Question about NetGear WG511 Wireless Adapter
Software to install wg511 32 bit cardbus
I have changed laptops and cannot find the cd for installation that came with the card - where can i download the software?
Netgear of course!! www.netgear.com/downloads_support.asp
Posted on Mar 21, 2008
How to turn on wifi
hi
the T42 does not have WiFi, instead it facilitates internet connection via 16 BIT & 32 Bit PCMCIA slot to install a WiFi card , in order to go on the internet.
The ThinkPad uses the following adapters: v 360, 365X, 380, 600: 16-Bit PCMCIA v T20, T22, T23: 32-Bit CardBus and MiniPCI v T23: 32-Bit CardBus and MiniPCI Daughter Card v T30: 32-Bit CardBus and LAN on Planar Board (LOB) v T4x: 32-Bit CardBus and LAN on Planar Board (LOB). 16- and 32-Bit PC Card adapters are configured during ThinkPad initialization. Network Interface Controller data rates are: v For Token Ring: 4/16 MBps v For Ethernet: 10 Mbps...........16 bit PCMCIA 10/100 Mbps.......32 bit CardBus 10/100 Mbps.......MiniPCI and Daughter Card 10/100 Mbps.......T3x and T40 LOB 10/100/1000 Mbps..T42 LOB The MiniPCI Ethernet adapter is accessed behind a removable plate located on the bottom of the ThinkPad directly above the Model/Type S/N sticker. For T20 and T22, the MiniPCI adapter may be an Ethernet/Modem combination card. The Daughter Card (T23) is secured with two screws and is located next to the MiniPCI modem adapter.
please go to this link to read the manual -- it will explain the features for this ThinkPad of various series T42 model-type .
http://www-01.ibm.com/support/docview.wss?uid=isg2ffa39ae31a2f590e85256ced00828893&aid=1
please rate my service
Nov 22, 2010 | IBM ThinkPad T42 Notebook
Problems with d-link DWL-G650 wireless cardbus adapter pcmcia
You can try downloading the latest driver for this card from Dlink web site and then remove the previously installed software and install the one that you have downloaded and then check if everything is working....
Dec 14, 2009 | D-Link AirPlus Xtreme G DWL-G650 108Mbps...
How do i start the d-link wireless to my laptop
Hi there. First you need to run the cd install disk BEFORE you plug in your card. Insert the CD or download the install from D-link online. Follow the instructions to set up the software. Turn off your computer and make sure the card is plugged into the PCMIA slot of your laptop. If you are using it at home and your router has a WEP security code, you must set up the card with the same code to get online. Good Luck...
Oct 29, 2009 | D-Link AirPlus Xtreme G DWL-G650 108Mbps...
My laptop does not detect my DWL-G630 cardbus card.
I am assuming it is using the PCMCIA slot on the laptop.
Since the OS is reinstalled, there is a high possibily that the drivers for the laptop devices are not fully installed.
click start -> run.
type in compmgmt.msc then ok
click on device manager and check all devices are installed correctly. If there is a yellow question mark or red cross on it then it means the driver is not present or its disabled.
Try to download all drivers for your laptop from HP website and install them.
May 29, 2009 | HP Pavilion dv4000 Notebook
Iogear gpu 202 cardbus not working with mac powerbook osx 10.4.11
Try the TechGear USB 2.0 cardbus. There are some available on eBay for $10.00. Item number is 250394104416. I bought two for older Titanium 15" PowerBooks, one on 10.4.11; one on 10.3.9. The cards works perfectly with no software drivers. I just inserted them into the PC slots and they work fine. In one case, one computer had a bad factory USB 1.1 slot, so the card does well for extending the comuter's life. The card included a CD with drivers for older versions of Windows and Mac 10.1 and Mac 10.2. I would NOT install drivers for newer systems.
Feb 27, 2009 | IOGear Cardbus Card GPU202 Serial Adapter
Installing pc card: 32 bit cardbus WG511
If your laptop is running on XP, sometimes WINDOWS installs the drivers for the wireless card automatically. If WINDOWS do not install the drivers, you need to load or install the drivers of your wireless adapter. You can use the disc that came with the wireless adapter or downloiad the drivers from the website of your wireless adapter
Mar 13, 2008 | NetGear WG511 802.11g/b Wireless Adapter
Wireless connection
before you insert the card to the slot run the cd thats comes with it and install the software. after installation of the software insert the card. if it is properly installed, you will see a single computer icon on your task bar click it up and search for a network.
