Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet steam giving error code f20 - Whirlpool Duet GHW9150P Front Load Washer
  • 1 more comment
  • kkellogg May 04, 2008
    Washer is beeping, stopping on spin cycle....can't get it to finish during the spin.....what do I need to do please?
  • DLThompson06 May 13, 2008
    I have the same problem. Just got the set delivered yesterday. After the installation guys left, we ran the "test" cycle recommended in the manual. Everything was fine. Then we ran a single load of clothes. Again, everything was fine. This morning, I put another load in, and within minutes of starting the cycle, we got an F20 error. I have pulled the machine out and checked all the connections. There are no kinks in the hoses, there is no debris clogging the screens at the inlet hose connections, and the water inlet hose is not frozen. I then reattached the hoses, plugged the machine in, and tried to run the load again, but with no luck. Still getting the F20 error.
  • pilgrim776 Jul 03, 2008
    I just got the Duet Sport washer and had the same F20 problem. I'm on well water, so to minimize our use, we tighten all our valves slightly to make more efficient use of the pressure. We "tested" the washer with a Quick Wash, but the cold-only temperature setting, and kept getting the F20 error. I had to increase the HOT water line a little more, because apparently, even on a cold-only temperature setting, this machine still checks the hot water pressure.
    So, either it's lying and using hot water on a cold-only setting, or it just cares too much about everything. Ah, technology!
Mmm
Posted on Aug 08, 2008
  • mcgeezer1 Aug 08, 2008
    I have finall fixed the f20 error. It has to do with the washer protesting that it is not getting enough water either from the hot or cold intake or both. This can be caused by many things including simple stuff like not turning both water valves on, Super low flow pressure, or screen filters being plugged with particulate. If all of these check out, then you have to look inside the machine. Most of the remaining f20 errors are caused by the following defective part: Whirlpool Washer, Water valve #8540751.
    This is the housing that you screw your hot and cold water hoses into on the back of the washer. The water flow and temprature is controlled by two solenoid energized valves that turn the hot and cold water on and off. In many cases, one or both of these solenoids sticks intermittently, causing water temperature and volume problems that trigger the f20 error. In troubleshooting the problem on a warm water cycle(uses both hot and cold water), the hot water would only flow when I applied hand pressure to the hot water solenoid and flexed the electrical connection durring the fill cycle. It responed by working fine as long as I maintained pressure to the connection, and then failed when pressure was absent.
    This part sells for under thirty dollars, is the size of a baseball, and can be replaced in less than an hour with a few simple tools, good luck
    Problem Solver:
Your connection is band fool
Posted on May 21, 2010
  • dentures May 21, 2010
    I am a tech and I was worried about the fix on this whirlpool duet steam the f20 error code could have been many thing even though the flow meter voltage meter on it, it out to be good it was bad. I replaced it and it worked fine.
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
What is the F20 code on the whirlpool duet front load washer?
Whirlpool WasherDuet Repair F20 Error Code - YouTube
www.youtube.com/watch?v=kYuRQNbR9Nc
  • By Mike Murphy ·
  • 110,010 views ·
  • Added May 11, 2011
How to Fix A Whirlpool Washer Model:Duet that gives you an F20 Error Code.
Mar 08, 2015 | Whirlpool Duet GHW9150P Front Load Washer
How to fix F20 error code whirlpool duet
How to fix F20 error code whirlpool duet YouTube
https://www.youtube.com/results?search_query=How+to+fix+F20+error+code+whirlpool+duet
Sep 04, 2014 | Whirlpool Washing Machines
What does it mean when my duet washer flashes F20?
F20 is a No Water Detect error.
It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed. This can be a potential problem with the following:
* If you have NO water in the wash tub, check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
* If you HAVE water filling the wash tub, check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions: Duet_Service_F20_error
Hope helps.
Sep 24, 2011 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Washer stops during cycle with an error F20
Hi
Please check this link to get error F 20 resolved:-
http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-sport-error-code-f20-washer-repair-troubleshooting/
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I am recieving a F20 error message on a brand new whirlpool washers each time i use it. Its a Duet Steam.
F20 means water is not entering the machine at a sufficent rate, check water supply is connected correctly, turned on and hoses are not blocked or kinked or pinched.
Jan 14, 2011 | Whirlpool Washing Machines
Washer model number WFW9400VE error code F20 keeps coming up. Is there a way to reset?
F20 No water detected entering machine, Defective flow meter, clogged water valve inlet screens.
Duet sport service manual
Jan 07, 2011 | Whirlpool Duet WFW9400VE Front Load Washer...
Error code F-35 is showing on my whirlpoot steam duet stackable front load washer, what does that mean? It won't run through any cycles.
it is an analog pressure sensor failure theres a malfunction with the steamer component detected by the steamer electronic board
check if pressure hose is fixed correctly
check if the airtrap is not blocked
check if the hose is not blocked
hope this helps if this doesnt work write me back
Jul 21, 2010 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
What does f20 mean on the duet steam washer?
After a time the small hose that comes from the pump area to the pressure switch located at the top of the machine can clog.
Unplug the machine. Remove the top or the back of the washer. Locate the pressure switch near the top of the washer. It is about 4 in round and has wires and a 1/4 inch black tube attached to it. Pull the tube from the switch and blow through the tube until clear. Reassemble, plug in and test.
Feb 26, 2010 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Duet Steam washer, F20 error. help
make sure pump is clear. open toe panel and access pump.
Feb 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
1,273 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
