Tv stays in standby mode all the time - Televison & Video
  • Anonymous Feb 01, 2009
    bloody hell the TV is new.................
  • tyson_l May 01, 2009
    TV stays on standby.....Purchased the TV one year ago. This is crazy!!
First I am assuming you tried both the remote on and the button on that is on the TV and get the same results. If it's just the remote that is giving you the problem, put in some fresh batteries first and if that doesn't work, order a new remote. If both controls fail to turn the set on, your problem is in the latching network and requires a technician to find out which diode or chip has burned out. It would be on the control logic portion of the circuit board.
Posted on Apr 01, 2008
SOURCE:
Is it normal for an acoustic solution 24" LCD TV to stay for like 10seconds before coming up after switching on from the stand by mode?
10 seconds doesn't seem an excessive amount of time. Standby is supposed to be a power saving mode - the fewer parts of the circuit that are kept in complete readiness for switch on, the less power will be saved.
These days there is much prejudice against using the standby mode and it would be expected designers would respond to this by changing the internal arrangements so standby consumes less power so when the set is switched on it will take time for capacitors to charge and digital computers to fully boot and so forth.
Think of it not so much as a TV but as a computer. A 10 second reboot from the sleep mode wouldn't be so unusual...
If the TV works ok otherwise you probably have no worries...
Sep 06, 2017 | Televison & Video
I got a used LCD1932 Lloyd's TV/Monitor. The top has a standby button, turns it on, but u hit same button to turn it off, it has red standby light that stays on, does that mean it's always on standby
It's normal; if the set do not show a screen at this time. The red light indicates that the set is in standby mode, and it will off, when you hit the standby button again, and the scree will get live.
Oct 15, 2014 | Televison & Video
On standby mode light constantly switching between blue and orange. Why is this?
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Sep 14, 2014 | Televison & Video
Logik TV stuck in standby
if you don't hear a click its the power over switch. on the power board it is a black box. if you have the back off turn the tv on and then out of stand by and flick the black box it will probably turn on.
Feb 25, 2014 | Televison & Video
TV won't turn on. Stays in Standby mode
Someone is going to have to go inside and check voltages and other things --no brand or model is indicated here so this is as much as I can suggest.
Dec 20, 2012 | Televison & Video
My hd4208TIII-PDP WONT COME OUT OF STANDBY MODE
You Need a new Power Supply, part # LJ44-00025A
buy it here for $139 http://www.adc-ast.com/
I have my tv working like new.
If you want this time the power supply last, do not turn off, just press tv/video button to switch input source, let the tv in sleep mode.
Credit: User IMJR
Feb 28, 2009 | SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready...
SHARP 29" TV switching off to Standby
have you tried changing the batteries just to elimate this problem
change them
sometimes if the batteries are low in electronic devies, they send a wek signal to its receiver (your tv),
your tv gets confused and then switches itself to standby
if you have changed the batteries and this problem still persists
it can only then be th PSU or power supply unit, take it to your local tv repair shop of mastercare somewhere like that, its going to be cheaper to get it repaired than replacing the whole tv
PSU'S generally 20 to 50 pounds depending on model
don't deo it yourself though unless you've got a capacitor discharger (or a nice 25KV will be on its way to your body)
hop this helps mate, let me know how you get on
Nov 10, 2007 | Televison & Video
TV Switches itself back to standby mode continuously
if your remote is ok then this is due to power supply failure in your tv. either it is loose in oscillator ckt in switching section or it has failed. if not tech person call tech to fix it. not a major problem.
Oct 07, 2007 | Televison & Video
Televison & Video Logo
469 people viewed this question
Top Televison & Video Experts
Ekse
