Question about Panasonic PV-GS180 Mini DV Digital Camcorder
Dropped camera dear sirs, i dropped my PVGS 180 camera this morning the viewfinder is not showing, it looks cracked, it works in playback mode, but its does not record. can it be repaired, I have a friend coming to new york next week where can it be dropped off and what would be the estimated cost for repairs, i live in the caribbean adrian boodan [email protected]
Try throwing it away, it might cost you more to fix than replace, buy a sony next time
Posted on Apr 05, 2008
SOURCE:
Canon rebel xt 1. image looks blury in eye
1. The viewfinder's diopter is probably out of focus (doesn't affect Auto Focus of photos). There's a dial and a +/- symbol next to the viewfinder. Turn the dial till you can see clearly through it. Alternative reason: The glass in the viewfinder is dirty/foggy. Use camera cleaning solution (a drop) on a cotton bud to clean it.
2. Malfunction needs Canon Service Centre to take a look at.
Dec 25, 2009 | Canon Rebel XT / EOS 350D Digital Camera
CANON POWERSHOT A640 LCD VIEWFINDER STOPPED WORKING
nice camera ... the button at the bottom left is marked Disp ... each time you push that button it will change the display mode ... there are three modes .. OFF, ON , and NIGHT ... night turns down the brightness a bit ... push the button several times until you get the display you want ..
Oct 06, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Large viewfinder only works when reversed &
dear ... there is an option in the menu .....
of hvr A1 TO KEEP THE VIEW finder.... ON..
write nw
ur camcorder is in auto mode ,wht happen in auto mode is ,view finder gets ON only when u turn the LCD pannel ...
so need nt worry change ur MENU option OF view finder from AUTO to ON,......
Jul 13, 2009 | Sony HVR-A1E HDV Digital Camcorder
Only works in playback mode
If when switching from playback to LCD then Viewfinder and no preview display is visible in either LCD nor viewfinder then the switch is not switching. If the red battery light is on try new batteries as some functions are unavailable with low battery power or connect the AC adaptor to see if power is a problem. Does the menu work? Does the zoom function move the lens? If all is functional in the playback mode then the switch may not be making contact internally. Carefully apply pressure to the switch while slowly moving it between all 3 positions while seeing if any display changes both through the viewfinder and the LCD. If you are technically confident you can open the camera case and try bridging the switch poles with a small screw driver to see if the switch is defective or misaligned. EBay has had DiMAGE cameras listed for 'parts only' very cheap but the Z3 would not merit the cost of a camera repair shop. My last successful bid for a Z6 was $200 2 years ago. My first repair on a digital camera was pretty simple since inside the case is a single printed circuit board with little ribbon connectors that can be reseated at ZIF type connectors. Just be careful, slow and keep track of the screws and parts orientation. Any friend who fixes laptops can help you but a shop will cost you more than the camera is worth. Good luck.
Oct 15, 2008 | Konica Minolta DiMAGE Z3 Digital Camera
Blue screen on playback on Sony DCR-HC40
You can see an image in a camcorder viewfinder any time the camera's actually on in record mode, whether or not the camcorder is actually recording. So that's no guarantee.
Assuming the obvious (you have the right kind of tapes, they're not in write-protect mode, you rewind before playing, etc). I recommend that you borrow a tape of the same kind from someone else and check it on playback in your camcorder. This should lead you know understand if you have a playback problem or a recording problem.
Jan 20, 2008 | Video Cameras
Mode switch
my dimage z5 and see alot of problems on ebay the net ....anyways being a tech for 25 years the cover came right off and u can see the switch is surface mounted. there is supposed to be a plastic lever coming out to manually engage to outer switch but missing ...upon closer inspection i could see alot busted up chards of small plastic ...the insideof the switch was completely ruined for bits where falling out...its just stuck in main veiwfinder. cant find the part itself anywhere on net. heard sony bought out minolta. my only bet is buy a broken camera with different prob. on ebay. Larry
Jan 26, 2007 | Konica Minolta DiMAGE Z1 Digital Camera
Distorted Viewfinder Only In PIcture Mode
Yes, You are correct, it does not seem to be problem with the CCD. Insted it seems to be with shutter control or apparture control mechanism of the camera. Normaly there is one single cable carring signal to the shutter blade mechanism and the diaphram control. If this cable is damaged it shows the same symptoms as you have described in your mail. Get in touch with an expert camera repairer.
Aug 17, 2006 | Sony Cyber-Shot DSC-F717 Digital Camera
LCD Monitor on ,and the Electronic Viewfinder turned off
If you turn on the back LCD, the electronic viewfinder will remain on while in a shooting mode. There is no setting on the camera to use only the back LCD monitor while shooting. If you playback images in the Play mode, only the LCD monitor will turn on. However, if you press the Monitor button while in the Play mode, than the back LCD monitor will turn off. The image will display only in the viewfinder LCD.
Sep 04, 2005 | Olympus Camedia C-730 Digital Camera
Panasonic PV-GS180 Mini DV Digital Camcorder Logo
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
