logitech X-530 Computer Speakers
Logitech Z-5500 Work Just with Optical And Coaxial cable
i think its something to do with your operating system, since you have said its works for few min.
Feb 20, 2009 | Logitech Z-5500 Computer Speakers
Hook up z-5500 suround to a tv
The Sony has (http://b2b.sony.com/Solutions/product/KDL-46S4100)
Digital Audio Output(s): 1 (Rear) Optical Digital Output
The Logitech speakers have (http://www.logitech.com/index.cfm/speakers_audio/home_pc_speakers/devices/224&cl=GB,EN)
Source Inputs:
Digital optical for DVD or CD players, PlayStation®2, Xbox®**
To do this, you need a Digital optical cable--Search Googe for this: Cables Unlimited Pro A/V Series - Digital Audio Cable (optical) - 6 ft
Should work.
Oct 22, 2008 | Audio Players & Recorders
Centre Speaker No Sound
i can think of two things., you may need to do the update on your sound card and computer and make sure you have the correct codec's installed or also you may need to go to the web site of the makers of your logitech speakers and see if they have a common solution for this problem...... i also wonder if you should bypass the sound card and directly connect your speaker system to the out put port on your computer ..... give it a try what can it hurt .... if all else fails maybe there is a faulty wire in the speaker system ....... ahy ?
Jul 17, 2008 | Logitech Z-5500 Computer Speakers
Logitech Z-5500, no sound coming out
Hi there, Mr Dan
Happy Holidays
well, you can change, the coaxial cable for another optical? is better, if you got an optical input. or optical output to input on your SPK. that should work.try the test with a movie on.or sound continue.
Dec 18, 2007 | Audio Players & Recorders
Please help with getting 5.1 sound from my TV!
You must run a Digital Optical cable from your PS3 to your reciever. Then press your function button on your recievers remote until you see SAT/CABLE on your recievers display. Next go to your PS3 settings and go to Sound settings, then Audio Output settings, and select Digital out (OPTICAL) then your done. This is the only way to get true digital sound from your PS3 to your reciever.
Oct 01, 2007 | Sony DAV-HDX500 System
Logitech Z-5500 Computer Speakers Logo
810 people viewed this question
Top Logitech Audio Players & Recorders Experts
Ekse
Michial Gueffroy
Paul
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
