If the diagnosis is correct (and I believe it is) your
part number is correct and can be purchased for about $130.00 online or at your local appliance parts retailer. It is very easy to replace.
{{{UNPLUG THE FRIDGE!}}}
Pull the fridge out away from the wall so you can get behind it. As you're looking at the back of the fridge, you'll see a panel at the top left. You can't miss it. It has about 15 screws holding it in place. Remove these (use a 1/4" nut driver or socket) then remove the panel.
Now if you look closely at the board and take note of the connectors, you'll see that it's fool-proof... which means that after you take them off, you can NOT get it wrong when you put them on the new board. <-- Now THAT'S good news, huh?
OK, you'll see 3 connectors on one end of the board and they are all white. You'll see 2 connectors at the opposite end, one is white and the other is blue. Remove the 3 white connectors first, leave the other 2 for last.
Next, look closely at the board again... you'll see 4 white plastic tabs sticking through the board. These are the stand-off clips that hold it in place. Look very closely and you'll see that these clips have a "locking" tab on them. Use the tip of a knife to push the tab in while pulling out on the corresponding section of the board. Do this on all 4 corners and the board is out.
Now you should still have the 2 remaining wire connectors (the blue one and the white one) still on the board, remove them now. Pull out your new board, install the 2 connectors (blue and white) first then mount the new board onto the plastic stand-off clips, then connect your 3 remaining white wires connectors. After that is done, plug in the machine for test. You should hear the compressor start within 5 seconds or so.
When you re-install the aluminum cover, make sure that you connect that "flying" green ground wire to one of the screws used for the panel. It's necessary.
All in all, about a 20 minute job.
Hope this helps!
SG
