Question about Dyson DCO3 Absolute Bagless Upright Cyclonic Vacuum
Suction loss? loss of suction in hose/attachments so not able to get to small hard to reach places. Suction not appearing to work right through hose?
  • Anonymous Mar 18, 2014
    power paw will not turn; eureka as2000
  • Anonymous Mar 29, 2014
    The hose accessory of the DC24 has no suction
    Scholar:
  • 74 Answers
Hi samdan... have you checked all the hose attachment vents .. ie Under the vacuum as well... How long is it since you replaced the filters?
Try giving the Yellow cone inside a blow out. these tend to become clogged from time to time!
Regards Faggly
Posted on Mar 21, 2008
No suction on my dyson dc27
Most common cause of loss of suction are objects being lodged. You can isolate the area pretty simply. Put your hand to the tube on the detatchable handle. If there is suction there the obstruction is at the base. To clear this turn the vacuum over and lay it down. There is a suction hose that attaches just behind rotating sweeper. Disconect it, and check for debris. Also look in the sweeper compartment for hair, and other clogs. Re-Attach, to see if this remedied the problem.
If the loss of suction is somewhere in the detachable handle. What i have done is disconnect it from the unit... Take a wire hanger or similar and carefully run it through the hose. Be careful not to puncture the hose.
Jul 19, 2014 | Dyson DC27 Bagless Upright Vacuum
No suction from canister on electrolux guardian model c154e. green light on switch is on
Have you remove the hose and checked the suction at the intake of the vacuum? If the motor is running there will be suction.
If there's suction here, attach the hose to the vacuum, turn it on, and check the end of the hose for suction. If there is none or very little, there's a clog or bad leak in the hose. The easiest way to check for a clog is to drop a coin in one end, lift that end up allowing the coin to drop through to the other end and out. If it drops through, the hose is clear. If not, the easiest way to clear it is to plug the hose in to the exhaust port of the vacuum, place the other end into a large garbage bag or point it outside, and turn on the vacuum. This will usually clear a blockage.
Leaks that are severe enough to result in no suction will be readily apparent as tears, cracks, or cuts in the hose. A crushed hose will also result in the loss of suction.
If suction is fine at the end of the hose, do a visual check of the wands. It's unusual for them to be blocked, but not impossible.
Check the power nozzle above and behind the brush and where it attaches to the wand. The elbow can catch long objects resulting in a blockage.
If there don't appear to be any problems with the above mentioned items, you need to take the vacuum, with attachments, to a repair shop to have it checked. It may need a new motor, but that would be due to worn out or broken fans, and that is unlikely with Electrolux vacuum motors years older than that.
Dec 01, 2013 | Electrolux Guardian Bagged Canister Vacuum
My Dyson 41 has just started only sucking through the tube
We've had our DC41 for 4 months now and suddenly noticed no suction at the base as well. Base motor works fine.Thought I'd take one last look before sending in for repair. At the base of the attachment hose near the motor is a small red tab. I depressed it and pulled the entire hose off the motor. Sure enough inside was a eyeliner pencil our daughter had unknowingly vacuumed up. I couldn't see it just peering the length of the hose. Even with a flashlight. You don't see mention of the small red tab but it allows you to see close up rather than peering down the hose if something is lodged near the motor. Apparently this pencil prevented the internal hardware to switch from wand to base suction when the handle is reclined in floor vacuum mode. These vacuums have strong suction and they will pull up the oddest things! Hope this helps!!
Aug 14, 2012 | Dyson Dc 41 Ball
My dyson vacuum cleaner doesn't seem to have the same suction power it used to. I have cleaned out the canister and have taken apart the vacuum head (for cleaning carpets) and it doesn't seem to be...
Hello, this is Ava with Think Crucial.
Most of the time the reason why the vacuum is not picking up is due to loss of suction. You may need to check for blockages of your wand and hose. Remove the wand and hose from your cleaner when checking for blockages and any damages. Make sure to turn off and unplug your vacuum from the power before doing this.
You can purchase a wide variety of high-quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Mar 08, 2011 | Vacuums
Loss of suction to the hose. All hose lines appear to be clear.
