You may have accidently hooked the lines to the purge button wrong. The purge button (primer button) should have a short stem and a long stem. The short stem is the suction side of the primer button and should be hooked up to the return on the carburetor. You actually s*uck gas through the carb and not from the tank. The carb should have two hook ups. If you hook the fuel line up to one of the lines on the carb and the button is hard to push and doesn't return to normal, hook the line up to the other one. When you push the primer button gas should be pulled through the carb. The other line on the carb goes back to the fuel tank.
Check the screen inside the tank to make sure it is clogged. also check the gas cap to make sure the breather holes aren't blocked.
