Question about Kenmore Elite 45986 Front Load Washer
Lost my Kenmore Elite E3 manual need to bleach
Hi!
I can't find my Kenmore Elite manual and I was wondering how much Bleach I need to use to do the monthly cleaning cycle..please let me know!
Rebecca
    President:
  • Kenmore Master
  • 2,651 Answers
Forget the bleach for now theres anew product that hit the market in the last few months that will cure youre cleaning noeeds and was designed by/for and with the help of whirpool corp."AFFRESH " tabs, available at major qppliance retaillers as well and the home depot--- best buy as well.
Posted on Mar 23, 2008
Why can't I use liquid color-safe bleach in Kenmore Elite top loading washer?
IF the instructions advise against using bleach in that machine then it is probably because the bleach will affect certain parts / rubbers of the machine and will lead to costly repairs if used.. Try a bleach free soil remover like nappy-san or vanish pink in conjunction with a liquid detergent rather than a powder detergent
Aug 03, 2013 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite front-load
you must remove bottom panel ,,in the center front you will find pump,,remove pump filter,,always unplug first..it has slugg,..than after you clean filter run your unit once a month with a pint of bleach and hot water only..also wipe your rubber gasket or bellows with a touch of bleach..
Dec 27, 2008 | Kenmore Elite 45986 Front Load Washer
DARK CLOTHES END UP WITH BLEACH DOT STAINS
Hello sa-kap,
yYu said,
Hi, I have a top loading Kenmore Elite washer (don't know model #) from the year 2002. It has the automatic bleach dispenser. The problem is that if someone has washed clothes with bleach sometime during the day and someone else comes along and washes dark clothes, the clothes get ruined with dot bleach stains. It appears that the bleach remains in the washer. Any tips or do I need to buy a new washer? Any help would be greatly appreciated. Thank you
V.C.My problem is similar to that which VCasabona is having. Not just dots occur but often big splotches. It may not even be just a colored load following whites on the same day but, on occasion, it occurs on the next laundry day, a week later with the first load that is not the whites with bleach. Also, my wife adds the bleach to the filled washer (old school, I guess), rather than pouring into the dispenser. My water pressure, which is not at issue, is not what I need to address to remedy the situation. I have noted that the ledge that is part of the floating tub had some build-up of deposits, some of which may have been bleach. These I've reached in with damp cloths and removed as best I can. I've run full, empty loads through hoping this would flush out any lingering bleach. Because the occurrences run intermittently from infrequently to frequently I cannot be sure if any of my attempts to remedy the problem are having any effect. I've guessed at the model # of the Kenmore top load washer we own since Dec of 1999
Sounds like some water is remaining in the tub after the pump gets done emptying the washer.
So its the pump!
The Kenmore Elite is a good washer and I believe worth fixing!
Unless the cost is half the price of the cost of a replacement.
Bless You,
Please write me a good rating before you sign off.
Jun 20, 2008 | Kenmore 24032\24036 Top Load Washer
SOME BLEACH DISPENSERS USE COLD WATER TO FLUSH THE BLEACH FROM THE CUP. CHECK THE COLD WATER FOR GOOD PRESSURE. IF THERE ISN'T GOOD PRESSURE, REMOVE THE COLD WATER HOSE FROM THE MACHINE AND CHECK THE SCREEN INSIDE THE VALVE WHERE YOU REMOVED THE HOSE. PUT THE END OF THE HOSE IN THE TUB AND TURN IT ON. CHECK FOR GOOD PRESSURE. CLEAN THE SCREEN AND RECHECK THE WATER PRESSURE AFTER REINSTALLING THE HOSE AND TURNING ON THE WATER. IF YOU STIL HAVE POOR PRESSURE REPLACE THE VALVE.
Apr 07, 2008 | Kenmore 22422 Top Load Washer
Kenmore he3
Getting around the way the boards are pre-programmed is not something they write into the manuals or even make programable. If you want to soak with more bleach, open the dispenser drawer after the unit has filled and add a bleach/ water miture to the soap area of the dispenser. This will let it run into the machine and will get you more bleach in there.
Apr 05, 2008 | Kenmore Elite 45986 Front Load Washer
Top Load Kenmore Elite Bleach Dispenser Leaking
I have this same problem today and did not need to take off the top panel or remove the front panel/housing. The bleach and frabric softener dispenser snaps right out and you can check the tubing and clamp from there. You will need to remove the top panel if you need to replace the tubing. In my case, there is a crack in the dispenser itself which has ruined several loads of laundry over the past year...now I realize it wasn't the clamp and hose, but the dispenser itself. Check them all while you are at it.
Nov 18, 2007 | Tecnik TKL9260 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
278 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
