I have installed my magicolor 5430DL printer on my PC and connected it but it will not print. Everytime I send something to print I get a window pop up that says print to file and urges me to save a file in documents then nothing hppens
    Brigadier General:
  • 6,966 Answers
You have tried a couple of times for Live Session but for some reason, the "Conversation is closed or you can not access this conversation." always shows up.
Perhaps another expert has responded, perhaps the site is too busy or for whatever reason if you still need assistance you could also try the Premium Solution.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 21, 2008
SOURCE:
How up upgrade engine firmware on KM 5430DL?
Have tech come out. mite be able to flash the firmware
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 07, 2017 | Konica Minolta magicolor 5430DL
Magicolor 5430 dl printer driver needed for windows 7
Try downloading this
Extract and go to
mc5430DL_Win7_v2.0.1.0\English\English\setup.exe
Run this setup file.
Install the components that you want.
If you select local and USB ensure printer is plugged in to your computer.
Hope this helps.
Feb 14, 2013 | Konica Minolta magicolor 5430 DL Laser...
How do I print 8-1/2" x 14" paper. I only have one 8-1/2" x 11" tray? Konica Minolta Magicolor 5430DL
On the 5430 DL there is an aux legal tray that can be purchased for legal printing. On a later successor the 5550 a manual feed option was included, however for the 5430 there is no option for printing legal without the extra tray being installed. On a side note, I have this tray and when not printing legal it lets me load an extra 500 sheets of letter paper which is very convenient when I need to print a bunch of sheets overnight.
Mar 15, 2010 | Konica Minolta magicolor 5430 DL Laser...
Konica Minolta 5430DL second tray - print dialogue
This needs to be setup through the computer using the printer properties, not through the printer. You will need to be the local admin to make the changes. You may also have to go under advance and manual specify the tray and component types. The printer will not allow you to set options for trays and components that are not enabled or detected. Let me know if you need a step-by-step.
Nov 08, 2009 | Konica Minolta Magicolor 2530 DL Laser...
KONICA MINOLTA magicolor 5430DL don't recognize paper
The machine keeps track of what paper was reqested last, and asks you to change paper if the new job is different. I get the "put media" message and have to open and close the drawer if my next print job requests a different paper. So I suggest you gently open and slam the drawer a couple of times, or see if you can find the sensor switch that monitors whether the drawer is open. Also check if your paper guides in the drawer are clicked in place.
Sep 03, 2009 | Konica Minolta magicolor 5430 DL Laser...
Konica Minolta 5430DL error code 111112
I couldn't find the install disks so downloaded the driver from the Konica website, un-installed the software and re-installed it. After calibrating the colours everything seems fine now.
Oct 01, 2008 | Konica Minolta magicolor 5430 DL Laser...
Konica magicolor 5430 smuding all over page
also there can be problem with the waste toner pipes, that the waste toner wont go away and smug the page. check waste toner box also check transfer belt and pc drums that they are clean.
Jun 03, 2008 | Konica Minolta magicolor 5430 DL Laser...
Printer problem
I think I had a chat with you , here is trancription:
You are now in session with bazza1963
ginko says:
hi
ginko says:
are you there?
ginko says:
seems you need to re-install driver softwar for your printer, do you have printer disks? and which version of operative system are you using (Windows XP, Vista, etc)
ginko says:
I will try to find drivers for windows, give me some minute
ginko says:
Here is Driver download page for your printer, start downloading the one for for your system:
ginko says:
www.qms.com
ginko says:
Here is installation guide, same as the one provided with printer: ftp://ftp.minolta-qms.com/pub/cts/out_going/manuals/5430dl/ig54dl.pdf
ginko says:
ginko says:
download the above driver software.
ginko says:
is the same as the one distributed in disk coming with printer , if you have the disk you can use the disk
ginko says:
Once you downloaded software do the following:
ginko says:
1 disconnect printer from PC
ginko says:
2 expand and install downloaded software, alternatevely use the disk provided with the printer. Do this with printer disconnected.
ginko says:
3 when asked from installation, or after installation, connect the printer to your computer using the USB cable , not the network (ethernet) cable
ginko says:
4 the printer will be recognised in Windows, if it does not restart the PC
ginko says:
You must use an usb cable to use this printer as a local printer.
ginko says:
You may need a router to use the ethernet cable (one similar to thick phone cable) provided with the printer
ginko says:
therefore ensure you are using the right cable
ginko says:
here is an example of usb cable, sometimes it is not provided with the printer, have a look,. This is the right cable you need to use to connect this printer to local computer, the other one is for network www.amazon.co.uk-
ginko says:
check on www.amazon.co.uk how it looks like and ensure you are using the right one
ginko says:
let me know if you need further help, I am not receiving much feedback from you
ginko says:
Best regards
ginko says:
Also check under printers in vista that you have this printer installed and that it is the default print
I could not get any feedback from you , do not know if there was something wrong with chat software
regards
Mar 21, 2008 | Konica Minolta magicolor 5430 DL Laser...
Printing from 2 different pc, drivers installed on the server, get different quality
I think that quality settings is different for each user. If your printer have network card, pleas install printer with TCP/IP port in every PC, not from server, more job, but less problems.
Sep 15, 2006 | Konica Minolta magicolor 5430 DL Laser...
Open Questions:
Computers & Internet Logo
43 people viewed this question
Ekse
Marvin
Marvin
