Alpine 3518 amplifier
I am looking for a service or repair manual for an alpine 3518 amplifier, any I deas where i might find one?
Thanks, Larry
  • Kilr77 Mar 18, 2009
    Need the wiring diagram
5 Suggested Answers
  • 111 Answers
SOURCE: looking for a manual of alpine TDA - 7552J
YOU CAN ORDER IT FROM pacparts.com
Posted on Dec 17, 2007
robotek
  • 1512 Answers
SOURCE: amplifier repair
any luck, I can help, cant get a manual or any info, what problem are we solving?
regards
Graeme
Posted on Apr 21, 2008
catally733
  • 117 Answers
SOURCE: looking for service manual for optimus amp
www.manuals.com & try www.pacparts.com
Posted on Jan 20, 2010
jdvillanueva
  • 2098 Answers
SOURCE: I 'm looking for a service manual JVC Amplifier
Just want to clarify the model no if it is a JVC KS-AX3300 Power Amplifier. If yes, how can I send you the copy.
Jdvillanueva
Posted on Jul 04, 2011
I obtain recently a car amplifier model: mrv-f400 of alpine, i want information about the correct way to instal thanks
http://www.alpine-usa.com/US-en/support/support_search.php?modelname=MRV-F407
THE ABOVE LINK WILL DOWNLOAD A MANUAL FOR THE SIMILAR MRV-F407 AMPLIFIER. IF YOU WANT TO PURCHASE THE EXACT MANUAL, YOU CAN OBTAIN IT FROM PACIFIC COAST PARTS AT 800-421-5080 PART NUMBER=68P50958W56. IT IS AROUND $5.00 PLUS SHIPPING. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Nov 24, 2009 | Alpine MRV-F540 Car Audio Amplifier
Alpine Amplifier Cuts in and out on Passenger side while driving
Make sure wirings are not pinched and try replacing the fuse as well.
May 01, 2008 | Alpine MRV-F345 Car Audio Amplifier
I have a alpine pdx 1.1000 and it is in protect mode so i disconnected it i started to hook it back up and put power to it and it gose right to protect mode anyway to get it out of protect mode
The most likely suspect would be an internal fault on the Alpine PDX-1.1000. So other than verify the 2 ohms per speaker using a continuity tester (DVM / VOM), all others involve opening the Alpine amp to effect repairs.
Options then are: to consider a DIY (do-it-yourself) repair if and only if you're very familiar with electronic components & circuitry, use of a DVM/VOM and a soldering iron/station.
Access to a Service Manual or at the very least, a schematic diagram would be a necessity (although a challenge in itself) as detailed procedures, test points diagnosis flowchart would be outlined though should you be uncomfortable with a DIY, perhaps your best bet would then be to seek the services of an authorized Alpine Service Center (specially if still under warranty) or a qualified professional.
Now referring to http://www.fixya.com/support/t1817194-stuck_in_protect_mode_phoenix_gold_ryval
"1. Does your amp have a high input port? This is where instead of RCA's you feed it speaker output from your head unit?
2 If so try this and see if the magic happens.. If it doesn't your screwed and the problem is internal most likely in the input stage and that's why your having to "fool" the amp.
3. Also take off the remote turn on wire and make a short little jumper from the remote turn on to the B+ on the amp. Yeah the amp will blaze on but see if it changes the output."
Oct 15, 2009 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Owner manual for alpine 3539
CLICK HERE for your manual in PDF format.
THanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 22, 2009 | Alpine Car Audio & Video
Want to bridge my alpine 3555 amp to run my sub.
I'm assuming this atleast a 2 channel amplifier all you need to do is hook the negative side of the speaker wire coming from the sub to the negative channel one. and the positive to another positive on channel 2. Should indicate on your amplifier channel one and two. most amps provide a diagram right on the amplifier over top of the speaker inputs. let me know if this helps.
Mar 07, 2009 | Alpine Car Audio & Video
Alpine mrd-m500
Hi SPDGOD,
Could not find exact, but close manual.  It is the MRP-M450 mono block amp from alpine.
Go to this url and view in Adobe. Print it if you need to
http://vault.alpine-usa.com/products/documents/OM_MRP-M450.PDF
Oct 19, 2007 | Alpine MRD-M1005 500W x 1 mono subwoofer...
Alpine MRP-M650 problem
The built in power supply is probably bad. This supplyds the voltage from the 12volts and inverts it up to 20 to 30 mvolts DC. You will need to get a manual to service this unless you know the inverter circuit really well. good Luck
Jun 30, 2007 | Alpine MRP-M650 Car Audio Amplifier
Could you help
i have lost the instruction manual for my alpine v12 mono power amplifier mrd-m300 could you send me a print out of it by any chance. Without it i am unsure of the controls on the unit thanks.
Apr 27, 2007 | Alpine MRD-M300 Car Audio Amplifier
this isnt a complex problem but both units may need service
Mar 12, 2007 | Alpine MRV-F345 Car Audio Amplifier
412 people viewed this question
 Grubhead
Grubhead