Feb 11, 2008 | Computers & Internet
Startech.com IEEE 1394 Firewire Cardbus problem
Remove the card, download and install the latest drivers and firmware for the motherboard BIOS and the pcmcia controller from the laptop manufacturer's site. Uninstall all software and drivers pertaining to the startech card, download the newest set from their site, install the card back.
Aug 17, 2007 | StarTech.com (CBUSB2) Serial Adapter
Quantum Maxtor Serial Adapter
Though I suspected that I already knew the answer to your question about a source for drivers for the Maxtor 1394 CardBus Adapter, I wanted to research this in order to be able to provide PROOF that my answer is correct. As a result, I've now spent more than two hours researching this issue for you... As it turns out, the drivers you have requested are actually EMBEDDED within Windows itself, and have been ever since the release of Windows 98 Second Edition. They are listed within Windows as "OHCI 1394" drivers, which is another designation for FireWire / IEEE1394 device drivers. According to the Seagate / Maxtor Knowledge Base, there are NO downloadable drivers for the Maxtor 1394 Cardbus Adapter, and none have ever existed. The software originally provided on the CD in the retail package for the Maxtor 1394 Cardbus Adapter did NOT include drivers, which I'll explain in more detail later... As a general rule, when installing the Maxtor 1394 CardBus Adapter into a system for the first time, you insert the PCMCIA card into the Type II slot while Windows is loaded, NOT while the system is shut down; after inserting the card into an empty Type II CardBus slot, you should then hear a tone indicating that Windows has detected a device in the slot. The Add New Hardware Wizard should then load, and you might be prompted to insert your Windows CD into your optical drive, though this should NOT be necessary if you've previously installed any other FireWire devices on the same system. You can download the Installation Guide (in .PDF file format) for the Maxtor 1394 CardBus Adapter from either of the following links: http://www.seagate.com/staticfiles/maxtor/en_us/documentation/ins tallation_guides/1394_cardbus_installation_guide.pdf http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000 041641.pdf Simply right-click one of those links, and choose the "Save As..." option to download and save the Installation Guide to your Desktop, or to another folder where you can find it easily... The following links should help you to learn more; the first link explains the reason why drivers are NOT available for download for the Maxtor 1394 CardBus Adapter: http://seagate.custhelp.com/cgi-bin/seagate.cfg/php/enduser/stx_adp.php?p_faqid=831 The next link describes a known problem (and the solution) when the Maxtor 1394 CardBus Adapter is installed on some IBM Thinkpad laptops: http://seagate.custhelp.com/cgi-bin/seagate.cfg/php/enduser/stx_adp.php?p_faqid=1959 The next link describes the hardware and software requirements for installing the Maxtor 1394 CardBus Adapter: http://seagate.custhelp.com/cgi-bin/seagate.cfg/php/enduser/stx_adp.php?p_faqid=762 As I've previously mentioned, the original software (on the CD-ROM) provided with the Maxtor 1394 Cardbus Adapter were the "MaxTools" utilities (which I have NOT been able to locate for download); they were NOT actual hardware drivers for a Windows OS... Well, I hope this solves the mystery of the "missing" FireWire drivers; though I don't recall ever needing to load third-party drivers for ANY FireWire devices I've installed in a Windows system, I wanted to be able to PROVE to you (and to anyone else who reads this in the future) that the drivers are already embedded within Windows, and that they are NOT available for download. As long as you use a supported version of Windows (all versions beginning with the release of Windows 98 Second Edition), you already have the drivers available, though Windows will probably need to extract them from the Windows CD, if they haven't been loaded onto the system previously. Good luck with this; let us know if you have any problems installing your FireWire card. I don't think that is likely to happen, as long as you follow the steps in the Installation Guide. You might want to create printouts of those Seagate Knowledge Base pages (or copy them to your hard drive, or at the least, bookmark the individual links) for future reference.
Apr 01, 2007 | Quantum Maxtor Serial Adapter
NetGear WG511 Wireless Adapter Logo
101 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
