Question about Cuisinart 12 Cup Digital Thermal Coffee Maker - BLACK
Long brewing time
I've had my coffeepot for about 1 year -- for the past month or so, it's been taking 30 minutes to brew a pot of coffee. It's also very noisy. Any suggestions?
  • 8,596 Answers
Clean it out with 1/3 caraffe distilled white vinegar and 2/3 caraffe water. Once it is clean, it should take the normal amount of time and will make slightly less noise since it isn't busy steaming off as much water. Also, double-check the filter basket and make sure it is not slowing down the rate of draining coffee.
Posted on Mar 31, 2009
How much apple vinegar do I add to 4oz of water
Hello Linda Mohr,
1/2 White vinegar +1/2 water (wait 30 minutes = success.
This from the HUFFINGTON POST...
Fill the coffee maker's water chamber with equal parts white vinegar and water. Using a paper filter, allow to brew until half the chamber is empty. Turn the coffee maker off and let it sit for 30 minutes, then finish brewing. Rinse the machine by using a new paper filter to brew a pot of clear water.
I would stay away from apples.. grapes,
wine & balsamic vinegars...
I like a strong cup of coffee... but wit a
COFFEE FLAVOR (nothing else).
If you can NOT find WHITE VINEGAR use a commercial
Carnac the Magnificent
Feb 12, 2017 | Coffee Makers & Espresso Machines
Why won't my bunn coffee maker turn on
You should check to insure that the tank inside the machine is full of water. Pour in 1 pot of water at a time until you get water to come out of the brew basket. If you haven't done any internal damage it should be ready to brew a pot of coffee inabout 20 minutes.
Sep 21, 2014 | Bunn 10 Cup Home Coffee Brewer
My kitchenaid coffee maker gives us an "error 2" and will not brew. help!
This problem occurs between 6 months and 1 year of these coffee pots. I have contacted customer service each time this occurs and have received a new coffee pot. Unfortunately, I am calling them again and again because the new coffee pots do not even last their warranty time and the ERR2 light again comes on and ruins my morning. I would not recommend this coffee pot. It is expensive and life time is not long at all. Customer service has been great but how many times do you have to return a coffee pot for Kitchenaid to get the hint that it needs to be fixed. Most consumers will get angry, throw it away and never buy the same one again. So, wake up Kitchenaid and smell the COFFEE!!!!!!!!!!!!!!!!!!!!!!!!! Fix this coffeepot. I am not the only one who has had this problem. Customer service @ 1-800-541-6390 Hope this helps. When they send you a new one they send you free shipping back for the old one and you use the box the new one came in.
Dec 04, 2010 | KitchenAid KCM511 Coffee Maker
My Pot wont brew
mcdevito75 here, Your Mr. Coffee may need cleaning, here"s how, Fill the resovoir with white vinegar, cycle thru the machine 3 times, half way thru the 3rd time stop 1/2 way thru and turn off machine for 30 minutes, then recycle. After that rinse your Mr, Coffeee by cycleing thru fresh water each cycle takes another resovoir of fresh water to get rid of the vinegar. If this is not the problem, maybe the pump is shot. Contact Mr. Coffee by phone or online at Mr. or replace the machine.
Jul 09, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
Kenmore Elite coffee maker Model # 100.9101670A Is this model on a recall? How can I get a manual for it? And what is the filter reset button?
I have a manual with mine and as far as "recall" goes on this model, I've not found anything recalling this particular model...<br /> <br /> The most important thing in the manual, that I have found, is how to clean and change the filter. If all else fails unplug the pot for 10-15 seconds; replug it...this resets it...(if it ever acts up, do this; it helps)<br /> <br /> The filter reset button: Your coffeepot should flash a small message stating: "change filter and clean" To do this you first, turn off the pot, remove filter~(the filter is in a long thin black plastic thing and the filter cover simply snaps and pulls apart to expose the charcoil filter; Remove the Filter, then fill the coffee pot with 7 cups of vinegar plus 7 cups cold water; Place a paper type regular coffee filter in the brew basket, or a thin paper towel works well too~(This traps and holds particles that get trapped inside the pot)<br /> <br /> Before brewing; PLEASE NOTE, brew the first pot of vinegar/water mixture only HALF WAY then TURN OFF and let it sit for a good 15 minutes to soften any deposits...<br /> Turn the pot BACK ON and brew the remaining solution. When brew stops turn OFF coffee pot, empty the solution, and discard the paper filter...<br /> <br /> Refill reservoir with cold water and turn ON; you may want to dump this and refill with more cold water to ensure the vinegar taste/smell is gone...<br /> <br /> Now, wash the brew basket and the glass pot...Open the black skiny Water Filter and replace with a new charcoil filter...Put Filter back in pot...fill brew basket with coffee and brew some mighty fine tasting coffee!!! Hope this helps....Good Luck
Jun 29, 2010 | Coffee Makers & Espresso Machines
My Survival Guide To The Dreaded Err2 Disaster
An ERR 2 may be cleared by a simple reset of the coffee maker. This means unplugging the unit and plugging it back in. When powered back on, select a brew function to see if the error reappears.
If it does, ERR 2 indicates an internal error with the computer of the warming plate. This may be covered under Kitchenaid's 1 Year Hassle Free Warranty. I would advise you to call Kitchenaid Customer Service to see what options are available to you. Repair is not recommended, as it is not cost effective for the company or the consumer.
Their toll-free telephone number is 1-800-541-6390.
Thank you, have a nice day.
Aug 30, 2009 | KitchenAid KCM511 Coffee Maker
Brewing time is too long 20 min for 6cups
You have an obstruction in the feed line to the heating element. I found coffee grounds before the check valve. I had to take the bottom off it which I am sure the manufacture wouldn't approve of but I was at my wits end and ready to toss it. I just brewed a full pot 10 minutes!!!
Aug 18, 2009 | Cuisinart DCC-1200 Coffee Maker
Keeps shutting off after one cups is brewed even if filled for 10 cups
Hi, this is a common problem with Hamilton Beach on several models. There are also a host of other problems with them. There is no fix for these coffee makers. They are "throw aways" have owned them myself in the past and understand your problem. Sorry to sound so negative but Many people are disappointed with Hamilton Beach.
Good Luck.
Aug 17, 2009 | Hamilton Beach BrewStation 47214 Coffee...
GE 169164 Coffee Pot Not Brewing
Loosen the charcoal filter. You only need to GENTLY place it in. Your problems will all be solved. I just did it 5 minutes ago and i just brewed a 6 cup pot of coffee completely.
Jan 07, 2009 | GE 106591 Coffee Maker
Coffee pot turns stops brewing in the middle of the cycle
Yup thats the Ticket - EASY FIX -
you have to clean the insides too people... lol.. The best way to do it is to buy citric acid crystals available from your local pharmacy. who knew huh? a couple of tablespoons in distilled water. Brew half the pot and let it sit for 30 min the brew the rest of the pot. Notice the color of your water after your done brewing. probably green from copper.. I could go into much more detail but thats the short answer... brew another pot or two of just plane ole water and bang your good go.. You should do this every month with any coffee pot for better tasting coffee..
Jan 20, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart 12 Cup Digital Thermal Coffee Maker - BLACK Logo
284 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
