Question about Logitech Optical Cordless Trackman Wheel Mouse
Mouse battery get message your mouses batteries are unknown
  • pdjem Feb 21, 2009
    same issue
SOURCE:
SOURCE: changed batteries, mouse no longer works
what is the receiver?
Posted on Apr 02, 2008
SOURCE: Microsoft Wireless Mouse Model 1025--Keeps giving low battery messages
throw it in the woods and buy a new one ya cheap ****
Posted on Dec 22, 2008
  • 61 Answers
SOURCE: LX5 mouse battery warning still flashing with new batteries
Hello
You need to reconnect the mouse.
Please read instructions from Logitech site
Best regards,
Zizzler
Posted on Apr 24, 2009
  • 6 Answers
SOURCE: microsoft optical notebook mouse 3000 battery change
Simply push the silver oval button below the word "Microsoft" and the cover will spring open.
Posted on May 16, 2009
wayneard
  • 1901 Answers
SOURCE: change battery
If it is cordless, it has batteries. You can usually tell if the small red light is off on the bottom.
Most mice have the battrey compartment in the rear half of the top of the mouse. The rear half slides off. Something like this:
Yours will probably hold 2 AA batteries. If it is one of the smaller ones it may have the battery compartment underneath and take 2 AAA batteries.
Hope this helps.
Thanks for using Fixya.
Posted on Feb 09, 2010
I am getting a message that my Microsoft Laser Mouse 6000v2.0 is about to quit. Do I need new batteries and if so, what.
You need new AA standard type of battery. Use alkaline battery (longest life). Don't use cheap battery because solution from battery can go out and destroy your mouse. Battery life from that mouse can be around 6 month with good battery. This is very good duration for this type of mouse.
Aug 26, 2011 | Microsoft Wireless Laser Mouse 6000 v2.0
My laptop doesn't detect my gigaware wireless mouse anymore
Have you tried the mouse in another computer to verify that it is working? Are the batteries good in the wireless mouse? If these check out okay, got to the device manager and look for issues with unknown devices. If there is software needed to make the mouse work, you can try reinstalling the software, too.
Aug 30, 2010 | Computers & Internet
Reciever does not will connect with mouse
are you sure the batteries are ok? even new batteries can sometimes be dead,
Jan 20, 2010 | Logitech Cordless Mouse
"Connection lost"
Normal 0 First make sure the batteries are good in the mouse. Then do the following.
Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Dec 07, 2009 | Apple Mighty MA086LL/A Mouse
I just dropped my mouse by accident and it doesn't work now. How do I fix this?
open up the door to make sure the batteries are okay, reseat the batteries into the slots to make sure the batteries are making proper contact.
If that doesn't work, then try new batteries just to be sure the batteries aren't the issue.
If it still doesn't work then leave the new batteries in and the usb adapter that comes with that mouse, hook it back up to the usb slot on the laptop and see if windows recognizes the mouse. If no messages come up then go into the device manager and see if the mouse shows up in there.
It will show up as either the type of mouse you have or a yellow question mark which would mean you need to reinstall the software for the mouse.
if nothing shows up in the device manager for the mouse then that means the mouse is bad and would need to be replaced.
Dec 01, 2009 | Microsoft Wireless Notebook Optical Mouse...
98811 mouse wont work
The GE 98811 ergonomic Wireless mini mouse is a HID compliant mouse you will need to change the setting to use this mouse. This is what I would suggest:
Go to device manager
Go to the unknown device
Manually pick a driver
Mice and other pointing devices
***Change to a HID compliant mouse***
Then press the connect buttons on both pieces of hardware and the mouse should work
Hope this helps, it took me over two hours to get the mouse working. Very frustrating!!
Sep 03, 2009 | GE Wireless Optical Mouse
Changed the batteries now the mouse doesn't work
Hi there.
Underneath the mouse there should be a small button which is the connect button, press that and also the button on the docking station if there is one.
Also check to make sure the batteries are in the right way as its an easy mistake to make.
Good luck and thanks for choosing FixYa!!
May 28, 2009 | Logitech MX700 Cordless Optical Mouse
Usb mouse problem
Did you install the CD software program that came with your mouse?
If you did and it gave you the unknown device, Then disconnect the mouse receiver from the USB port and reinstall the software program from the CD.
Then if that doesn't work try the following.
Normal 0 Turn the mouse over and find the smallrest/connect button on the bottom of the mouse and press it toReset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then pressthe mouse. This should be done whenever you change batteries orglitch.
Jan 18, 2009 | Computers & Internet
Battery Message
Method 1: Try different ports. Method 2: Install fresh batteries. Method 3: Resynchronize your device to the receiver. Method 4: Install the latest software from this website: http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx
and Method 5: Clean the mouse lens.
Oct 21, 2008 | Microsoft Wireless Laser Mouse 5000
Logitech Optical Cordless Trackman Wheel Mouse Logo
80 people viewed this question
Top Logitech Computers & Internet Experts
Ekse
Damen Wong
Damen Wong
Alun Cox
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
