My drives r not opening
Hi friends.. im having a problem to access my hard disk drives.. when ever i double click it, it wil show open with dialog box. i had same problem proviously, but tat time i installed avast anti virus n cleaned. but same problem arised now but its not cleared by avast. plz help in resolving this problem.
    Genius:
  • 1,913 Answers
Hi
first turn off your system restore in my computer propertitis sys restore menu.
then scan your pc with quick heal ,avast , symantec with latest update definition.in safe mode.
u gor auturun virus. u can remove it very easily.also iu gor other virus like ntdetect.com, etc.
best of luck
pls notify me that my solution is solve the pro all helpfull
bye
Posted on Mar 23, 2008
SOURCE:
My WD 320gb external hard disk is not getting detected in computers...the blue light blinks on d drive & also in device manager the hard disk is shown....but cant get into it & itz not...
For windows 7 / Vista : - write "Administrative Tools" to start menu "Search Programs and Files" box and click enter - Double click "Computer Management" - Click on Disk Management under the Storage on the right. - If your WD disk is shown on the list at the top, right click it and select Change Driver Letter and Path - Select a suitable letter. - Try reaching to your hdd from My Computer
For windows xp ( or 7 and no results appear when you write "Administrative Tools" to start menu "Search Programs and Files" box and click enter)
  1. Right-click on an open part of the Windows task bar and selectProperties. The Properties dialog box opens.
  2. Click the Start Menu tab, then click the Customize button. The Customize Start Menu dialog box opens.
  3. Click the Advanced tab, then scroll to the bottom of the Start Menu items list and click the radio button next System Administrative Tools > Display on the All Programs menu and Start menu.
  4. Click OK twice.
  5. Click Start > All Programs > Administrative tools to access these tools.
Then follow the above (first) steps.
Mar 10, 2011 | Computers & Internet
My hard drive Maxtor do not recognize.I have many important data inside,I would like to backup all data.can you help me .
Firstly be more specific on the problem anyway I wil tell u some solutions....I think your problem is that the hard disk is not being accepted ...Open the CPU box and check the pins and fix them once more correctly and firmly. I think that wil solve yur pblm. ALso if u have any friends system which can accessed , u can remove yur hard disk from yur sytem and connect as a slave harddisk in your friends system and then can back up all the data
Thank You
Please rate me as it will be just one CLICK
Don't find fault, find a remedy. - Henry Ford
Oct 23, 2009 | Computers & Internet
When i try to open any drive or any other application a dialog box 'open with' appears why this happens ,how do i solve this problem?
This is problem with registry, there is some sort of corrupt data in your registry which can be cleaned by registry repair.
By the way you can open your drive by using explorer drop down address bar.
Sep 11, 2009 | HP 435768-001 - Compaq Presario C300...
I cant access the d partition on my hard drive
Hi...
Do you want to access the drive d and get your files. You can not access it when you double click the drive. The drive will says access denied. To access the drive d open My Computer you can see there a address, there is and arrow there just click. Chose the drive d to open i am sure that you can open it.
Regards
PCmania
Aug 27, 2009 | Computers & Internet
Lenovo Y510 stuck on logo screen at startup
back up your data and do the fresh installation of OS
Jun 13, 2009 | Lenovo ThinkPad T61 Notebook
My ATI Catalyst Control center Problem was first.
Your hard drive sounds like it's about to fail. MAKE BACKUPS NOW! I would start in safe mode and backup all my important files to an external source. Then I would run a chkdsk, here's how:
Double-click My Computer, and then right-click the hard disk that you want to check.
  1. Click Properties, and then click Tools.
  2. Under Error-checking, click Check Now. A dialog box that shows the Check disk options is displayed,
  3. Use the following procedures:
    • To repair errors, locate bad sectors, and recover readable information, select the Scan for and attempt recovery of bad sectors check box, and then click Start.
    Note If one or more of the files on the hard disk are open, you will receive the following message: The disk check could not be performed because the disk check utility needs exclusive access to some Windows files on the disk. These files can be accessed by restarting Windows. Do you want to schedule the disk check to occur the next time you restart the computer? Click Yes to schedule the disk check, and then restart your computer to start the disk check.
Please don't forget to rate this solution.
Jun 13, 2009 | Computers & Internet
Kingston 2GB pen drive not opening by double click
This is cause by a virus or something , first thing that you can do here is to back up all the files from your pen drive and then one everything is already back up you can go ahead and format the drive, just right click the pen drive and select format....that should;d fix the problem,,,,
Dec 28, 2008 | Vantec 1 Bay NexStar 3 USB 2.0 External...
Acomdata Photon 250 gig not working
I would try running chkdsk via the recovery console. does your bios dectect the drive, and just not the os?
Dec 18, 2008 | Acomdata PHOTON 2.5 (PHD080U2E54) Hard...
Couldn't open the hard Drive folders....
hi sir,
i think you have an autorun.inf file residing at your local drives. this probably infected by a virus.
go to control panel >folder option> click View> choose "Show Hidden Files and Folders" and uncheck Hide Protected Operating System Files, this will show hidden autorun.inf file. In your explorer, right click your local disk and click explore, this will show all your files and folders of your drive, navigate autorun.inf file, if found delete it.
note: it has an associated file called vbsscript file...if found also delete it..do the same with the other drives. empty recycle bin and restart.
Winsor
Sep 02, 2008 | Microsoft Windows Server Standard 2003 for...
Problem in watching hidden files.
I had earlier experienced the same problem of when you double click the Drives....the response is an open with dialog bo..If they were earlier opening when you doble clicked .Its most probable that a virus has infected your machine..Try to clean it wih a stong and updated antivirus..Also if you have to access the drives try to right click on them and click explore on the pop-up menu..
Try opening them in windows explorer..for option two
May 03, 2008 | Computers & Internet
Open Questions:
avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7
Oct 17, 2019 | AVG Computers & Internet
Computers & Internet Logo
49 people viewed this question
Ekse
Alun Cox
