Question about HP Photosmart 2610 All-In-One InkJet Printer
Error Message: Remove and check cartridge on right.
Per error message above I have done so and all seems normal. The metal coil in the cartridge slot on the left was not placed as it should be and I fixed that but the problem persists. Any ideas?
  • daveshadow Apr 09, 2008
    I keep getting,"Error: remove and check color cartridge" and have tried a different cartridge and even cleaning what I could reach on the inside and the cartridge. Even unplugged the machine.( is that how you reset it?) How can I fix this problem?
    Thanks
    David
  • Anonymous Apr 11, 2008
    Error message: Cartridge Jam.
    Cartridges are stuck to left on printer. Cannot unstick. What do I do?
  • 4,889 Answers
Just perform a full reset of your printer and it will be done for..
Posted on Mar 21, 2008
Printer keeps giving alignment problem message
hello, remove cartridges, clean with something soft the wiring of both printer cartridge slot and cartridge itself, make sure you use alcohool, sanitary or even parfume wich dries fast and is not greasy, after that power up printer and check to see if everything is alright, if other error ocurs reply here.
hope that helped, best regards
Feb 28, 2014 | Lexmark International Lexmark 7300 Series
My Dad bought new ink cartridges ( black and color) and installed them in the printer and it is not registering that they are installed. What are some things I should check for and how can I fix this????
After installing new ink cartridges in your Dell all-in-one 926 printer, you may receive an error message telling you the print does not recognize the new cartridges. Refilled or third-party cartridges, which Dell does not recommend using with the 926, often trigger the error message. You may also receive this error after you have been using the same ink cartridges for some time. Whether the cartridges are new or not, the error can be caused by a number of sources. Following the steps below should clear up print cartridge problem.
  • 1
    Open the Dell 926's front cover with the power on and wait for the cartridge carriage to come to a stop. Remove the ink cartridges by pressing on the tabs at the top of each cartridge. Check the cartridges to make sure you have removed all of the blue protective plastic film. Look for the "Dell" logo stamped into the cartridges' lids to ensure they are genuine cartridges.
  • 2
    Clean the shiny metal portions of the ink cartridges with a damp microfiber cloth. Allow each cartridge to dry completely.
  • 3
    Clean out any paper, staples or other debris that you may be able to see, then reinsert the cartridges into their appropriate slots. Put the black ink cartridge into the left slot and the color cartridge into the right slot. Make sure both click back into place.
  • 4
    Close the Dell 926's front cover and turn off the printer. Unplug the power cord and USB cable from the printer for five seconds, then reconnect them.
  • If your Dell 926 fails to recognize the print cartridges after following the above instructions,
    take it to a repair shop for servicing.
    Good Luck and Happy Printing
    Jan 26, 2011 | Dell 926 All-In-One InkJet Printer
    10.1000 supply memory error
    hi,
    10.00X is the error code displayed when
    • Cartridge is not installed correctly
    • Use of refilled cartridges
    in your case x is 0 which means that black color cartridge had a problem
    problem may persist in slot holding black cartridge and /or in the cartridge
    just do steps below
    solution 1: check all cartridges are in right slot it is better to remove and fix it again
    solution 2:
    clean the surface of metal contacts with lint-free cloth
    the image below will show metal contacts
    solution 3: Insert the problem print cartridge into a different slot
    Follow these steps to determine if the print cartridge or the slot it sits in is causing the error.
    1. Open the print cartridge door completely.
    2. Press the blue handle on the print cartridge drawer to release it, and then pull the drawer out completely.
    3. Remove one of the non problem print cartridges from its slot.
    4. Install the problem print cartridge into the empty slot.
    5. Install the other print cartridge into the slot of the problem print cartridge.
    6. Close the print cartridge drawer completely.
    7. Close the front access door completely.
    • If the error message persists , replace the problem cartridge with new one(problem is in cartridge)
    • If the error message is gone , contact HP to troubleshoot a faulty slot.
    regards,
    cseian
    Dec 16, 2010 | HP Hewlett Packard LaserJet 3000dn Printer
    Cannot print, scan or copy. Continue to receive
    Solution
    1. Remove and then reinsert the cartridge indicated in the error message.
    2. If the error is still displayed, clean the contacts. Click here to see how.
    3. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
      1. Remove both cartridges, lower the latches, and close the printer access door.
      2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
      3. Turn the printer back on by pressing the On button.
      4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    4. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty.5. Replace Cartridge.Please rate my response!!!Thanks,SF
    Jan 28, 2010 | HP PSC 2410 All-In-One InkJet Printer
    Keep getting replace yellow ink cartridge error message
    Where did you get the error message on printer or computer?
