Question about Konica Minolta magicolor 5430 DL Laser Printer
Printer problem I have a Konica Minolta Magicolor 5430DL printer connected to a Dell laptop running Windows Vista but I cannot get it to print. Every time I send something to print I get a window pop up that says print to file but it will not print whether I save the file or not
  • jterry Aug 13, 2008
    Solution for "print to file" problems with Konica printer & Windows Vista;
    Vista defaults the Konica printer to "print to file" when the printer is connected so the user has to
    1) go to the "control panel" in Vista
    2) choose "printers"
    3) choose "ports"
    4) change the default port from "print to file" to "USB"
    this fixed my problem, I hope this helps someone it only took me 12 months to figure it out..
    Brigadier General:
  • 6,966 Answers
You have tried a couple of times for Live Session but for some reason, the "Conversation is closed or you can not access this conversation." always shows up.
Perhaps another expert has responded, perhaps the site is too busy or for whatever reason if you still need assistance you could also try the Premium Solution.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 21, 2008
  • Konica Minolta Master
  • 19,396 Answers
I think I had a chat with you , here is trancription:
You are now in session with bazza1963
ginko says:
hi
ginko says:
are you there?
ginko says:
seems you need to re-install driver softwar for your printer, do you have printer disks? and which version of operative system are you using (Windows XP, Vista, etc)
ginko says:
I will try to find drivers for windows, give me some minute
ginko says:
Here is Driver download page for your printer, start downloading the one for for your system:
ginko says:
www.qms.com
ginko says:
Here is installation guide, same as the one provided with printer: ftp://ftp.minolta-qms.com/pub/cts/out_going/manuals/5430dl/ig54dl.pdf
ginko says:
ginko says:
download the above driver software.
ginko says:
is the same as the one distributed in disk coming with printer , if you have the disk you can use the disk
ginko says:
Once you downloaded software do the following:
ginko says:
1 disconnect printer from PC
ginko says:
2 expand and install downloaded software, alternatevely use the disk provided with the printer. Do this with printer disconnected.
ginko says:
3 when asked from installation, or after installation, connect the printer to your computer using the USB cable , not the network (ethernet) cable
ginko says:
4 the printer will be recognised in Windows, if it does not restart the PC
ginko says:
You must use an usb cable to use this printer as a local printer.
ginko says:
You may need a router to use the ethernet cable (one similar to thick phone cable) provided with the printer
ginko says:
therefore ensure you are using the right cable
ginko says:
here is an example of usb cable, sometimes it is not provided with the printer, have a look,. This is the right cable you need to use to connect this printer to local computer, the other one is for network www.amazon.co.uk-
ginko says:
check on www.amazon.co.uk how it looks like and ensure you are using the right one
ginko says:
let me know if you need further help, I am not receiving much feedback from you
ginko says:
Best regards
ginko says:
Also check under printers in vista that you have this printer installed and that it is the default print
I could not get any feedback from you , do not know if there was something wrong with chat software
regards
Magicolor 5430DL firmware
located at a secure Konica Minolta web site seem that Konica Minolta protects their Copier/printer firmware, available to only Konica Minolta dealerships and KMBS, need a tech
Feb 15, 2014 | Konica Minolta magicolor 5430 DL Laser...
Magicolor 5430 dl printer driver needed for windows 7
Try downloading this
Extract and go to
mc5430DL_Win7_v2.0.1.0\English\English\setup.exe
Run this setup file.
Install the components that you want.
If you select local and USB ensure printer is plugged in to your computer.
Hope this helps.
Feb 14, 2013 | Konica Minolta magicolor 5430 DL Laser...
Konica Minolta 5430DL second tray - print dialogue
This needs to be setup through the computer using the printer properties, not through the printer. You will need to be the local admin to make the changes. You may also have to go under advance and manual specify the tray and component types. The printer will not allow you to set options for trays and components that are not enabled or detected. Let me know if you need a step-by-step.
Nov 08, 2009 | Konica Minolta Magicolor 2530 DL Laser...
I have a Konica Minolta magicolor 2400w printer I
have you read if you need your windows up to date? like windows xp/vista sp2?? or maybe your windows need an extra component.try this update your windows google this window update then follow the microsoft links and this will fix your problem for ya'
Jun 28, 2009 | Konica Minolta magicolor 2400 Laser...
Konica Minolta 5430DL error code 111112
I couldn't find the install disks so downloaded the driver from the Konica website, un-installed the software and re-installed it. After calibrating the colours everything seems fine now.
Oct 01, 2008 | Konica Minolta magicolor 5430 DL Laser...
Vista print drive for the konica minolta 2400w
If you are using the USB connection, got Control Panel, Device Manager and delete/uninstall the last listed USB Hub - and wait a moment for the system to re-recognize what's connected. If there is a page in the cache, it will automatically start to print.
Sep 12, 2008 | Konica Minolta magicolor 2400 Laser...
Konica Minolta Magicolor 2400W -- Only Prints on Reboot!
I've had that problem before too, and found out that there were copies of the printer that had somehow installed themselves on my computer. All I needed to do was to choose to print with "konica minolta copy 1" instead of the one that I *thought* was installed and it worked. I then deleted the original printer and just stuck with the copy.
Jul 22, 2008 | Konica Minolta magicolor 2400 Laser...
Konica minolta 5430dl colour printer
13D0H: Parameter Chip failure
Unplug the power cord and plug it in, then turn
OFF and ON the Power Switch.
the PWB-A may be faulty.
May 21, 2008 | Konica Minolta magicolor 5430 DL Laser...
MagiColor 2300DL Printing Wtih Vista over Wireless Network
I am using Vista 64 and a 2300DL in the same manner as abertola003. I downloaded the Latest driver from Konica Website and everything is working well.
the driver is named Konica-Minolta 2300DL (unidrv)
Apr 01, 2008 | Konica Minolta magicolor 2300DL Laser...
Konica Minolta magicolor 5430 DL Laser Printer Logo
154 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
