Question about Vacuums
Dirt Devil vacuum sucks... figuratively
My dirt devil swivel glide vision never works correctly. I've had to use the extension to vaccuum my entire apartment because the main unit doesn't pick anything up. Please help! I have visitors coming in an hour.
  • 126 Answers
Well, I guess your visitors have come and gone, but the vacuum remains the same. It sounds like you have a broken or worn belt. The belt should be changed once a year (approx) and can break if something is picked up that jams the brush. It is also possible that you have something obstructing the vacuum inlet at the brush housing.
If the belt is worn, it can still look o.k., but won't have the tension to turn the roller when it engages the carpet. I suspect the belt is your trouble.
Posted on Mar 30, 2008
I have a dirt devil vision wide glide, 086700, made may 2006. I found 2 places with reasonable prices and the same excellent explosion diagrams. www.ereplacementparts.com and www.vacpartswarehouse.com hope...
Do you know how to get the height adjustment knob to release the wheel height? Its stuck on high carpet? The knob moves but doesn't change the position?? Identical Vacuum.
Feb 27, 2011 | Dirt Devil M086700 Vision Bagless Upright...
My dirt devil bagged upright(swivel glide) wont turn on..light on
  • its clogged that is what the light shows is that if your vacuum is clogged then that light will come on and it will shut off, i have the same vacuum and mine does not come on cause its not clogged
Mar 09, 2010 | Dirt Devil SwivelGlide Bagged Upright...
How do I repalce the belt on Dirt Devil Swivel Glide upright vac?
Four screws hold the bottom plate in place. Turn the vac upside down and remove the screws that hold the cover(bottom plate) over the brush roll in place. Remove the plate and you are there.
Oct 22, 2009 | Dirt Devil M088910 Swivel Glide Vision...
HOW DO YOU CHANGE THE BELT ON A DIRT DEVIL VISION VACUUM CLEANER?
With the vacuum unplugged, turn the machine beater bar side up. Locate the clips or screws that hold the plate over the beater bar and remove the plate. The beater bar sits in sockets just inside. Be careful in removing it; take your time and note how it comes out...this will make reassembly easier. Clean the debris while you have tha bar off and remove any debris thet you see in the vacuum hose area behind the bar....The new belt slips over the motor shaft behind the beater bar (further up in the cavity behind the b/b), then you slip it back onto the beater bar as you place the bar back nto the sockets. Test your work by revolving the bar a bit to make sure that everything is back in place. Replace the plate.
Regards,
--W/D--
Jul 12, 2009 | Dirt Devil M088910 Swivel Glide Vision...
Roller on my dirt devil vision not spinning
how do you replace a belt no.5 on a dirt devil vision.
Jan 31, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
Dirt Devil Vision bagless not working
Check the dirt cup filter. remove the dirt cup and check for proper suction. if you have good suction, check your belt
Jan 24, 2009 | Dirt Devil Featherlight Bagless Upright...
Vacuums Logo
93 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
