Question about Toshiba SD-6000
Unable to open CD tray
I have been using SD-6000 since few months. All of sudden, the DVD tray would not pop out ... I turned it on/off several times but unable to open it. Pls help.
  • 796 Answers
The winding of the motor controlling the tray operation may not be getting the supply properly or functioning well ...
check it...
that must be the problem
Posted on Mar 21, 2008
SOURCE:
Why not open cd&dvd?
By opening what do you mean? Is it Tray or File? If Tray is not opening, Turn your Computer off, then insert a needle or a pin in the hole just beneath Tray and push the needle in slowly, after a few attempts, your Tray will open. But don't force, if you don't find yourself comfortable doing so, better call authorized service professional.
If it's about not opening Folder or File, there may be several reasons like dirty surface of CD/DVD, Corrupt File(s), Improperly created Sessions on CD/DVD etc etc. If this is the case, you may first try to clear the Surface of your CD or DVD with a soft cloth, slowly. If files or folders are not proper on your CD or DVD, or if you have incomplete writing sessions on your CD or DVD, you can not do anything to open them. Just create another CD or DVD. But if your CD or DVD is rewrite capable, you can format your CD or DVD and rewrite the data, but in this case your Data that's on your CD or DVD will vanish away.
If these things are tough,l please contact Authorized Service Center or your Computer Dealer.
Apr 23, 2014 | Computers & Internet
I have dual cd / dvd drives on my desktop
your cd drive might just be jammed. on the front of the drive there is a little pin hole. find yourself a safety pin or paper clip and insert it in the hole. push the pin in and it will unlock the drive door. with the door open restart your computer.
dont forget to rate your helper
Dec 25, 2009 | Dell INSPIRON 6000 CENTRINO...
Toshiba SD-6000 dvd player tray will not open. The OPEN and LOAD lights just keep flashing.....is there a way i can reset it by unplugging it? it was working fine until now.
The tray is blocked or the drive motor is stucked. Unplug and open the player's casing and check for any obstructions and remove it. It might be a disc or something. Check the motor if it's trying to spin. if not, disconnect it and connect it to a 12-volt supply or lower. If it spins then there's a problem with it's supply. Otherwise the motor should be replaced.
Aug 06, 2009 | Toshiba SD-6000
Unable to copy dvd's
Most dell machines do no come with dvd rewriting as standard. They only come with cd rewriting capability. Unless you specifically requested it as an add on to the spec it probably just has the ability to pay dvd's.
Most internet cafe's will have a machine with a dvd rewriter if you really need to copy a dvd
Val
Dec 15, 2008 | Dell Inspiron 6000 Notebook
CD drine issue
To manually open the CD Drive, straighten a paper clip and insert it into a tiny hole in the front of your CD drive and push the paper clip gently into the drive and the tray should then pop open.
Open and close this several times, then insert a disc into the drive and see if it will read the disc.
If not the drive is dead and needs to be replaced.
Nov 18, 2008 | Acer (KV.16X04.007) DVD Drive
Lid fails to open!
the motor belt are weak or lose / need to replace to accuirate turning out the tray.
Jan 03, 2008 | Sony DRX-810UL DVD RW Dual Layer Burner
CD driver stuck
In the front side of the dvd drive you will see a small hole ...so to eject that cd put one niddle in that hole and .
Now press the button at just after that apply a force on niddle .suddenly you will notice that cd will come outside ,if not try more times and you will learn to eject the cd when you are unable to do it by pressing the eject button...
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Thanks
Dilip Bagdi
Technical Associate
Dec 06, 2007 | Dell INSPIRON 6000 CENTRINO...
CD-RW Problem
There some few tips you can try. Power down the computer then open the cd tray by inserting a sharp object in the small hole near the tray. Look for this hole, then using the sharp object push it pretty hard. With the other hand try to pull the tray out. Once you've pulled it power on the computer (with the cd-rw's tray opened) and watch what the cd-rw is actually doing now. If after it retracts the tray it is doing the same, you will need to dissasemble it. If you are willing to try this, please post another message and also specify there what did the cd-rw drive do when you've applied the method i've told you before.
Mar 11, 2007 | Lite On (LTR-52327S/5238S)...
Toshiba SD-6000 Logo
219 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