    If you get the message on printer remove all cartridges and reinsert the cartridges and align the ink cartridges. If the alignment page prints successfully then the problem is resolved.
    If you get the message on the computer disconnect the usb from computer. uninstall the software and reinstall the full feature software by selecting connect USB later.
    May 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
    Error message-remove and check cartridge on right
    use a eraser on pencil and rub the contacts on both the cartridge and the machine try again i assume you are using new cartridges by hp
    Jan 01, 2009 | HP OfficeJet 7310 All-In-One InkJet...
    Hp psc2410xi
    The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
    1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
    2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
      • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
        1. Clean the color cartridge contacts.
        2. Reinsert the color cartridge into the carriage and close the blue latch.
        3. Close the printer and wait 10 to 15 seconds.
        4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
      OR
      • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
        1. Reinsert the color cartridge.
        2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
        3. Clean the black or photo cartridge contacts.
        4. Reinsert the black or photo cartridge.
        5. Close the printer and wait 10 to 15 seconds.
        6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    Dell AIO 962 printer faulty
    The error you are referring to could be related to either the cartridge or the printer, so please perform the steps below to check if the issue lies in the printer or the cartridge.
    Power on the printer and open the top cove, the cartridges will align in the middle of the printer, remove both the cartridges form their slots and interchange them, yes put the Black cartridge in the Blue slot and the Color cartridge in the Black slot, then close the top cover of the printer and power off the printer and restart it, at this point of time check if the error message is changed or not if the error message is not changed and till showing the same as “Right cartridge is incorrect” then you can try to update the printer firmware form the Dell support site, here is how you can do it.
    1. Go to www.support.dell.com.
    2. Click on Drivers & Downloads.
    3. Under Option 2: Select a Product as printers.
    4. Locate the printer(s) 962 printer and click Go.
    5. Select an Operating System that is installed in your computer then choose downloads and look for Firmware.
    6. Download and install the firmware, then restart the computer and the printer, however please make sure that you do not restart your computer and the printer when the download and the installation is in progress.
    If the issue is still not fixed after you upgraded the firmware then I believe that you will have to replace it. However if the error message changes to Left cartridge incorrect after you have interchanged the cartridges earlier then try these steps below.
    1. Remove the color cartridge and clean the metal contacts of the cartridge with a dry cloth thoroughly please make sure that you are using a soft dry cloth to clean the metal contacts of the cartridge.
    2. Make sure that the cartridge holder snap which sits on the top of the cartridge is fixed firmly.
    3. Make sure that you are using a Dell branded cartridge and it is not a refilled one cause Dell printers often give error message when you use a refilled cartridge or a cartridge of some other brand.
    4. If the issue is still not resolved replace the color cartridge.
    Regards
    Malik Khan
    Jan 08, 2008 | Dell 962 Photo All-In-One InkJet Printer
    Right cartridge incorrect
    This solution (RESET the BRICK - solution 1 above) worked for me!
    I had a brand new out of the box Lexmark X4580 and after one or two prints I was suddenly getting a "Left Cartridge Incorrect" error showing on the Printer Control Panel and the printer would now all me to print anything.
    After about an hour of trying this and that (cartridges in, out and shalen all about!) ; no avail, I tried this and hey presto, it worked.
    When I removed the "Brick" power supply I left it until the Green LED had faded right out though, I dont know if that was significant or not. Fingers crossed all is sorted now!
    Mar 14, 2007 | Lexmark X7170 All-In-One InkJet Printer
    HP Photosmart 2610 All-In-One InkJet Printer Logo
    196 people viewed this question
    Ben Johnson
