SOURCE: Tappan TEF242BW oven stopped working
Have you tried the broil setting yet?
This will tell you if the upper element comes on.
If so, you may have a burned bottom element.
SOURCE: smell gas no heat
hi thanks for the question yes this problem is very popular in gas ovens even though theigniter lights up its not hot enough to ignite the gas and also with this problem it wont reach the set tempeture thanks the appliance doc
SOURCE: Tappan gas range burner ignition
Hello paultoledoWelcome to fixya.
I'm Huuum and happy to assist you,
You said, You got a 5-year old Tappan gas range. Two of the burners don't
ignite, the other two and the oven are fine.
What do you need to do to
fix the problem?
Sounds like a yes from where I'm sitting, your right on target, buying a new spark module will fix it.
That sounds like the spark modules.
I think you are correct!
Let me know if you need me!
Please remember to leave a solved rating!
Huum
SOURCE: I have a series 30 Tappan Gas Range with a broiler
Either a weak ignitor or stuck valve. I tap on the valve with the plastic end of a screwdriver while it is glowing and if it lights the ignitor is weak. If not the valve is stuck and both should be replaced.
eric
SOURCE: The igniter in the oven of my Tappan gas range
the ignitor is bad it is not pulling enough amps to call for gas replace the ignitor
