Question about Kodak EasyShare C613 Digital Camera
Help? can i get my digital camera fix? when i press the on botton it came on but it said lens error, then shut off.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kodak Master
  • 102,366 Answers
SOURCE: Lens Error 111,0,0,23 on my Kodak Easy Share c743
have a look at this
Posted on May 12, 2008
  • 188 Answers
SOURCE: lens error
you can't fix it by yourse. You need it to send for repairs.
Posted on Jul 29, 2008
  • 83 Answers
SOURCE: lens error
It could be jammed or when you turn it on, your finger or somthing is in way of it opening all the way.
Posted on Aug 05, 2008
  • 11967 Answers
SOURCE: Lens Error 117..
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 07, 2010
  • 2761 Answers
SOURCE: Kodak EasyShare C182 digital camera displays
If you've recently dropped the camera you may have damaged the lens zoom mechanism. This causes the camera to shut down, preventing further damage. There's no safe DIY fix for that, and the camera will require professional repair.
Another possibility is a buildup of dust, dirt, etc. in the lens mechanism. This is routinely caused by using the camera in dusty/sandy outdoor settings, or by keeping the camera in a case or camera bag. Sounds odd, but the cases build up dust which eventually ends up in the lens area. You can try blowing out the area with air from a compressor or keyboard cleaner (canned air), but this problem often requires professional repair/cleaning.
Your problem could also be power related. If your rechargeable battery is more than a year old it may need to be replaced. Old batteries appear to charge up OK, but they frequently do not hold a charge sufficient to operate the camera. Before you replace the battery though, wipe the contacts on it, and in the camera's battery compartment, with a clean dry cloth to remove corrosion that may have built up. Heavy corrosion may require cleaning with a fine wire brush, steel wool, or sandpaper. After the cleaning, give the battery a good charge and then see if the camera is working.
If repairs are needed, take the camera to a Kodak dealer/repair point (NOT the camera department in a chain store) and also check Kodak customer service on line at Be sure to get a firm price, not just an estimate, before you commit. The price of a fix can approach the cost of a new camera, and repairs typically only carry a 30-day warranty.
Bill B
Posted on May 08, 2010
Lens error
This is probably THE most common failure among digital cameras.
There's a halfway chance of fixing it yourself, described here:
Feb 20, 2010 | Pentax Optio 60 Digital Camera
First a black screen, then a lens error
For the lens error:
For the black pictures (after you've corrected the lens error):
Note, if you're going to try fix 5a on the above blog page, do it with the camera turned off to lessen the chance of damaging the lens.
Jul 04, 2009 | Canon PowerShot SD1000 Digital Camera
Lens error
This seems to happen when something (water, sand, dust) gets trapped in the lens mechanism. Has the camera been somewhere filthy before?
The recommended methods include taping on the bottom of the camera, rapping it on a table, and pressing hard on the lens. If the lens moves when you turn the camera on, try keeping your hand on it so that it's forced back into the camera body. A can of compressed air squirted around the lens is also a possible fix... but be super careful with that stuff, a good hard blow of breath might be safer.
I'm not recommending that you do crazy stuff to your camera, but if you're careful you may be able to get it working again without having to get it serviced.
Jul 04, 2009 | Kodak EasyShare C613 Digital Camera
Lens error
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here:
Jun 20, 2009 | Nikon COOLPIX L10 Digital Camera
Casio Z750 says, "Lens Error" on start up, and then shuts down?
A lens error has to be sent into repairs or else you need to buy a new camera. Repairs is 800-706-2534 and then choose extension for repairs.
Nov 28, 2008 | Casio Exilim EX-Z750 Digital Camera
Lens 12 error
This is probably the single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here:
Sep 07, 2008 | HP Photosmart M425 Digital Camera
How do you fix 'lens error restart camera' I put it in my bookbag. I guess i threw my bookbag around and now i have this "lens error, restart camera." The lens froze halfway and it's staying that way....
Aug 18, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Camera turns on BUT then get "lens error restart camera" msg
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here:
Aug 09, 2008 | Canon PowerShot S3 IS Digital Camera
Kodak EasyShare C613 Digital Camera Logo
14 people viewed this question
Top Kodak Cameras Experts
Are you a Kodak Camera Expert? Answer questions, earn points and help others