Have you tried reversing the hose-- and sucking on the outlet end?-- this might assure that the hose is unplugged--
Or is there ot enough suction at the hose connection, when you remove it, and place your hand over the opening?
WHen did you change filters last on the upright?-- or at least clean the filters?
Mack B
Dec 28, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
There is no suction in the hose part, long part of hose is not cloged
Unplug the machine..now if you remove the attachment hose at the body of the vac and feel inside (to the right about an inch) their is a "suction cover" that rotates when the wand is removed (aka using atachments). The cover in your machine is NOT rotating correctly, so it does not get full suction. If you do get some suction from the hose then their is at least a 'small opening' because it has partially rotated. I was able to fix this problem by taking a large screwdriver (1.5 feet long, thick as a pen), inserting it into the small opening (on the suction cover, inside to the right at the top) and forcing the cover down all the way by lifting the screw driver up against the top of the body opening. Seems to have corrected the problem, but may reoccur. If you have NO suction at all then it has failed to rotate whatsoever, and Im not sure how to correct it.
picture of the suction cover part:
http://evacuumstore.com/p-3604-electrolux-versatility-el8502ab-cover-suction.aspx
To the guy below me...way to not even read the question....
-Steve
Nov 11, 2010 | Electrolux EL8502 Versatility Bagless...
No suction of the water from carpet after soap is applied
Hello :
1: A vacuum pulls air through the bag, then through the tube attachment and then through the base (with the spinning agitator brush).
2:Check for signs of suction. Remove the tube attachment from its cradle and, after turning on the vacuum, put your hand to the end of the tube. Is there any suction at all? If there is a little bit of suction then you may have a clogged air tube.
3:Check the vacuum bag. It may be very full. If it is then remove the bag and replace it with a new bag. Check the suction power again. Has the suction improved?
4:Check the tube attachment. Completely remove it from the vacuum. You usually have to twist and pull the tube attachment out of place at the point where it connects to the back of the vacuum. Check the suction power again. This time you place your hand on the vacuum right where the tube used to come out of the back of the vacuum. Has the suction improved?
5:If the suction power has improved then you probably have a clogged tube. Dog hair, people hair, leaves and more can get lodged in the tube slowly over time and then suddenly block the tube completely.
6:Clean the tube by first trying to shake the debris out of the tube. If this does not work then go outside and run a hose through the tube. Use a pressure nozzle if you have one. Run the hose through one end of the tube. Then run it through the other end. Repeat until the debris is disloged. Dry the tube and then reattach to the vacuum.
7:Has suction power improved or returned to normal power? If yes then you can stop reading now. If not then read on.
8:Check the air hose in the base of the vacuum. This hose is usually pretty short and you can see if there is any blockage. If you see blockage then try to remove it. You may need to reach into the hose with a tool (like a screw driver or something long).
9:Has suction power improved or returned to normal power? If yes then you can stop reading now. If not then read on.
10:If you made it to this step then you may have a problem with the motor on your vacuum. If this is the case then you will need to take the vacuum in to a repair shop.
Things you will need :
1 Philips screw driver
1 flat head screw driver
Warning :
# Always unplug electrical devices before you work on them.
# Never work on electrical devices around water or when you are wet.
I hope this will help .
please rate !
Apr 27, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
My Lindhaus Diamante 300 has great suction but clogs
Sounds like you have some form of an obstruction in the hose ( i once found a tooth pick sideways in mine) most models allow for the hose to be disconnected from the vaccum itself, also make sure theres not a setting for attachments also, some models need the suction redirected.
Apr 08, 2010 | Lindhaus Diamante 300 Upright Vacuum
Dyson suction loss
make sure the filters in the bottom are clean, then remove the canister and you will need to clean it thouroughly, pay close attention to the upper section inside where the "cones" come togetheri have read that they are prone to clog up here and lose suction, google dyson suction loss or how to clean a dyson ect...pay attention to getting the rod that releases the bottom to dump back in the correct place or it will not work right. a few write ups tell about this!
Jan 31, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Loss of Suction
Thank you for this solution, it saved me $$$ and a trip to the repair shop.
Feb 23, 2008 | Kenmore Progressive Bagless Upright with...
Dyson DCO3 Absolute Bagless Upright Cyclonic Vacuum Logo
528 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
