Question about Canon PIXMA MP470 All-in-One Printer
Right Margin Does Not Print
When I print a bank statement or recipe, the material is cut off at the right margin.
This one work for me...on top left of the page click on file then click print. A box print with option opens...... click options then select or put a check on left bottom box that says print all linked documents....good luck!
2nd option or
Last option and 100% will print the entire page even allows you to select what you want to print inside the page. Its called webcollect and here is the link.......http://www.web-collect.co.uk/
Posted on Mar 29, 2008
When printing from my PC the left margin is okay but the right one is cut off before printing the last column what can I do? My Printer is a HP OfficeJet .
go to control panel, printer & faxes. there you will see your printer. right click on printer, go to property, go to printing preference. there chose the paper size as A4. your margin setup will automatically setup. now print from your document. it will print well.
Aug 30, 2011 | HP Office Equipment & Supplies
Only copies half a page. Right margin cuts off
check paper trays to make shure paper is tight in guides. registration settings off
Jan 09, 2010 | Sharp Office Equipment & Supplies
My E-mail when printing on my HP Officejet J5780 cuts the right 1/4 page off at the right margin: appears that the font and picture sizes are enlarged and is cut of at the right hand margin.
that is not unusual, as emails are non formatted for printers, you may find that making the page 'scale' to the paper in print setup panel, will help this.
Nov 24, 2009 | HP Officejet J5780 All-In-One InkJet...
The printer will print OK from the desktop, but when I print from emails it cuts the right margin back about 2" - nothing will print on the right hand side of the page. I tried dumping the driver program...
Dear Glenn27,
As you mentioned, printer works fine normally however the issue is only while printing emails.. so I would like to know the email program that is in use .. I mean, do you use Outlook, Outlook Express or webmail or Lotus notes etc..
If this is a repeated question then I would like to apologies as we experts are not allowed to peep into other experts' solutions so I cannot see the responses by the previous expert.
Also please let me know the following printer settings ..
AUTO WRAP, RIGHT MARGIN, LEFT MARGIN,
What happens when you copy the email text to a standard text editor like Notepad or Ms Word and then try printing .. does it still print with right margin extended?
Waiting for your response.
Regards,
Srinivas
Jun 24, 2009 | Brother HL 1650 Laser Printer
Always prints more to left than established margin
Check you Page Setup andmargin set. Sounds like the page isn't set up properly. When you typing a document, go to the FILE then PAGE SETUP. Margins and Paper Layout.
Hope this helps. Bud
Jan 08, 2009 | Lexmark Optra T610 Laser Printer
Printed Tape Cuts Off Letters
I was having the ame issue. Found the solution on the user manual (posted online). Press Function, scroll to "Margin", press "Function", use arrows to select "#" or "##", then press Function again. Now it should print with a margin, thus not cutting off your letters. Mine was set to "-", which is basically no margin.
Dec 29, 2008 | Brother P-Touch 1180 Label Printer
Not printing whole page
Could be as simply as the right print margin in the application you are using. Try printing a test page by right-clicking on the printer in Printers and Faxes in Control Panel and select Properties. If the test page prints ok then check the margins in the application you are using - usually File>Page Setup. The right margin could be set to 5.0 in instead of 0.5 in.
Dec 15, 2008 | Lexmark X2600 InkJet Printer
Envelope margin error
have you adjusted the page setup on your software?
I'm assuming you're using Word to print a mail merge. yes?
Check that the margins are setup properly in the "word document"
Go undetr file, page setup, and confirm the envelope size is set properly.
Check the page setup in the printing preferences.
File, Print, Printing Preferences.
The printer accepts whatever margins microsoft word tells it to use.
Best wishes
www.techvisitor.com
Oct 20, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Margin problem???
I can just guess it has to do with the paper being fed. either you have the paper wrong or the paper settings to a different size then the actual dimensions of your print material.
Oct 24, 2007 | Dell 3100cn Laser Printer
Paper margin problem in pagemaker application
Do you mean the left margin is too large so all the content is shifted to the right and off the page? If this is the case, it is probably a setting in Pagemaker. In the file menu, choose "page setup" or "print setup". Check the paper size. Check the margins.
Jun 24, 2006 | HP Color LaserJet 2600n Printer
Canon PIXMA MP470 All-in-One Printer Logo
340 people viewed this question
old marine
old marine
