Question about Brother MFC-970MC Plain Paper Thermal Fax
Vertical dark line on copies
No matter how I clean it according to the manual I cannot get the dark line to disappear on copies
  • beatricemary Mar 21, 2008
    I have a similar problem with my Brother MFC-440CN. When I print to the printer from the pc, the printed copy comes out clear, as it should. When I use Paperport and scan (using the MFC), the vertical line appears in the scanned copy and subsequently the viewed copy of the printed copy appear with vertical line. I tried reinstalling Paperport and of course, I cleaned the screen - don't know what steps to take.
    President:
  • 2,072 Answers
That is comming from the scanner. If cleaning it well does not help, then it is one of the segments in the CCD assembly within the scanner that is the problem. That would requiring replacing tha scanner .
it could be a small scratch on that screen also.
Only thing you can try would be use some rubbing alcohol and a regular piece of 20 pound copy paper to clean the scanner glass/screen vigorously.
Posted on Mar 21, 2008
SOURCE:
All documents have dark vertical lines printed across them
you can change the drum unit. line will disappear after this replacing.
Apr 17, 2011 | Canon imageRUNNER 3030 Black and White...
Vertical line when copying. The line does nIs this a problem for
I would look at the scanner. It is not involved in the printer process but is in the copy process. Clean the glass with a glass cleaner and soft cloth. Remove the glass and also clean the lamp assembly. If either part has a dark mark on it it would leave a line on the copy. If this does not solve your problem and the unit is several years old I would replace the lamp. Let me know if you need more assistance.
Thanks for using FixYa and for the generous rating.
hardrocko
Jul 10, 2010 | HP LaserJet 3050 All-In-One Printer
Toshiba XF355 has a column of coloured vertical l...
A very common problem with toshy lcds is the tcon connectors need cleaning. Failing this a replacement tcon board will put matters right.
May 20, 2010 | Televison & Video
Dark vertical lines
You have to clean the scanner.Open the dock feeder area,and make sure the scanner glass is clean sometimes the glass look clean but just a smaal dot on the glass can cause a line.Clean also the white area above the scanner.The white area above the scanner help for shading operation of the mchine.Make sure you clean with a sullotion that can remove ink but not damage plastic.
Feb 18, 2009 | Brother FAX-8070P Plain Paper Laser
Transmitted pages are too dark, practically unreadable :
I suspect your scanner unit is going bad or it is extremely dirty.
Making a copy gets same result as when you send.
Nov 01, 2008 | Brother FAX-8360P Plain Paper Laser
Vertical lines on photocopies/faxes
The MFC-7420 Manual recommends cleaning the scanner glass and white plastic bar above it with isopropyl alcohol. Page 11-22 has a diagram.
I am having a similar problem but cleaning it did not work. But try that first.
Oct 15, 2008 | Brother MFC 7420 All-In-One Laser Printer
No matter how I clean it according to the manual I cannot get the dark line to disappear on our fax machine copies
the dark lines are caused by these things so check.
the thin strip of lamp dirty, or a light is bad
the drum has a dark toner ring around it, change
the fuser is dirty or is bad
Sep 17, 2008 | Sharp Office Equipment & Supplies
Dell All in One Printer 962-dark vertical line on photo copies
If you are running your copies through the document feeder then see if the line goes away if you make a copy directly from the glass. If the line goes away then open up the doc feeder assy. by hinging it to the left. Underneath you will find that there is a thin strip of glass that the document passes over when it is scanned. Clean this strip of glass and this should correct your problem. If there is a smudge of dirt or small line, it will come out as a solid verticle line when scanned.
Jul 31, 2008 | Dell 924 All-in-One InkJet Printer
Copies here and recipients faxes: dark, lined
How long has the drum been in there?
try this:
1-take out toner, look and see if it is ok. do you see stripes on it?
2- look at the drum are there any black rings on it? ( you did not specify white or black lines)
3- where the glass is on the opposite side ( the part you lifted to clean the glass, look at it standing from the back. you will see a white metal plate with some springs in it if you touch it. this is the reference that the fax has if there is/are a black dot on it it will give you a black line clean carefully. if it is scratched use white out to cover and make white again.
For the darkness try making a copy in photo mode if it is still too dark change drum.
Dec 07, 2007 | Canon FAXPHONE B640 Plain Paper Bubblejet
Brother MFC-970MC Plain Paper Thermal Fax Logo
127 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
