Question about Canon imageRUNNER 210S Copier
Cannon Copier image Runner 400/330 series error 051
I keep getting error code 051 on my copier. Can tell me what is the problem. I have an industrial copier Cannon image Runner 400/330 series
  • 5 more comments
  • Anonymous Jun 21, 2008
    las copias salen con rallas y negras como limpiarlas donde encuentro el manual en español
  • manish_xerox Feb 12, 2009
    i often get error code 803, 805, 014 on my canon photocopier
  • hjaber Feb 18, 2009
    feeder not working, need spare part kit
    for Cannon copier ImageRUNNER 330S
  • Anonymous Apr 07, 2009
    error no. E051
  • temeculahome May 14, 2009
    Copier image Runner 400/330 series error 051" problem. error code appears after filing with oem toner... now machine showing error code and will do nothing else
  • Anonymous Mar 13, 2014
    iam getting E005 error code in cannon ir 400 how it can be rectified and if possible send me error code list
  • Anonymous Mar 31, 2014
    Copier shuts down.
    Problem Solver:
  • 11 Answers
E 051 problem is registration horizontal position gear is broken. this gear seem to paper pick up deck back side. remove paper pick up deck and see one small moter and see small gear is there u change it u r problem is solved
Posted on Oct 01, 2008
    New Friend:
Err e051 Problem Tell this Problem
Posted on Jun 19, 2010
  • 86 Answers
Try opening the front cover and there is a green knob under the toner tank try pushing it towards the back of the machine and pulling to the front of the machine if it moves freely. If it does not maybe there is paper caught in between the reg rollers.
E051
The horizontal registration home position
detection mechanism has a fault.
• The horizontal registration sensor
(PS10) has a fault.
• The horizontal registration motor (M9)
has a fault.
• The DC controller PCB has a fault.
Any problems please get back to me
Thank You
Posted on Mar 25, 2008
Error 805 on iR 400 and trouble on power suply
Posted on Aug 09, 2008
    Sniper:
  • 54 Answers
Its a horizontel registration home position sensor problem.
the horizontal motor(m9) has a fault.
mostly the horizonal motor gear is a problem.
Posted on Aug 03, 2008
SOURCE:
Canon ir 400 error code 051
I m E220 Error how to clear the error of Ir 400
Jul 29, 2011 | Canon imageRUNNER 400S Copier
Our Canon Image Runner 330S shows error message E014....
is there an error code appear on panel display?
if there a error appear try to reset you may press * key,press 2&8 simultaneously, the select copier then select fuction then clear then error then ok then turn off& on
Jan 04, 2010 | Canon imageRUNNER 400S Copier
Image runner 4570
it might just be a power spike in which case your machine just shot an error while it protected itself...
try the following...
press additional functions
press 2 and 8 at the same time
press code error
press copier
press function
press clear
press error
press ok
press reset
if that doesn't work then call a tech... it might be very serious...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 21, 2009 | Canon ImageRUNNER 3570 Copier/Printer
Cannon Image Runner c3170U
I am not sure what a AS/400 is, but I do know what chip they are asking about. It is called a Network boot Rom. It is like allowing the copier to be a printer. If you look in service mode under display version. It will have a "N" for networking and "C" for a stand alone copier- no printing. Also, some of the new copier come with it and have other options like faxing. Also, are you buying a new one or used? Also, are you going to use it alot? You may want to go with the c4080 or the faster model c5850 copies a minute. Take from me I work on all of them and the c3170c is not a work horse.
Sep 24, 2008 | Canon imageRUNNER C3170U Color Copier
Canon Image runner photocopier
It is very easy... What code is it? It may not be resetable with out replacing a part... Need more info...
Jul 07, 2008 | Canon imageRUNNER 210S Copier
E051 sensor location
It is located behind the paper pickup unit on the pre-registration guide. There is a teeny tiny motor with a tiny plastic gear and the gear cracks which stalls the motor. The purpose of the sensor and motor are to find the front (or is it rear?) edge of the paper coming out of the duplex unit so it can accuratly line up the images on the paper.
Apr 03, 2008 | Canon imageRUNNER 210S Copier
Cannon image runner c6800 error code E000001-0003
Its a fuser error and it has to be reset in service mode
To get into service mode.....
Press *
Then 2 & 8 together
Then *
then choose COPIER
then choose FUNCTION
then choose CLEAR
then choose ERROR
then press OK
turn power off and on
if the problem comes back there is a problem with the fuser but in my experiance resetting has worked 99% of the time
Mar 05, 2008 | Canon imageRUNNER C6800 Copier
Canon IR 3100 error code (E000020-0081)
error code E00020-0081 my canon printer IRC3170i.what is the problem?Anybody can help?
Feb 19, 2008 | Office Equipment & Supplies
Canon imageRUNNER 210S Copier Logo
2,476 people viewed this question
Clive
Clive
old marine
old marine
Ekse
