Replace bearing on washing machine
I need to change the bearing and inner spider on an Electra 17340E.
Could you please advise?
  • gazo Mar 22, 2008
    It is definetely the bearing which has failed. It is the inner one and I have replaced it. However, this involved me removing the whole drum and ancillary equipment. I would prefer a step by step guide on this procedure?
  • 871 Answers
This may help you out.
Replacing Drive Belts and Tightening Pulleys
The drive belt (or belts) of a washing machine may become worn or damaged, causing noisy operation or stopping the washer entirely. A damaged drive belt is easy to replace. Remove the back panel of the washer to gain access to the belt. To remove the belt:
Step 1: Loosen the bolt on the motor bracket and move the motor to put slack in the belt.
Step 2: Remove the old belt and stretch a new one into place on the pulleys.
Step 3: To put tension on the new belt, use a hammer handle or a short pry bar to push the motor into position while you tighten the bolt in the adjustable bracket. The belt should have about 1/2 inch deflection when you press on it at the center point, midway between the pulleys. If the belt is too loose, it will slip on the pulleys, causing the machine to malfunction. If the belt is too tight, it will wear very quickly and will probably become so hot that it will start to smoke or smell.
Loose pulleys can also cause problems. Most pulleys are fastened to shafts with setscrews around the hub of the pulley. These screws must be tight or else the pulley or belt will slip. The resulting malfunction may seem to be caused by a faulty motor, but it can be corrected by tightening the pulleys and adjusting the belt. For this reason, always check the belts and pulleys before working on the motor.
Servicing the Motor
In most cases, motor malfunctions should be handled by a professional; do not try to fix the motor yourself. If the motor is a universal motor, however, you can change worn carbon brushes when sparking occurs. To save the expense of a service call, remove the motor from the washer and take it to a professional service person, then reinstall the repaired or new motor yourself. To access the motor, remove the back panel of the washer. The motor is mounted on an adjustable bracket.
There is one other motor problem you can repair yourself. Washer motors usually have an overload protector clipped to the motor. When this component fails, the motor won't work. Before you take the motor in for service, test the protector with a VOM set to the RX1 scale. Disconnect one electrical lead wire to the protector and clip one probe of the VOM to each protector terminal. The meter should read zero. If the needle jumps higher, the protector is faulty and should be replaced. Pry up the protector with a screwdriver and replace it with a new one made specifically for the motor or washer. Connect the new protector the same way the old one was connected.
Servicing a washing machine can be a frustrating home repair project. Because a washer has so many different cycles and functions it's not always apparent what exactly is going wrong. With the troubleshooting tips in this article, you should be cranking out loads of clean laundry in no time.
Posted on Mar 21, 2008
  • earl norman llanera
    earl norman llanera Mar 21, 2008
    since your asking for changing the bearings, follow the steps here since they may have similarities anyway. be careful always ok.
  • 1,512 Answers
You can get a bearing kit from here
  • Graeme Ross
    Graeme Ross Mar 21, 2008
    or from here
  • Graeme Ross
    and correct procdures for your model from here
  • 796 Answers
Are you tech saavy..can you do it by yourself.
click here....to learn
Hotpoint wmf560 aquarius washing machine
BIG JOB !!! The whole machine has to be stripped down. Ie/ The complete bowl assy has to be removed from the machine, the outer bowl separated from the inner bowl, the main seal removed, and the bearings pressed or knocked out of the housing in the rear of the outer tub. If the bearings have failed , it would be almost certain that the drum shaft has worn and or been damaged. You will need a set of bearings, drum spider shaft assy, and main seal. If its an older machine, it may not be worth it.
Apr 13, 2015 | Washing Machines
Bosch wff 2000 inner drum wobbles and knocks??
when you changed the bearings did you check the spider for any broken legs on it
or have you firmly fixed the belt pully
Nov 11, 2013 | Bosch Classixx WFL 2066 Front Load Washer
I have a LG wm2277hw washing machine. the drum will spin a little and then make a scaping sound like friction. The drum has a lot of play in it. Is there a hard plastic washer or shim that wears out. The...
The symptoms that you describe sound like the spider or support arms of your washer has failed. It the part that holds the wash drum true in the plastic tub. It's a rather difficult job to replace the spider since the washer has to be taken apart to get to the spider. Fortunately, LG does sell the spider, instead of making you buy a new spider and drum. You may need to also replace the plastic tub parts if they are too damaged to be reused. Get a few estimates before deciding whether to repair or replace.
Mar 21, 2011 | LG WM-2277HW Front Load Washer
Washing machine makes terrible noise please advise
where the noise came from during the spinning time? if is spinning time,check the foot of your unit if is unbalance and adjust it,if is ok but the noise still in der the belt of the unit is wort out check the belt is is loose,remove cover the the back to check,if is belt is ok,the bearing have big problem and need to replace the new one,but you need an technician to remove it coz very difficult to remove this,need to dismantle the hole unit to remove the bearing and replace it that why the technician can do that
Dec 24, 2010 | Zanussi WJS1265W Front Load Washer/Dryer
I have a aquarius hotpoint 340, bearing gone
You have to split the drum to replace the bearings
The reason the bearings have gone is that water has leaked into them and the soap content has destroyed the grease
There is a carbon seal on the spider assy which attaches to the back of the drum , this normally cracks so the spider or seal has to be replaced
Feb 24, 2010 | Hotpoint Aquarius WF000 Front Load Washer
I need to replace the bearing in an AEG Lavamat 1450. I've taken the back off the machine, but there isn't a traditional "spider", just a round wheel type thing attached with an Allen bolt. Can I have some...
Hi there.....unless your exerienced in this area...id advise you to seek expert help...the drive wheel securing bolt is of the torx type and requires a secial torx key to remove it....you will find that the outter drum has a series of torx headed screws around it which have to be removed and then the drum split...only after this has been completed and the inner drum removed will you have access to.the bearings.......
regards Sir Galahad
Aug 20, 2009 | Washing Machines
Washing machine, bang crash
It sounds liek a shock/support is broke. Remove the lower front panel after you UNPLUG the washer and you might be able to see what is wrong.
Hope this helps.
Thanks
Vic
May 11, 2009 | Washing Machines
Replace drum bearing
To complete this repair correctly and to prevent problem re occuring within months you must change the inner drum spider at the same time as the bearing kit, otherwise you are wasting your time, to complete the repair if you have not done one before will take you aprox 1 to 3 hours depending on space available and practicle ability, here goes, remove lid and outer case from machine to do this remove bolts on lower back and two side bolts (under small white covers) remove bolts along top edges both sides on top of macnine, remove cabinet, remove motor, remove hoses, remove heater and thermostat wires, noting location for refitting, remove suspension leg pins and lift outer drum assembly complete fron lower frame, split two halves of outer drum by removing bolts around centre seem, split drum in two, remove drum pully, refit pully bolt and drift inner drum out having put nut back on drum spider thread to avoid flaring shaft, using hammer knock shaft through bearings, then using a chisel or similer object knock out bearings and seal, reverse process refitting new bearins and spider, make sure to replace centre outer drum seal, as these are prone tro leaking I suggest you also seal with a layer of clear silicon, and problems contact me again, not really a job for a novice. Good Luck you will need it. Regards Advisor
Aug 29, 2007 | Zanussi FJS1225W Front Load Washer
Noisy spin loose drum
drum bearing need need bearing kit and drum support £60 plus labour at similar price. Appliance Doctor
Feb 02, 2007 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
89 people viewed this question
Top Washing Machines Experts
