Question about Creative Labs Gigaworks S750 Computer Speakers
Subwoofer died (again)
First time subwoofer would not work properly, power light flashing randomly & giving off virtually no sound rang creative & they replacrd it straight away, unfortuatly the replacment they sent me was faulty so i rang them back & after 27 30 minute phone calls to ireland they sent me a new one. That has been fine for the last 8 months until now, it is totally dead no power light ect, i have changed the fuse & the lead & still no good. Unfortunatly the warantee has now run out & i cant find a hi-fi technition to touch it. i dont think you can buy just the sub alone, have you any sugestions for repair?
many thanks mark
  • 2 more comments
  • garyh521 Jul 10, 2008
    I have the fires symptom of the power light blinking on the Creative S750.
    Gary
    http://bytesolutions.com
  • stupid _PCs Sep 30, 2008
    Hiya m8, if it's any consolation i have the same probs too. Found a faulty lead when i used my multi-meter and the 3.15 amp fuse had blown too. I changed the lead and the fuse but still the same flickering LED and my warranty has run out :(
    I have emailed Creative to see if they can recommend a repairer/service technician. gonna have to wait an see...
  • arzka Oct 04, 2008
    Same problems, same symptoms. Contacted Creative about this - if they can't figure out a solution, I'm going to make sure I let as many people as possible to know how crappy Creative products are. First fuse blew right away, second one lasted a bit longer but the light just flicks and the box doesn't respond to anything.
  • Anonymous Nov 17, 2008
    Fuse blows out, I've tried a 4amp 250v glass chassis that one exploded. I've tried an alternate kettle plug, no solution there.
  • 3 Answers
I will buy the broken sub if you want so you can put that money towards normally sub and use your receiver to push the speakers
Posted on Mar 02, 2009
Read this http://forums.creative.com/creativelabs/board/message?board.id=speakers&thread.id=8037&view=by_date_ascending&page=85
I was about to buy these speakers, but not after reading this
Posted on Apr 10, 2008
SOURCE:
I have a creative subwoofer which I replaced the two ICs thinking that they were the problem,but now the two speakers dont give out sound but the subwoofer one gives out an outburst of a buzzing sound...
Do not replace a part until you have proved with a signal and circuit test that there is absence of amplification. So I would suggest that you replace the original IC back to the circuit so that we start allover again.
Now you will need a signal tester- an audio frequency( AF) testor so that you can apply the signal and trace. Check the power to the subwoofer output and the main outputs. If present check with signal , check the parameters of the IC to confirm if there is amplification and BIAS to the circuit.
Once confirmed check the feeder resisitors,capacitors, check if any of them is open/short. If not recheck IC and replace once again from original source of spares.
Sep 16, 2011 | Creative Labs Audio Players & Recorders
TC-P42C2 Power Indicator Light Flashes 7 times, No video or audio
Power LED light indicator are flashing it is the effect of the power supply board are dying and not giving the tv the wright amount of voltages anymore.That the board,where the power a/c cord plug into it.U have all the tools,u understanding basic electronic also can u do basic soldering?Yes,check all over the power supply board for dying parts call capacitors.These dying capacitors are alway bulges up or puffing up on to it tops.By replacing all these dying capacitors are bulges or puffing up on it tops,will solved this flashing LED power light indication,power supply board will work again.Or try website like Ebay.com to buy a whole refurbish power supply board for the replacement.
Jan 07, 2011 | Panasonic TCP42C2 42 in TV
Subwoofer will not play with other speakers
Hello
It looks like you have posted this before. Unfortunately, I don't know what you have tried so I may be repeating some of your earlier troubleshooting.
The subwoofer needs its own power supply to function properly. if it isn't getting enough power, the sub will not work at all.
On the back of the unit, you should see a green LED when the power is turned on. Is this light on all of the time of does it fade / flicker? This would indicate the power supply is going bad and you need to replace it.
http://forums.creative.com/t5/Speaker-Systems/GigaWorks-S750-power-problems-green-LED-faded-and-flickering/td-p/547311;jsessionid=9B7C9D2D939336148A9036D7E7D18A12
Apr 30, 2010 | Creative Labs Gigaworks S750 Computer...
Creative labs gigaworks g500
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&Item=270456737725&Category=3702&_trkparms=algo%3DLVI%26its%3DI%26otn%3D1
Jun 21, 2009 | Creative Labs GigaWorks ProGamer G500...
Three blue lights blink
check you speakers and power source make sure all connection is correct
May 26, 2009 | JBL CS300.1 Subwoofer Mono Amp - 200W CS...
Speakers stopped working
I get such a thing from time to time on different systems. What I do:
1. Open the Sound Control Panel (the one on this present PC is named: "SoundMax Control Panel").
2. Enable or Disable a certain feature (something like "Virtual Theater Surround" or "Virtual Ear" or "Acoustic Environments" or so on).
3. Click Apply and the sound is back in your speakers.
4. If you want, you can undo the enable / disable and the sound still works.
May 15, 2009 | Audio Players & Recorders
Oven and control panel not working for model # JS900B0K2BB. Stove top is working fine. Panel is flashing some sort of code: F7 and d6. F7 D6. Any help
Sounds like a stuck keypad. Push all pads at random several times each then try it again. If that does not work the clock will have to be replaced.
Apr 06, 2009 | GE JS900WK / JS900CK / JS900BK Electric...
Powers on but no sound
Check the main amp fuse under the hood, even if it looks good just change it. Often times that light on the amp can come on just from the power amp tunon wire. Try a friends subwoofer box just to make sure the connectors on your box are good, and if that doesn't work then give me some more details....year/make/model of car, what kind of sub, what types of things do you see on the side of the amp....is there a green light as well as a red light?
Aug 18, 2007 | Xtant A3001 Car Audio Amplifier
Creative Labs Gigaworks S750 Computer Speakers Logo
4,229 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
