Question about Onkyo TX-SR605 Receiver
No video signal on my tv fron the TX-SR605
I just purchased the TX-SR605 and im having problems with the cetup/connection of my Sky box.
I have connected it using a scart out to Phono/RGB plugs into the CBL/SAT on the Amp. Currently I have no sound or video picture I have asked where I purchased the system but they are not sure. I have searched online and some sites reccomend scart/RGB to component convertor. The problem is my brother has one too and he already tried that and it still didn't work so he got a new box with S-video. Im sure it is something we have both done incorrect can you comfirm it is possible to use the Amp in the way I discribed if yes how to do it?
Many thanks in advance.
  • 151 Answers
IFF YOU ARE USEING HDMI FROM AMP TO TV SET HDMI OUT PUT ON IN AMP MENU, FIRST BY GOING TO SET UP MENU IN/OUT ASSIGN PRESS ENTER ,MONITOR OUT NOW ON AMP, PRESS ENTER TO SEE HDMI MNTR AND PRESS RIGHT ON ENTER BUTTON TO SWITCH ON.IFF YOU ARE NOT USEING HDMI TO TV LEAVE HDMI OFF AND PRESS DIGITAL INPUT BUTTON ON FRONT OF AMP TO SELECT THE TYPE OF CABLE YOU ARE USEING FOR AUDIO,EG OPT1 OR2 COAX 1 OR 2,IFF YOU ARE USEING PHONO CABLES SELECT _ _ _ .MAKE SURE OUT PUT ON SKY IS SET TO RGB.
HOPE THIS HELPS.
CABLE GUY.
Posted on Jun 04, 2008
Onkyo sr605: needs to "warm up" before video
check your display section, is there any problem?
Jan 08, 2011 | Onkyo TX-SR605 Receiver
I have a 37" Sony Bravia KDL-37XBR6 that I purchased in July 2008. I also have a Time Warner HD cable box that also has a built in DVR. The HD cable has been connected to the HDMI 1 port. It worked just...
Hello, There is an update for your TV at Sony Support and I would strongly  recommend to call Sony Support to update your TV as firmware updating firmware is risky job for novice and TV firmware can be damaged and TV will shut down.
Jan 10, 2009 | Onkyo TX-SR605 Receiver
How to program onkyo tx-sr606 receiver onto remote control
I think onkyo has not come up with codes for game console yet. Codes that are available are for DVR/VCR, CD, DVD, TV. and Setup Box. I need to get the manufacturer of those components that you have for me to be able to determine which code is appropriete for your components.
Nov 23, 2008 | Onkyo TX-SR605 Receiver
Onkyo TX-SR605 video problems
Bypass most reviews say video area is still alittle shaky
Feb 08, 2008 | Onkyo TX-SR605 Receiver
Cable box pass through
ur trying to downgrade the signal when ur running composite cords u need to either run the composite out or an hdmi out to upconvert the signal the svideo cant handle the composite
Dec 18, 2007 | Onkyo TX-SR605 Receiver
No video throught HDMI output
press set up go option number 1 then go hdmi monitor and input yes. then press set up again
Dec 11, 2007 | Onkyo TX-SR605 Receiver
Analog RCA input to HDMI output?
You have said the correct thing HDMI is digital therefore Analog will not pass.
You might have RCA audio outputs on your cable box so either send them into the TV from cable or into the AMP then use AMP volume to listen to TV audio (select unused input and remember it is for TV) the key is to remember that cable box will drive the initial vol so raise or lower cable vol then use AMP vol to obtain desired volume.
Nov 29, 2007 | Onkyo TX-SR605 Receiver
New home theater setup- no signal at tv using onkyo tx=sr605
Could well be the quality of your cables. if you have high end cables the consult a service agent. if you have the cables that came with the products, go and get some better ones.
Nov 04, 2007 | Onkyo TX-SR605 Receiver
Cable connection to Onkyo TX-SR605 7.1
You will have to connect your coax to the tv coax input.You can view cable this way.To use the hdmi input to tv,you will have to change your input settings back and forth on the tv menu from hdmi to rf input.There is no way to hook your cable to the txsr.
Oct 22, 2007 | Onkyo TX-SR604 Receiver
Onkyo TX-SR605 Receiver Logo
141 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
